Mystery ground formation appeared over night next to driveway! What is it?
Discussion in 'The DIY Room' started by don2222, Mar 2, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    There was 4 of these little hills in the grass next to the driveway so I cleaned up the dirt and another appeared this morning!
    It rained last night and then there it is next to driveway!
    What is it? How do you stop them from appearing?
    See pics below:
    Click to Enlarge
  2. Bret Hart
    Bret Hart
    Central NY
    What part of the world do you live in? Could be moles or gophers.
  3. don2222
    don2222
    Salem NH
    Salem New Hampshire, I see no bugs, animals or mole holes?
  4. Bret Hart
    Bret Hart
    Central NY
    Gotta be a witch then. :D Sorry, I had to say it.
    Maybe a spring is popping up in a new place. Does it smell bad? Septic or sewer pipe leak maybe?
  5. Bret Hart
    Bret Hart
    Central NY
    Maybe the rain and the frost in the ground is doing some strange things this year. Been very warm and wet here this winter. I imagine it's been the same there.
  6. mywaynow
    mywaynow
    Is it frozen? Sometimes the groundwater pushes up into freezing air which causes that kind of formation.
  7. don2222
    don2222
    Salem NH
    Hello
    Ground water or moles?
    wildwest and Well Seasoned like this.
  8. Grizzly Adam
    Grizzly Adam Guest
    Did it fall off you vehicle wheel wells?
  9. don2222
    don2222
    Salem NH
    No
  10. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    Did you have snowstakes marking your driveway in these locations at some point? I second water rising to the surface taking silt with it.
  11. Well Seasoned
    Screenshot_2016-03-02-21-11-06.png I agree with the others. Water freezing under ground, breaking through with pressure, filling with rainwater, freezing and expanding overnight..........
    Edit- After reviewing the pics again, is there any pipes under there or near there? The way the dirt flowered out, looks like maybe some pressure from underneath, no?
    wildwest, eatonpcat and 1964 262 6 like this.
  12. basod
    basod
    Mount Cheaha AL
    It's definitely some type of hydro pumping from under the asphalt.
    Could be natural water being squeezed from vehicle traffic following a natural path during the freeze/thaw cycles.
    Unless you have fire ants up that way, but those piles don't look like ant hiils
  13. TurboDiesel
    Is this any where near your city water line?
    Sewer line?
    Gas line?
    underground electric?
    If not, it could be the start of a sinkhole of sorts. Don't worry though, it could take up to 10,000 years before your house collapses into it! ;)
  14. don2222
    don2222
    Salem NH
    Thanks for your comments.
    There was a lot of snow from the driveway piled there and the car wheel ran back there a while ago.
    We also had a lot of freezing and thawing lately too!
    Stinny, wildwest, 1964 262 6 and 2 others like this.
  15. TurboDiesel
    Looks like pretty sandy soil. Wouldn't take much water to bring the sand to the top
  16. smoke show
    smoke show
    Pittsfield, Wi
    I saw something very similar to that in the toilet this morning.
    Stinny, wildwest, bobdog2o02 and 8 others like this.
  17. wildwest
    don2222 , where is your new sunroom w/ top deck draining to?
  18. HDRock
    wildwest, Horkn, basod and 3 others like this.
  19. Gasifier
    :picard:
    Stinny, wildwest, Horkn and 5 others like this.
  20. bogieb
    Doesn't have to be the entrance to a mole tunnel, just a weak spot in the tunnel ceiling. You can't stop them from appearing at this point in time. Welcome to the wild, wild, world of nature.
