Earth magnet on bar , for 17" rounds
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Jan 16, 2014.
  1. bogydave
    Got the earth magnets (apex magnet)
    Link
    got one 1-1/2 diameter & two 1" diameter.
    the 1-1/2 " worked the best, stronger attachment to the bar.
    the 1" work ok but they came off much easier than the 1-1/2 " one.
    Strong little magnets !!!
    Be careful with them, easy to pinch a finger & get a blood blister ;)
    Epoxied it to a piece of fishing pole. (cut off a 1/2 - 20, 3" bolt)
    Left a nub stick thru that fits in the hole in the bar. (can't slide)
    lashed, epoxied, added some flo-pink duct tape.
    I'll test it soon
    Nice features:
    I can switch sides of the bar easy &
    fast on & off.
    DSCF2432.JPG DSCF2434.JPG DSCF2436.JPG DSCF2437.JPG DSCF2443.JPG DSCF2446.JPG
  2. bogydave
  3. rookie1
    rookie1
    NICE JOB! I love it when somebody makes a gadget to help get the job done rather than buy one.:thumbs:
  4. lukem
    Nice job, Dave.
    Horkn likes this.
  5. olyman
    olyman
    Horkn, HoneyFuzz and Beetle-Kill like this.
  6. Osage Orange
    Osage Orange
    Somebody needs to come up with way to mount a laser pointerto saw handle where dot can be adjusted to mark length of cut. Lasers are cheap and would not be anything to get in way of cut.
    My theory on making each piece of firewood perfect is similar to my thoughts on making each bale of hay perfect - the residue looks the same when I have to haul it off.
    Horkn likes this.
  7. lukem
    Lasers aren't friends with dust, dirt, and vibration. But I still like the idea.
    I'm not too particular about what my wood looks like, but it does make it easier to stack and fill the stove up completely when they are all uniform.
    Horkn likes this.
  8. Osage Orange
    Osage Orange
    They work on firearms which cause exposure to dust , dirt and vibration. I have also seen them on electric wood cutting saws. I will bet someone on here could come up with way to make it work.
    Cold Trigger Finger and Horkn like this.
  9. lukem
    I guess if they can work on a chop saw or circular saw there's no reason they couldn't work on a chainsaw. I guess I'm just a simple man.
  10. bogydave
    Two lasers set to hit the log 17" apart ( or what ever length)
    One at a spot just off the edge of the bar/chain, x distance & the other aligned to mark the desired length.
    Adjustable to get it "sighted in" for your saw , a L.E.D light starts
    blinking, then goes steady green when you're right on.
    Have them move up & down to show a line (not just a dot)
    Gonna have to work on this one. :)
    An "Auto tune" saw with a "laser sight" :)
    another light telling you your saw is at 90° & straight >>:)<< ?
  11. capetownkg
    capetownkg
    southern, MD
    Dont let the big saw companies get a hold of this thread. Every "auto tune" saw will have a $300 add on
  12. BrianK
    BrianK
    West central PA
    Stihl already thought of this:
  13. bogydave
    There goes my million $$ idea :)
  14. DexterDay
    Nice job Dave!! Love it!!
    Olyman! Welcome to the Forums!!
    Horkn likes this.
  15. MasterMech
    Welcome to FHC olyman!
    Horkn likes this.
  16. bogydave
    The old one was attached with a stud & wing nut,
    Just used it 2 days ago.
    graphite , still working , 25 cord + measured with it.:
    HDRock gave me the idea of the magnet.
    He has one with a spring, whip antenna
    BillinTX has some he made one with a spring too.
    3765-3e84724d1c927e946cce963c2d8bfef9.jpg 3764-1b1a78a353569afbfab1a7d46579e288.jpg
    BeetleKill is in the process of making one using
    one of those spring door stops gizmos. Another good idea.
  17. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Great job Dave! KJmagnetics is sending me a few, they look perfect for what I want to do. PLUS, no drilling into my bar= win-win for me! :)
  18. bogydave
    What size did you get?
  19. Beetle-Kill
    Beetle-Kill
    1-3/4" od with the 1/4 x 20 female. Did it online, so hope they show up as expected.
    Now, here's what I really expect out of them- max. 50lb. pull off. They may rate 125 lbs., but they don't qualify the thickness of the backer steel.
    Mag drills don't hold well on 1/4" plate, I suspect this magnet won't hold to spec. on a chain bar. I'm good with that.
    I'll adjust.
  20. bogydave
    I was going to order a couple of them, let me know what you think.
    I can't pull mine straight off without serious effort,
    I pull the rod at an angle, break the flat strong hold & then pull it off hard & quick.
    I put it on at 90°, then let it stand up & then put the stud in the hole in the bar.
    They are a lot stronger than I expected.
