My Hearth Pad
Discussion in 'The DIY Room' started by Kimberly, Feb 10, 2016.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I promised I would show my new hearth pad once I got it completed. I call it a hearth pad because it is not permanently attached; it is more like the prefabricated hearth pads on the market. When I ended up going with the Madison stove from England Stove Works, I no longer needed the R2 hearth and thus could build a cheaper solution.
    I started with a 4x8x15/32 sheet of plywood as the base. My sister drove over in my brother-in-law's big 250 GMC truck to get the supplies. She helped me to pick out a nice tile; the tile was porcelain and I found out that you needed different mortar for porcelain tile. I cut out a 4x6 rectangle from the sheet of plywood and did some angles at the corners. The hearth did not need to be that wide but I thought it would be more pleasing to the eye and it gives more room for setting implements and extra fire wood.
    I went with premixed mortar; more expensive but less likely for me to screw up. It did not want to behave though, some times when I did the notches it would do correctly then other times it would mess up and I had to go back and redo it. I decided after reading a post on the net to back butter all the tiles to make sure they would adhere properly. I started by getting the center lines and started laying the tiles from the centre out.
    I ran out of mortar before I finished the project; probably because I was back buttering the tiles, so cleaned up around the tiles so I could pick up without having the problem of chipping mortar off the plywood. I had never done any tile work before so it was not the best of jobs plus the issues I had with the mortar not wanting to behave correctly. I grouted the tile and then had an issue with the grout haze not wanting to come off. They make it sound so easy in the video tutorials and maybe it is with some tiles. I am sure the grout glaze issue is not as bad with ceramic glazed tile since the surface is much smoother. These tiles are meant to mimic stone and the surface is not completely smooth.
    I trimmed the edges with some oak moulding from Lowe's. I was surprised that oak moulding is only a bit higher in price than pine. I got Lowe's to cut the two tiles at the corners and there was no charge for doing so since it was only a couple of pieces. I must say, the tile cutter went through these tiles as if they were butter on a hot summer's day.
    Hopefully this hearth pad will be suitable for my new wood stove. It may not be the best of jobs but function over beauty.
    unclefess, Woodwidow, Deacon and 12 others like this.
  2. fox9988
    fox9988
    NW Arkansas 72717
    Looks good :thumbs:
    Horkn, wildwest and Eric VW like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    Thank you.
  4. Eric VW
    WOW!!!! You did great, Kimberly :thumbs::D
    And it's portable? Cool:)
  5. milleo
    milleo
    Looks nice, can't wait to see the stove on it...:thumbs:
  6. Kimberly
    Kimberly
    The Kangaroo State
    Thanks, don't look too closely or you will see my boo-boos. I will admit that I was rushing to get this finished. I should have took more pains with it.
  7. Kimberly
    Kimberly
    The Kangaroo State
    Thanks, I can't wait either and it has turned cold here.
  8. papadave
  9. Eric VW
    The greater Martinsville area......
    Horkn, Well Seasoned and papadave like this.
  10. brenndatomu
    Nice!
    Horkn, Well Seasoned and Eric VW like this.
  11. Eric VW
    Don't know what you use for weather app/reports/forecasting/imagery, but the above image was from:
    National Weather Service
    (It will link to your area)
    Great site....no where near the greatness of FHC, tho:thumbs::D
    Horkn and Well Seasoned like this.
  12. Kimberly
    Kimberly
    The Kangaroo State
    Thank you.
    Horkn and Eric VW like this.
  13. Kimberly
    Kimberly
    The Kangaroo State
    Normally I use the weather underground. I have a desktop thingy that links to the page.
  14. Kimberly
    Kimberly
    The Kangaroo State
    I froze outside today. I went out and took all the firebrick out of the stove and the door to make it lighter for bringing in the house.
  15. Kimberly
    Kimberly
    The Kangaroo State
    Soon, very soon.
  16. Kimberly
    Kimberly
    The Kangaroo State
    I second that!
  17. brenndatomu
    What's your plan there...go to Lowes and bat your eyelashes at a couple big burly Lumber Jack types then challenge then into a stove lifting contest? :rofl: :lol:
    Woodwidow, Horkn, HDRock and 3 others like this.
  18. Eric VW
    Kick up the accent + the eyelash batting and a few fellas from FHC would prolly drive HOURS to take up that challenge:whistle:
    :thumbs:
  19. papadave
    Ya' gotta' quit using such confusing technical terms.
    They're.......confusing.:rofl: :lol:
    Woodwidow, Horkn, HDRock and 2 others like this.
  20. Well Seasoned
    Nice work Kimberly! Once things are complete and your sitting in front of that warm fire, you will feel extremely proud of your accomplishment!
