Husqvarna 268
Discussion in 'Chainsaws and Power Equipment' started by old iron, Feb 12, 2016.
  1. old iron
    old iron
    sw va
    Hey fellows I have a 268xp special what ya'll think about theses and what does the special mean?I got it from a friend, Has not been used much,I have to pull it a lot more times to get it to crank than my stihl 360,are they harder to start or think mabe it needs a carb kit? once it starts it no problem to start
    foragefarmer likes this.
  2. MasterMech
    I would look at the fuel line and filter and the carb pump diaphragm since it sounds like it just has a hard time moving fuel.
    I've never had one but the 268 is supposed to be a great saw.
    HoneyFuzz and foragefarmer like this.
  3. old 040
    old 040
    Buckeye State
    "Special" in this case most likely means it has a closed port cylinder rather than the open port........which is a good thing!.........:D
  4. foragefarmer
    foragefarmer
    Central, Virginia
    Are you using the throttle lock on the handle to start the unit?
    HoneyFuzz likes this.
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    MasterMech and old 040 like this.
  6. old iron
    old iron
    sw va
    I have al ready replaced fuel line ,I have a new kit for carb but haven't put it in yet
    Thanks Honeyfuzz for info,when did they stop making these?
  7. old iron
    old iron
    sw va
    Yes
  8. old 040
    old 040
    Buckeye State
    I put a 268 closed port mahle cylinder with 266 pop up piston on this old model 61, doesn't look like much, but sure runs awesome!!.........:D DSCF0052.JPG
    Sunfish, tamarack, MasterMech and 2 others like this.
  9. NH_Wood
    NH_Wood
    I think I remember reading that the 268's were all open port and the 268xp's were all closed port - but it was a while ago! Cheers!
    old 040 and HoneyFuzz like this.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Hey no problem ! I have no idea how long the special was made...but I can try and find out. I know they were labeled 268....268xp....and 268xp special...
    My guess....is the 268xp special was a short run....but that's just a guess !
    old 040 likes this.
  11. old 040
    old 040
    Buckeye State
    If I remember right, from what Nikko has stated in the past, these 268's and the 365's need to be physically checked for open or closed port regardless of how they were labeled.......
    Sunfish, NH_Wood and HoneyFuzz like this.
  12. NH_Wood
    NH_Wood
    Ahhh.....thanks! Cheers!
    HoneyFuzz and old 040 like this.
  13. old iron
    old iron
    sw va
    a buddy and I put in the new carb kit and now it starts on 3-4 pulls cold,this saw has good power!
    Thanks
  14. old 040
    old 040
    Buckeye State
    Yep, they're great runners!..........:dex:
  15. tamarack
    tamarack
    paulina oregon
    Tough to beat an old 200 series husqvarna chainsaw, lots of them still goen strong after many years of cutting wood.
  16. Sunfish
    Sunfish
    Success Mo
    268s' are very good saws!
  17. old iron
    old iron
    sw va
  18. old iron
    old iron
    sw va
  19. WV Mountaineer
    WV Mountaineer
    Princeton, WV
    It is likely a closed port design with that special name. If I'm remembering correctly, the 365 special was while the 365's were not.
    Eitherway, those 268's will flat out run. Great saws. Awesome power versus weight. God Bless
  20. old 040
    old 040
    Buckeye State
    Yep, that unit will bring home some firewood!!..............:stacke:..............:fire:
