Surburban as a beater-To buy or not to buy?
Discussion in 'Everything Else (off topic)' started by bocefus78, Jan 15, 2014.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    As I stated personal experience it's not everybody's experience it's been like that from day one. I know if you cruse junk yards and salvage yards around us you can get 5.7,s for a couple hundred bucks in great shape. As a matter of fact I'm about to do that lol. Talking to the owner is a must I would never buy a car unless I did that at a minimum.
    Clem has a good point I ebay parts all the time and save easily 75% over retail auto stores. My vehicles are all high mileage and ebay is a good way to not nickel and dime yourself to death too. I literally run them till the wheels fall off...
    gmule, Chvymn99 and clemsonfor like this.
  2. clemsonfor
    I eBay, amazon and use online discount codes for online orders for advance auto. I can usually always get between 20-40% from advance and way better sometimes on eBay. Starter I got for my Saturn was $50 shipped off eBay. Local was like $150 walking into advance!!!
    Pallet Pete likes this.
  3. Pallet Pete
    Ovid
    A good example not to stray to far off topic:emb: My Y pipe is $345 in store ebay was $107. :eek: Its a good way to save on a new to you used vehicle that's for sure.
  4. clemsonfor
    Or a $45 belt for $15 on amazon or idler pulley for $10 that's $20 in store. Man last few years I have spent hundreds on replacement parts.
    Range had timing belt, water pump, some new rubber hoses, 8 plugs, new exhaust, new manifold the year prior as the OE had 4 cracks in it one large enough to get my pinky in!!! And we don't salt roads here??? Out new radius arm bushings last year ....that was a job!! Brakes on all 4 the yr prior to the t belt work... man I don't even remember it all. It does have 297k on it though!!!
    Thorough derail now!
    Chvymn99 and Pallet Pete like this.
  5. stuckinthemuck
    stuckinthemuck
    Couple of quick things.. A pre-duramax 6.5 diesel option was available on the suburban between 1982 and 1999.
    http://en.wikipedia.org/wiki/Chevrolet_Suburban
    Look hard enough and you can find them on craigslist. Been looking to pick one up myself. Heard they can have a problem with the fuel system and the fix costs about a grand. Don't remember exactly what it was.
    http://boston.craigslist.org/nwb/cto/4288365878.html
    http://boston.craigslist.org/bmw/cto/4280948546.html
    I've done well getting parts from Rock Auto. I know there's other websites but these guys have taken care of me. Doesn't work unless you have back-up transportation or if you're ordering parts for pre-planned maintenance.
    http://www.rockauto.com/
  6. clemsonfor
    I use rock auto but have easily beat their prices through advance with coupons before. Rock auto gets crazy as they have at least 3 warehouses and unless u can find all parts in one warehouse the shipping kills you.
    But you usually do good on brakes from their.
  7. bocefus78
    bocefus78
    Ok. Ill clarify some things.
    its a 6 lug.
    I know what parts and repair cost on these things. I already have another one ( avalanche. ..sits on a burb frame) that drags landscape trailers and plows snow commercially and has for 9 years now since new. The camper is permanent. Not towing it anywhere. I really only need this to keep the miles and wear off the avalanche while getting me to and from the camper. It's 85 miles one way and I go 30 times a year minimum. I haul too much stuff to take my gas saver Ford escort.
    Test drive done. Needs lower ball joints. Everything else works. Knock sounds more like a tick. Gonna call owner tomorrow and make an offer. If it dies i think I'll look for a junkyard motor.
    Side note....how much wood can u fit in a burb? Lol
    Chvymn99, Pallet Pete and clemsonfor like this.
  8. Oldhippie
    Oldhippie
    Ashby Ma
    Depends on how much work it might need. 300+K I'd be thinking potential tranny problems, all sorts of suspension items, does the AC still work? I've got an Envoy pretty pampered with 105K on it, and it's already needed a new transmission and brakes/pads/calipers etc.. it goes through ball joints at least once every 50K or less.
    ...and sure, doing the work yourself does make it a lot cheaper, but it sounded like the engine work as going to get done by the mechanic that's got it. Not a DIY?
    I was just making the point that one would somehow need to acknowledge and be prepared to POTENTIALLY sink some money into it.
  9. clemsonfor
    I'd buy it. The tic could be lifter but proly not if mechanic says it's bearings? What are y'all doing to wear ball joints out? How do you wear out that many calipers??
    Certified106 likes this.
  10. smoke show
    smoke show
    Pittsfield, Wi
    All the stupid chain brake shops around here won't touch your brakes without hosing you for calipers too. just sayn.
    clemsonfor likes this.
  11. MasterMech
    Most 4x4 trucks eat ball joints. I don't care who makes them. It happens faster in the northeast thanks to our rough and winding roads. Tear a ball joint or CV boot and that joint is shot by the end of the season, guaranteed. Lots of salt and sand on these roads.
    I did a set of reman calipers for my GMC Canyon, when I put the third set of front brakes on it at 110k (roughly). I was using a kit from Powerstop, rotors are a PITA to change on that truck (have to pull the hub from the steering knuckle) and I did not want to chance having to pull the rotors early to have them cut, or replaced due to uneven wear from a sticking caliper.
    Bocefus, that ticking is very likely to be a collapsed lifter with 300+ on the clock. Bad main bearings usually make a heavy knocking or rumbling sound. Clicking or ticking is usually valve train or wrist pin issues. I have not run across an engine with noisy wrist pins yet however I do not work on cars for a living. If the oil pressure is good, throw a set of lifters at it.
  12. clemsonfor
    Just another way to up sell I guess? They can say .....sticking caliper....burned brake rotor....leaves you stranded. "You don't want that do you?" Or " no warrenty without swapping them out."
  13. Pyroholic
    Pyroholic
    mid michigan
    5.3's were notorious for piston slap with the short piston skirts. Especially the early ones. My 2000 made noise from the day I got it with 68k until I traded it in at 289k. It was only when cold at first, but was more prominent at the end. Never caused an issue. It seems that the aluminum blocked ones weren't as bad.
    The short piston allowed it to pivot back and forth on the wrist pin ever so slightly in the bore. Particularly when cold due to the temp differential between the Aluminum poison and cast iron bore.
    Was never an issue.
    Not saying that's what you have, but there's some more info on one possibility.
    MasterMech, clemsonfor and smoke show like this.
  14. MasterMech
    I remember that "cold knock" on the early 5.3s and 4.8s. Would make you wonder about your new(ish) truck for sure!
    Pyroholic likes this.
  15. Certified106
    Certified106
    In The Hills
    Dad used to get the same sound knock on his chevy that's being described here. The mechanic who we were friends with told him not to waste his money trying to fix it and told him it was fine. We drove that truck for years and never had a problem.
  16. clemsonfor
    All the new trucks, at least Chevy and fords have a tick to me?
  17. lukem
    Probably the injectors you're hearing. My injectors tick like a mo' fo' on my 24V 4.6.
  18. clemsonfor
    That's what I assume it is. But the new fords tick as loud as a bad lifter!!
  19. lukem
    That's probably the cam phaser (advances/retards engine timing). There's pretty damm noisy on some trucks. Mine is one of them. With a hot engine and 1300 RPM it makes some noise. At first it really pi$$ed me off, but I'm over it. It doesn't hurt anything...just makes noise.
  20. SolarandWood
    SolarandWood
    Syracuse NY
    Lots...oh wait you said in:) If you decide you want a 3/4 ton with engine noise, let me know:zip:
