Trashed a bar and chain today....
Discussion in 'Chainsaws and Power Equipment' started by lukem, Mar 5, 2016.
  1. lukem
    I was cutting a leaner and it slid a little and the bar dropped into the notch but the chain didn't. Sprocket is smoked...the end of the bar is bent...and the chain is bent.
    Oh well...Both had some serious miles on them.
    Now that I need a new one...is is worth the extra coin for a "high end" bar or should I buy a regular 20" E bar?
    Discuss.
  2. dgeesaman
    dgeesaman
    Elizabethtown, PA
    For a 362 with 20" bar, I'd stay standard bar unless you spend significant time carrying the saw around.
    If it were 24", I'd possibly look at the reduced weight bars.
  3. WV Mountaineer
    WV Mountaineer
    Princeton, WV
    I bought a 20 inch Pro light bar made by Oregon and put it on one of my 372's. My thought was the shorter bar wouldn't see the weight savings a longer bar would see. I couldn't find a weight on the Oregon bar before buying. Well, it is definitely lighter. I don't know how much but, there was a difference.
    My thoughts are this after getting the Oregon bar:
    Neither make a 372 heavy. The 372 does balance about level with the pro light bar versus tad bit nose heavy with the Forester bar. So while the light bar is lighter, it isn't as if they revolutionize a mid 70 cc saw.
    On a 20 inch bar, price has to be the determining factor for my saws.
    I've been running that Forester bar for two years. I run saws daily during the week. That one has seen the bulk of the work. It has performed flawlessly. I just started running the Oregon. Time will tell on it. The Forester was $20.00. The Oregon was $27.00 .
    On longer bars I'd seriously consider it. For 20 inch bars, it simply isn't worth it to me with the cheaper bar performing so well. God bless men
    Horkn, NH_Wood, Eric VW and 1 other person like this.
  4. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    If it happens again its just going to cost you more coin! I consider myself to be hard on bars. I pinch them here and there and tend to yank on them quite a bit to free them. Still kind of a rookie when reading tensions on branches, but getting better! If I was a little more delicate, or cut from a pile, I would go get one tomorrow. I'm young yet (32) and probably wouldn't notice the minimal weight difference.
  5. bocefus78
    bocefus78
    I like es over e bars but I've never ran a light bar by any manufacturer. I'd probably love one:makeitrain"
    Horkn, crzybowhntr and Eric VW like this.
  6. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    I have a brand new bar and chain off a 441 if you are interested.
    clemsonfor, Horkn and mike bayerl like this.
  7. lukem
    I have a WTB in the classifieds. Post it.
    clemsonfor, Mag Craft and Horkn like this.
  8. Guido Salvage
    Guido Salvage
    Done with pictures, price and description.
    clemsonfor and Horkn like this.
  9. cgraham1
    cgraham1
    Nor Cal
    The E bars are lighter and cheaper than the ES bars.
    mdavlee, clemsonfor and Horkn like this.
  10. cgraham1
    cgraham1
    Nor Cal
    mdavlee, Horkn, dgeesaman and 3 others like this.
  11. 94BULLITT
    94BULLITT
    Frederick County, VA
    I like the looks of the ES bars better. Most E bars are low Kick back and most ES bar are not.
  12. NH_Wood
    NH_Wood
    I've been a fan of Oregon Pro-lite bars - have a 20 and 24 for the 61's and 372 and an 18 for the smaller saws. Probably 15 cord on the 18" and 10 between the 20 and 24 - drop, limb and buck. Lots of plunge cuts. Noses have held up perfectly. No curls on the rails, rails still true and haven't had to take a file to them at all. Good prices can be found on the bay and elsewhere. I don't see a need to go more expensive for what I do. Cheers!
    Barcroftb, WV Mountaineer and Horkn like this.
  13. axeman
    axeman
    Sleepy Hollow
    Honestly there are so many NOS and replacement bars for sale on the net for significantly less $ than new I would do some good searching and just pick up whatever looks best.
    Check out trading post here and elsewhere as well as the 'bay and Amazon
  14. lukem
    RJames made me an offer I couldn't refuse. All set.
    After I thought about it some more, I'd feel worse the next time I bend a bar when it costs more...so I'll stick with the cheaper stuff.
  15. axeman
    axeman
    Sleepy Hollow
    Atta boy.
    My good saws all have moderate priced bars. Would really like to slap high end bars on them but then I could buy another pro grade limbing saw instead for the same coin.
    clemsonfor likes this.
  16. MasterMech
    Actually, the wide-nose ES bars are relatively rare. Especially in shorter versions. There were two versions of the ES bar, the wide nose and one that was much more popular and more closely resembles the shape of an E bar.
    Shawn Curry and concretegrazer like this.
  17. cgraham1
    cgraham1
    Nor Cal
    I have a 20" ES wide nose. It came on my 064 when I bought it. It's the one on the far left... image.jpg
    Barcroftb, mike bayerl and clemsonfor like this.
  18. 94BULLITT
    94BULLITT
    I have 4 "ES" bars. A 16'', 20'', 25'', and 28.'' The 25'' has a green dot on it, the rest all have a yellow dot. I guess the ones with the yellow dot are not low kick back bars?
    Here is the 16''
    The 20'' on the left
  19. cgraham1
    cgraham1
    Nor Cal
    The wide nose is noticeably wider. Most ES bars are narrow nose, but maybe not as narrow as the E bars? The wider nose bars are more prone to kick back... which is probably why Stihl discontinued them. Also in my picture above is a 36" ES wide nose bar.
    94BULLITT likes this.
  20. 94BULLITT
    94BULLITT
