Harbor Freight 22HP Predator Engine
Discussion in 'Everything Else (off topic)' started by Bret Hart, Mar 18, 2016.
  1. Bret Hart
    Bret Hart
    Central NY
    Any chance someone here has one of these engines? Got a machine to repower and the owner doesn't want to spend big bucks. I need the measurement from the front of the engine at the flywheel screen to back of the engine at the tip of the crankshaft. Called the semi local store last night, trying to save an hours drive time, and the kid on the phone didn't seem to know how to use a tape measure.
  2. RCBS
    Bret Hart likes this.
  3. Bret Hart
    Bret Hart
    Central NY
    Looked at that and couldn't tell if the listed length was to the crankshaft or the muffler which sticks out further than the crank.
  4. ironpony
    ironpony
    Mid Ohio
    At he will post in a minute
  5. ironpony
    ironpony
    Mid Ohio
    16 in
    bobdog2o02 and Bret Hart like this.
  6. ironpony
    ironpony
    Mid Ohio
    Anything else?
  7. ironpony
    ironpony
    Mid Ohio
    19.2 with muffler
    bobdog2o02, Horkn and Bret Hart like this.
  8. Bret Hart
    Bret Hart
    Central NY
    Thank you. She'll fit just fine. What did you install yours in? Any down side to this engine for your application?
    Horkn likes this.
  9. ironpony
    ironpony
    Mid Ohio
    I was driving by the local HF and pulled it to measure it for you, I do not own one.
  10. Bret Hart
    Bret Hart
    Central NY
    Very nice of you. Much appreciated.
    Barcroftb and crzybowhntr like this.
  11. cnice_37
    cnice_37
  12. Locust Post
    Now that is what I'm talkin bout when I say we got lots of good folks around here.
  13. Matt Fine
    Matt Fine
    New York
    If you need any more info, I plan to visit HF on Saturday.
  14. Bret Hart
    Bret Hart
    Central NY
    Picked it up today and as soon as my back quits hurting I'll start the install.
  15. RCBS
    Good luck with the project...and your back. :pain:
  16. Bret Hart
    Bret Hart
    Central NY
    Thanks. I'm gonna need some luck with my back I think.
  17. Bret Hart
    Bret Hart
    Central NY
    Let the games begin. Need a lovejoy coupler, throttle cable, and to make a wiring harness and motor mount and its off to the races.
  18. Bret Hart
    Bret Hart
    Central NY
    Finished it up this weekend. Had to make a motor mount and wiring harness but it runs great and functions as it should. Only thing I'm not happy with is the vibration. Removing an opposing twin and installing a V twin makes her shake a bit but there wasn't enough room to add rubber mounts.
    Horkn, MasterMech, eatonpcat and 3 others like this.
  19. HDRock
    Nice job:thumbs:
    Jeffrey Svoboda likes this.
  20. MasterMech
    Swap the tires for some 30 gallon drums and call it a vibe roller. :rofl: :lol:
    Bret Hart and Horkn like this.
