How would you cut a fuel oil tank in half?
Discussion in 'The DIY Room' started by Star Gazer, Feb 24, 2016.
  1. Star Gazer
    Star Gazer
    Right behind you
    With spring just around the corner, thoughts have turned to outdoor projects. One of which is to cut at least one of those ovalish oil tanks in half longways to make a cover for a settling tank fed by a spring. Maybe even cover the spring head to keep all sorts of leaves and debris from covering it.
    The holding tank is about 46 inches across by 96 inches in length, so I was thinking of cutting one or both of the oil tanks I have in half and bolting them together for the cover. I would be washing the inside out to remove any surface fuel oil that might remain.
    So my question is, how would one go about cutting these in half lengthwise?
  2. chris
    sawsall- tanks are not that heavy a steel - the saw shouldn't create any sparks if used properly.
  3. papadave
    Thinking the same thing.
    Horkn, bobdog2o02 and Star Gazer like this.
  4. Grizzly Adam
    Grizzly Adam Guest
    Stick of dynamite-- Kaboom!
  5. Star Gazer
    Star Gazer
    Right behind you
    Thanks! :D I do have a Dewalt Sawsall but I wasn't sure it would be able to cut those tanks. And thanks for alleviating my concerns about sparking without my asking!:)
    Horkn likes this.
  6. Star Gazer
    Star Gazer
    Right behind you
    :rofl: :lol: Sounds like fun but that might distort the tanks a bit much!
    Horkn and papadave like this.
  7. Grizzly Adam
    Grizzly Adam Guest
    My brother cut his up with the sawsall. His house smelled like deisel for two weeks.
  8. RCBS
    If you want an extra level of redneck safety you could pipe your truck exhaust into the tank to flood it with co2 to negate explosion danger. It's not the liquid so much as the fumes that will combust easily.
    basod, OhioStihl, Horkn and 5 others like this.
  9. papadave
    You'll probably need at least a couple new metal blades.
    I've only cut up one of those tanks, but it wasn't too tough.
    Horkn and Star Gazer like this.
  10. saskwoodburner
    saskwoodburner
    Angle grinder with a cut off wheel/disc?
    The tank may smell like diesel forever though.
    XXL, Horkn, bobdog2o02 and 2 others like this.
  11. Star Gazer
    Star Gazer
    Right behind you
    One tank has somewhere between 5 and 10 gallons of the fuel oil still left in it. But I will drain it into suitable receptacles before I cut. The cutting will be done outside so I'm not too concerned about the smell if there is any.
    I was considering making one tank into a smoker where I hook an old wood stove I have to it. Then I could almost hang a whole deer in there. The only drawback is I have no knowledge of smoking meats of any kind. (do you light the butt end first? :rofl: :lol:)
    Horkn and bobdog2o02 like this.
  12. Star Gazer
    Star Gazer
    Right behind you
    I do have quite a few metal blades so I should be good on that end. The ones I have allegedly are better than most. (Bosch 18 TPI)
  13. ironpony
    ironpony
    Mid Ohio
    rule of thumb for TPI, two teeth should be in contact with the material during the cut. You might want some 24 TPI blades. to coarse will tear the edge of the material, to fine clogs easily, no room to clear chips.
    Sawzall, medium speed, again rule of thumb 60 strokes per minute, steel.
    actually you might have more control with a jigsaw and good blades.
    correct speed and TPI, you can cut both tanks with one blade.
    basod, Star Gazer, Horkn and 3 others like this.
  14. Eric VW
    I hereby "like" all these posts.... There's a vid of a fellah converting a large propane tank into a smoker..... He filled his with water.
    I don't think home heating oil offers the same volatility as gas(propane, natural, or gasoline). But- safety first:thumbs:
  15. Horkn
    I'd say a sawzall or an angle grinder would both work well. In any case, put some ear plugs in before you saw/ grind away.
  16. swags
    swags Moderator
    I used a sawsall and it worked great. I think I only went through one blade. Like said above its not thick metal.
  17. eatonpcat
  18. ironpony
    ironpony
    Mid Ohio
    Eric VW likes this.
  19. Redfin
    Redfin
    central Pa
    Nitrogen works really well for a plasma.
    Eric VW and Star Gazer like this.
  20. Elderthewelder
    Elderthewelder
    Washington State
    Angle grinders with cutting discs create a lot of sparks
    basod, Eric VW, Horkn and 1 other person like this.
