Hastings stove or Barefoot Pellets?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by BHags, Feb 1, 2016.
  1. jtakeman
    Unless your the neighbor! :mad:
    :whistle:
    imacman, ivanhoe, Ambient and 4 others like this.
  2. krooser
    krooser
    Waupaca, WI
    The neighbor needs a sense of humor...
    imacman, slvrblkk, ivanhoe and 6 others like this.
  3. BHags
    BHags
    Massachusetts
    I burned about 20 lbs of last years brand and had good luck. No clinks. Just started it up with a full load of barefoot. This will be the real test.
    imacman, slvrblkk, ivanhoe and 3 others like this.
  4. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    It takes a lot of poking and prodding with all of the instruments of torture to completely clean a St Croix stove and that includes their "furnace" units.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    And a garden hose.
    imacman, bogieb, BHags and 3 others like this.
  6. ivanhoe
    ivanhoe
    Northern Ontario
    He should look on the bright side of things, free fertilizer :D
    imacman, bogieb, BHags and 2 others like this.
  7. BHags
    BHags
    Massachusetts
    I just finished burning 40 lbs of Barefoot. Looks like I have to let them off the hook! One thing I noticed after the Leafblower thing, was the little sparks flying around the burn pot when pellets drop in. That's a good sign, looks like air is flowing well again. I would have sworn that thing was clean! Time for a beer!
  8. will711
    will711
    Pocono Mts.
    Sounds great I'll join you :thumbs::cheers::pete:
  9. ivanhoe
    ivanhoe
    Northern Ontario
    Me too as the weekend has begun:cheers:
  10. will711
    will711
    Pocono Mts.
    ivanhoe you in Brother ??:drunk:
    bogieb, PelletHound, imacman and 3 others like this.
  11. will711
    will711
    Pocono Mts.
    You beat me to the post :drunk:
  12. imacman
    imacman
    Denver, NC
    Me too! I've been "in" for about 2 hours already. :cheers:
    PelletHound, will711, ivanhoe and 2 others like this.
  13. bobdog2o02
    bobdog2o02
    Drury Lane, PA
  14. Smokinpiney
    Smokinpiney
    "South" Jersey
    Just cracked my first one! :drunk: Was up at 3am to go push more white stuff :headbang:.
    Glad you got her running good again BHags !
    bogieb, PelletHound, slvrblkk and 4 others like this.
  15. ivanhoe
    ivanhoe
    Northern Ontario
    Had one awhile back and soon to have the following others. You could say I'm in:drunk:
    bogieb, BHags, PelletHound and 3 others like this.
  16. will711
    will711
    Pocono Mts.
    Yes you Are :cheers:
    bogieb, BHags and ivanhoe like this.
  17. BHags
    BHags
    Massachusetts
    Just some more praise about the leafblower clean out. My versa grate was making a knocking noise when I was having the clink problems. That noise is gone. The stove is running like brand new. I'll have to do it again in another 9 years!
  18. Smokinpiney
    Smokinpiney
    "South" Jersey
    BHags do you pull the grate out when you clean the stove? If you get a bad enough clinker or a build up on the grate it will push against the bottom sides of the burn pot
    bogieb likes this.
  19. BHags
    BHags
    Massachusetts
    I pull everything out and scrape it clean. Now that the air flow is corrected, clinks don't build up, and it's running like new.
    bogieb, Smokinpiney and bobdog2o02 like this.
