I run used motor oil instead of bar oil, anyone else??
Discussion in 'Chainsaws and Power Equipment' started by ironpony, Oct 4, 2013.
  1. ironpony
    ironpony
    Mid Ohio
    HaHa beat you to it........but
    I really do run used motor oil
    SmokinJay likes this.
  2. Pallet Pete
    Pallet Pete Moderator
    Ovid
    O for crying out loud ! :confused:
    Scotty Overkill likes this.
  3. swags
    swags Moderator
    rofl, I thought about that last night
  4. 343amc
    343amc
    Northeast Lower Michigan
    That didn't take long to get posted.... :)
  5. clemsonfor
    Dang it! beat me. no that stuffs nasty. only the best $10 gallon bar oil for my saws!
    if it was so great wouldnt loggers use it ?
    Husky Man likes this.
  6. MasterMech
    The used motor oil practice is much less common with equipment enthusiasts seeking the very best care for their machines and those who work with their tools every day and insist on reliable, and cost-effective performance. Not to mention those that fix the dang things. ;)
  7. Machria
    Machria
    Long Island, NY
    I don't use oil at all!! It just makes a mess!
    RichE23ACR, JackHammer and Husky Man like this.
  8. StihlHead
    StihlHead
    The wild west
    My father had a love for used motor oil. He called them drippings, and he used them wherever he could. He dumped them on his driveway to keep the dust down, and he used it for lube and in various other places, including his precious Homelite chainsaw. I give him some credit, as in those days motor oil was all there was for bar oil. However, he died a horrible early death. Really, he died of liver cancer. Which is one reason I detest these posts, even though I know they are made in jest (at least by some people).
    Exposing yourselves and your expensive toys unnecessarily to used motor oil is not a very bright. That stuff has blow-by gas, heavy metals, a lot of detergent, as well as other unhealthy crap in it. It also does not have and tackifier in it and it will sling off your bar even faster with the added detergents. If you use motor oil as bar oil, use 'virgin' non-detergent oil, like ND-30. O/w use a good bar oil designed for it (which is basically ND 30wt with a tackifier and maybe a dye added). Also for winter grade oils, use a winter weight 10wt based bar oil rather than thinning the bar oil with diesel or kerosene. Or just leave the bar oil inside with the saws the night before cutting and your oil should flow well for the day of cutting. Also you may want to consider using canola oil, as that is actually cheaper than bar oil around here now, and is far better for you and the environment that you are slinging oil around in.
    cmag and Scotty Overkill like this.
  9. fox9988
    fox9988
    NW Arkansas 72717
    Right or wrong, I used it for many years. Never burnt up a bar or chain. I've now been shamed away from it. All my used oil is now recycled in a heavily modified pre-epa wood stove with an oil drip, in a friends shop. :confused:
  10. firecracker_77
    firecracker_77
    IL
    I just use the stuff from Menards. $8 a gallon and I'm not damaging my saws. Not sure if it matters.
  11. MasterMech
    For the average firewood cutter, we don't use enough bar oil for it to be a considerable expense.
  12. Scotty Overkill
    I hate these posts........:mad:;)
    I think I will try out the canola oil with an added tackifier.......someone posted on the "other" site not long ago a link to tackifiers that you could add to the canola oil...as well as a food coloring to dye it so you could see the oil better when running the saw...
  13. jharkin
    jharkin
    I just use the husq stuff. I don't cut enough for the cost to matter.
    About used oil, I know I should be more careful and wear gloves doing oil changes. I just can't get used to it, loosing grip on the tools...
    Husky Man and Eric VW like this.
  14. firecracker_77
    firecracker_77
    IL
    I sometimes wear latex gloves for changing oil. They tear easily, but they make cleanup a breeze.
  15. SmokinJay
    SmokinJay
    I run what I brung! Heck I even used auto trans, fluid hydro, corn, veggie and some of the gf extra virgin olive oil. Don't tell her I only had a short run to do.
    RichE23ACR, thistle and Pallet Pete like this.
