Sycamore
Discussion in 'The Wood Pile' started by oppirs, Jan 17, 2014.
  1. oppirs
    oppirs
    SE Illinois
    Kinda want more about this type of wood. I have near me one that is down(large), and many more alive and producing in the fall Hugh leaves.
    Is it worth burning? I see it (correct me) as a Elm/maple type of tree with-out much bark.
    I could get many pines/cottonwoods, I pass on those. Except ceder, luv the smell!
    Again is worth the time?
  2. Blue Vomit
    Blue Vomit
    MD via PA
    Some like it as shoulder season wood. Depends on what you have around, what you can easily get, etc. If you pass on pine, I don't know that sycamore is all that much better.
    Grab some, let it dry, try it out for yourself. Then you know for sure for the future.
    raybonz and papadave like this.
  3. lukem
    Sycamore is worth processing if it needs cleaned up anyway. Probably puts out BTUs like silver maple, tulip poplar, maybe even cherry.
    It is SUPER wet when green, but will be ready to go in a year.
    Not a waste of time like aspen or willow for sure.
    rookie1 likes this.
  4. oppirs
    oppirs
    SE Illinois
    That I get....Pass on inferior woods.
  5. concretegrazer
    concretegrazer
    Southwest MO
    The little bit I have cut was a pain to split. I don't know if that's normal.
  6. lukem
    It is. Not elm tough, usually, but not easy.
  7. Certified106
    Certified106
    In The Hills
    It can be tough to split and retains a lot of water until you get it split. If you cut it in the summer and let it sit in rounds for a long time it goes bad quick. I wouldn't burn it in the dead of winter unless it was all I had but it works great for burning down coals and early/late season burning when you don't need max btus.
  8. oppirs
    oppirs
    SE Illinois
    Sound like Elm, I've tried too split Elm many x8.
    Any BTU to this tree?
  9. Paul bunion
    Paul bunion
    It is pretty low for BTU output, is a more difficult to split tree and lacks any redeeming value like the aroma of cherry. So in general I would say pass if you have access to cherry or soft maple or similar.
    But since you have never burnt or processed it you should at least get some of that tree so you can have firsthand knowledge.
    Blue Vomit and oppirs like this.
  10. oppirs
    oppirs
    SE Illinois
    I can get cherry-wood for free.. right now. Seasoned for next year when I get too the pile.
    I wanted to know about sycamore do to the trunk in my way.
    Thx PB looks like this tree is near value too Cottonwood. I won't cut it for heat.. Just move it.
    I see cottonwood in the rivers as the main/dominant species
    Next soft maple or river birch.
    We have sycamores in abundance, Never wanted to tackle one alive.
  11. bogydave
    18 mil BTU per cord +/-
    Good shoulder season wood.
    Be a bit picky & process the nice trunk chunks.
    firecracker_77 likes this.
  12. WeldrDave
    I got a load last year for free, about a solid cord. Burn't it up in three weeks in October:eek:…. Was good to take the chill off the house but it burns up like icecream in a deep fryer. If it's free and easy get it, but as Bogydave said… Get the bigger stuff
    OhioStihl and andybaker like this.
  13. charlie
    charlie
    Schoharie, NY
    I remember roping Sycamore limbs down doing tree work,,, heavy, heavy stuff!
  14. fox9988
    fox9988
    NW Arkansas 72717
    Yeah, its hard to split and low BTU but its burns hot and fast after seasoning for a year. It also makes lots of fluffy ash.
  15. WeldrDave
    Yup, about 85% water…. and light as a feather after drying for a year:eek:
    raybonz likes this.
  16. Paul bunion
    Paul bunion
    Last log load was the first time that I ever cut into it. There was one tree, might have been two logs. Definitely was heavy as could be. I took it in stride as I figured I needed a little shoulder season wood to go with the oak, ash and hickory.
  17. andybaker
    andybaker
    Northwest Ohio
    I too ask about this once. I have a friend in the tree business and ask him about. He said, "Well, better than burning snow balls." So I pass on it every time I see it.
  18. blwncrewchief
    blwncrewchief
    NorthCentral, IN
    lol. :rofl: :lol: That's actually a very good description. I have burned some in the past and put it about in the same group as cottonwood as far as desirability. If it is in my way on my property I will split it and burn it in shoulder season. As pointed out above, heavy, rots easy, can be a real pain to split, and mediocre heat output. Just no really good redeeming qualities. If you need wood, it is easy to get, and have a hydraulic splitter, go for it.
  19. firecracker_77
    firecracker_77
    IL
    I'd burn it if it was easy to get and cheap.
  20. dieselhead
    dieselhead
    CT
    Mofo to split
