Wood Shed Ideas
Discussion in 'The Wood Pile' started by woodwiz, Feb 13, 2016.
  1. woodwiz
    woodwiz
    Kenockee MI
    IMG_20151117_162334579.jpg IMG_20151117_162315243.jpg Was able to get some free, heavy duty guarding that was being disposed of. A late engineering change at one of the Big 3 assembly plants, obsoleted this stuff, so I scooped it up. Decided to prop it up against the previous homeowners wood storage posts to get some ideas.
    Think I will drop some 4x4's in the ground and build an elevated deck and use these for the walls. Not quite sure how I am going to tie it all together.
    Any Ideas would be greatly appreciated.
  2. Eric VW
    Other than the expanded metal, what are the frames made of?
    Would make a fantastic flooring for the structure. Think of the air flow! Ashwatcher has metal like that in his shed.
  3. woodwiz
    woodwiz
    Kenockee MI
    The frames are made from a heavy gage C-channel. Each section weighs at least 100 lbs.
  4. Backwoods Savage
    Good luck woodwiz. One thing for sure is that you'll have lots of t-posts when you are done!
  5. Eric VW
    Walls are a good idea for sure, but I'm still feeling the deck would be the best use for them. :)
    Sure do wish I had about a 1/2 dozen of them:thumbs:
    I'm anxious to hear other's thoughts....
    Backwoods Savage is right about having a surplus of tee's:yes:
  6. woodwiz
    woodwiz
    Kenockee MI
    You can have all the tee's when I'm done.......
  7. woodwiz
    woodwiz
    Kenockee MI
    I had thought about the floor, I just didnt like the fact that the expanded metal is inset about 1 1/2", which would leave the floor with steps all over the place and stacking would be a bear.
  8. Eric VW
    Got it... That could be a royal PITA....
  9. LinkedXJ
    LinkedXJ
    Looks like you are trying to keep the bears out of your stash. lol!
  10. Horkn
    I'd definitely find a better solution than tarps to be used to top cover. Tarps suck. They fall apart, shred apart, from UV and wind.
    Rubber roofing works much better so I hear. So would metal roofing, or shingling a plywood roof like a house.
  11. 1964 262 6
    1964 262 6
    williamsburg, ohio
    how about, turn them all long side down and make them the back wall of a 3 sided shed. use skids for a floor,small ends,roof sloping back......just my take
  12. woodwiz
    woodwiz
    Kenockee MI
    Yeah there will definitely be a roof!! I was thinking about a hip roof with plywood and Condura to cover it.
    HighCountry, 1964 262 6 and Eric VW like this.
  13. woodwiz
    woodwiz
    Kenockee MI
    Bears are about the only critter I dont have out here
  14. JeffGu
    JeffGu
    Osceola, Nebraska
  15. Paul bunion
    Paul bunion
    The 1.5 inch setback is a big problem although they could make a nice floor. Can you fit a pallet into or onto those things? That would fix the problem. Level them with whatever scrap you have available and they could do it. It would make an awesome floor.
  16. crzybowhntr
    crzybowhntr
    WV
    My thoughts exactly! The air flow and longevity of that being a floor, if set on blocks, would be great.
  17. Eric VW
    :thumbs:
    I been wondering when you'd pop up?!!!:sherlock:
    Good to see ya' man:handshake:
  18. crzybowhntr
    crzybowhntr
    WV
    you as well. Been busy a one legged dog in, well.....
