Green Supreme
Discussion in 'The Pellet Bag' started by oldspartantrader, Mar 8, 2016.
  1. oldspartantrader
    oldspartantrader
    Northern NY
    Some Green Supreme locally at 179.00 a ton. I purchased a few bags to try before buying.
    When I got them home I noticed on the bag that they have 10% soy oil added as a binder
    Anyone ever seen this ???
    I figure if they are to chitty to use I can always add some colorant and wow the grands by use them in the fire pit
  2. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    My Harman eats them fine. They are an O.K. Pellet, but good that you do not pay more than $200/ton.
  3. will711
    will711
    Pocono Mts.
    Smart move ,they are NEWP's not really liked here by many , let your stove be the guide .
  4. eatonpcat
    I would extract the Soy, make stir fry with it...then throw the pellets away!!
  5. oldspartantrader
    oldspartantrader
    Northern NY
    I am a carnivore -- Fry only with butter and lard
  6. ttdberg
    ttdberg Pellet Pig
    CT
    My stove liked the ones from the Jaffrey mill but not the mills in NY and that's all we've been seeing around here these past few years, unfortunately.
  7. oldspartantrader
    oldspartantrader
    Northern NY
    My "concern" (if I have one) is with the soy binder. That is new to me.
    The GS pellets will not be an issue for my stove. At worst I would need to contract the cleaning schedule which is no biggie with a Serenity.
    IHATEPROPANE and ttdberg like this.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    is it soy sauce or soy oil.....makes a big difference
    IHATEPROPANE likes this.
  9. will711
    will711
    Pocono Mts.
    Are you sure it says 10% I just checked out the AWF's hardwood label and it says less than 1% veg oil
    If your stove likes them and gives you heat ,@ a $179 / ton :thumbs:
    ttdberg and IHATEPROPANE like this.
  10. IHATEPROPANE
    IHATEPROPANE
    I am one of the few that doesn't mind these pellets. I rate them about the same as MWP.
    For $179 I would buy them all day long.
    Orson_Yancey, ttdberg and will711 like this.
  11. IHATEPROPANE
    IHATEPROPANE
    Agreed, must say <1% as well. 10% oil would be rather significant I would think.
  12. will711
    will711
    Pocono Mts.
    I've never burned any Trader so I can't say one way or the other , knowing my stoves , they would eat them no problem , and @ $ 3 . 60 / bag :thumbs::thumbs:
    You got some testers you tell us how they burn :yes: if they work sounds like an awesome score for you :banana::banana::banana: Like IHP said he buy them all day long
  13. peterfield
    peterfield
    I toured the Jaffrey plant last summer and in response to a question about any additives, he said nothing was added and the heat generated from the die press is what binds pellets there. He did later say the pellets from the New York plants they own are "different" in some respects.
  14. slvrblkk
    slvrblkk
    Northampton, PA
    I would think it might be used more for a die lube than a binder.
  15. jtakeman
    X2 Saw a mini mill owner do the same with his product. Lubes the dye and helps keep it(fiber) from stickin/cloggin in the dye's. Veggie oil does add some extra BTU's from what I was told.
    I have heard of far worser stuff being added by some of the mills. I wouldn't worry much about a lil veggie oil.
    ttdberg, slvrblkk and IHATEPROPANE like this.
  16. slvrblkk
    slvrblkk
    Northampton, PA
    IIRC...diesel is used and corn too I believe.
    IHATEPROPANE, ttdberg and jtakeman like this.
  17. oldspartantrader
    oldspartantrader
    Northern NY
    Sorry --- It is .10 --My finger missed the decimal and I did not proof read
    It is labeled as an additive and I assumed (I know better than to do that) as a binder. It could well be contamination from lubrication.
    I have never seen anything like that on a pellet label, but rarely look past the ash content anyway.
    I have a bag in the stove tonite but it is pretty warm out and the stove is just gurgling. I did notice an almost immediate browning of the glass similar to what I have seen with lower grade pellets I have used (I guess what we call shoulders).
    Will likely buy a couple ton because the price is hard to beat.
    IHATEPROPANE, ttdberg and slvrblkk like this.
  18. jtakeman
    One other mill I heard uses styrafoam in there mix. o_O
    Then you have mills like MWP that only use steam and the natural lignin in the fiber. :thumbs:
  19. subsailor
    subsailor
    Winthrop, Maine
    :yes:
  20. eatonpcat
    You fellas are crazy!
