Balls!
Discussion in 'The Wood Pile' started by MasterMech, Jan 14, 2014.
  1. OhioStihl
    OhioStihl
    Southern Ohio
    Bogydave! Great idea on the stack stability. I am going to try that, my girlfriend will appreciate it because I want her to stack instead of me. Her stacks are more stable than mine. That sounds wrong, doesn't it?
  2. mywaynow
    mywaynow
    That fallen stack reminds me of one of my favorite passive-vulgar slang terms: sack of balls! As an ex baseball coach, it just makes sense.
  3. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Nope it is definitely a Falzendownzen!:)
    Gary
  4. MasterMech
    Stacking Sir Isaac Newton style......
  5. Pallet Pete
    Pallet Pete Moderator
    Ovid
    That's usually what made mine top so I started just putting the uglies on the tops of all the stacks rather than mixing them in. It works much better.
  6. Pallet Pete
    Ovid
    :rofl: :lol::whistle:
    WeldrDave likes this.
  7. bogydave
    I drive some in with a hammer as the row gets the right height so I
    don't have them sticking out in the way while stacking.
  8. DexterDay
    That always sucks. The bad part, is it was the stack? I have had some of my racks lean quite a bit, but never fallen? For that entire rack to still stand and the stack fall? They had to have some serious uglies. Those racks seem indestructible. I like my racks, but it LOVE yours!
  9. Certified106
    Certified106
    In The Hills
    That really stinks! I hate stacking the first time let alone a second
  10. Paul bunion
    Paul bunion
    I use the rope method, except its 1" nylon web from my rock climbing days that I drive a nail thru and into the wood. It holds adjacent stacks together real tight. I have no concerns about metal in the wood anymore.
    The stick method should work fine, just do it separate for each pair of rows. Pete would do it with salvaged pallet slats. :)
    clemsonfor, fox9988 and MasterMech like this.
  11. trooper
    trooper
    Arizona: It's a Dry Heat!
    Looks all too familiar :(.
  12. NortheastAl
    NortheastAl
    Putnam County NY
    Why do they always seem to fall when it's cold, snowing or raining?
    trooper, clemsonfor and MasterMech like this.
  13. MasterMech
    Dex, these racks are inspired by yours, pretty much the same thing except they are built in groups of 3 with a common stringer along the bottom ends and a 2x4 rail on the top of each end tying the 3 units together. If a middle leans, not really a big deal, and if an outside row leans outward, there are two other rows to hold the entire rack in place. Now I just gotta figure out how I want to top cover them.
    I have 5 of them and that gives me roughly 10 cords worth of storage and single-row drying capability. I could get even more wood in the same area if I move them closer together or go back to stacking on pallets and not leaving an air gap, but it becomes even more difficult to top cover and access the stacks in the snow.
  14. Gasifier
    That will give you a good core workout MM. Always look at the positive side. And that wood will have warmed you "several" times by the time it is gone!
    Mitch Newton and clemsonfor like this.
  15. ansehnlich1
    ansehnlich1
    a guy could screw a 2x4 across the ends of his rows, 'bout half way down, that usually keeps 'em from becoming that fallzendownzenhauzen.
    clemsonfor likes this.
  16. Backwoods Savage
    MM, just look at this on the positive side. Those crazy guys who never have to re-stack the wood only get one shot at it. You get more practice and may end up better at it in the end. :whistle:
  17. Hinerman
    Hinerman
    NE Oklahoma
    Me too, which is why I would never stack that high....Even stacked correctly, stacking that high is bound to fall over at some time or other...
  18. charlie
    charlie
    Schoharie, NY
    I built the same size racks 4 years ago... One time I had one fall over... Now I make sure that if anything, the angle of the wood stack is leaning back if not level,,,, if it does fall it's just against the rack behind it... then it will get fixed when I burn it..
    papadave and Chvymn99 like this.
  19. Backwoods Savage
    Charlie, where is all that apple wood?
  20. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    But that is how firewood warms you again and again and again and ......
    savemoney and DexterDay like this.
