When is a chain officially "finished"?
Discussion in 'Chainsaws and Power Equipment' started by saskwoodburner, Feb 25, 2016.
  1. saskwoodburner
    saskwoodburner
    Is there a right answer? How far do you run a chain before it's considered garbage?
    The original low kickback chain that came with my saw has seen a hard life, and I believe nearing the end. I don't mind, I have a big boy chain waiting to go. How should the top plate look before it hits the scrap pile? Shoot for a triangle and toss?
    Barcroftb likes this.
  2. concretegrazer
    concretegrazer
    Southwest MO
    When it starts loosing cutters I'd say it's done.
    Horkn, Barcroftb, UncleJoe and 7 others like this.
  3. saskwoodburner
    saskwoodburner
    I didn't realize you could let them go that far lol. Poor mans skip tooth chain.
    Barcroftb, Horkn and OhioStihl like this.
  4. Nixon
    Nixon
    West Sunbury,Pa .
    Like concretegrazer said . In fact if the rakers are done right ,and the gullets clean out ,they seem to cut their best just before the die .
    Barcroftb, Ron660, basod and 3 others like this.
  5. crzybowhntr
    crzybowhntr
    WV
    I agree that they cut better at the end of life. Less drag???
    Barcroftb and saskwoodburner like this.
  6. Nixon
    Nixon
    West Sunbury,Pa .
    Just a wag , but that ,better chip clearance ,and the cutter not only shortens as it goes back but also gets narrower . So ,maybe narrower kerf as well . Whatever it is ,it seems to work .
    Horkn, Barcroftb, basod and 4 others like this.
  7. clemsonfor
    Yea when the teeth start knocking off its done
    Barcroftb, Horkn, basod and 3 others like this.
  8. mike bayerl
    mike bayerl
    Too many rocks around here and operator error will kill any of my chains before they are filed too far. This is why I've invested in a 1/2 roll of 72LPX.
  9. man of stihl
    man of stihl
    NW PA
    Narrower kerf from a chain at the end of its life = less wood removed = faster cuts.
  10. Oldman47
    Oldman47
    Illinois
    Lots of chains have a line on the top of each tooth to define the sharpening angle. Once you have filed that line off the chain should become history.
  11. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    This is what I use as my rule of thumb. Maybe a sharpening or 2 after but thats about it.
    saskwoodburner and Horkn like this.
  12. clemsonfor
    Why would you toss it there if your still getting cuts out of it? I agree that's pretty much the point at which it becomes a triangle cutter and they start falling off but I go till you start loosing teeth
  13. MarylandGuy
    MarylandGuy
    Maryland
    When Bailey's has a good sale and makes it a no brainer.
    clemsonfor and Horkn like this.
  14. clemsonfor
    Or left coast supply. When the 20" oregon loops at $10 shipped to house.
  15. Barcroftb
    Barcroftb
    The Mitten
    Nah that's just a warning line. Like the gas light on your car. It let's you know when it's time to think about ordering a new chain. So you have it ready for when you finally file more than half the cutters off the chain. :rofl: :lol:
    Seriously though being a cheap sob I try to squeeze $ .99 out of every penny. I usually run a chain until I file a tooth off. Then I start at that tooth and grind every other tooth off. Now I have a skip tooth stump chain. Or a birthday present for my Brother In Law. Unless, of course, the chain has been damaged or looks dangerously worn.
  16. clemsonfor
    Like the skip tooth idea
  17. NewToStihl
    NewToStihl
    Central Indiana
    What he said. Spot on.
  18. saskwoodburner
    saskwoodburner
    There was never any line on the top plate of my chain.:(
    clemsonfor likes this.
  19. saskwoodburner
    saskwoodburner
    I mentioned the skip tooth chain idea in post #3, but I was kidding. :saw: Now maybe not....squeeze that last dying breath out of it just for fun. It's not yet to triangles, so it's got a few more cuts left to go!
    Barcroftb and concretegrazer like this.
  20. Barcroftb
    Barcroftb
    The Mitten
    It's not chain I'd use everyday, but is good for chopping wind rows down, trees you suspect have fence in them, stumping, etc.
    HDRock, Oldman47, Nixon and 1 other person like this.
