Cold plug
Discussion in 'Modern EPA Stoves and Fireplaces' started by CNE deer, Feb 5, 2016.
  1. CNE deer
    CNE deer
    ohio
    Just filled the house with smoke due to a cold plug........................THIS S*CKS didn't have any newspaper to get it going the right direction
    Keweenaw and bobdog2o02 like this.
  2. HarvestMan
    HarvestMan
    Southeastern Michigan
    Never heard of a cold plug. Can you provide a bit more information about how/why this happened?
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I thing he's referring to a reversed draft.
    I use a propane torch up the chimney to get draft started.
    brenndatomu, Horkn and Keweenaw like this.
  4. Keweenaw
    Keweenaw
    tapiola mi
    Birch bark ;)
    Horkn and bobdog2o02 like this.
  5. Gary_602z
    Gary_602z
    Lake Odessa, Michigan
    Wifes hair dryer!:)
    Gary
  6. CNE deer
    CNE deer
    ohio
    I normaly use newspaper but didn't have any , the stink is finally starting to fade.
  7. CNE deer
    CNE deer
    ohio
    I think it is when you cant get the flow of air up and out it acts like a "plug" all the smoke goes into the house until the draft gets going:loco: :crazy::loco: :crazy:
  8. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Yup hairdryer or better yet, heat gun pointed up to pre-warm the chimney.
  9. Deano31
    Deano31
    I do as someone else said hand held torch works great
    brenndatomu likes this.
  10. HarvestMan
    HarvestMan
    Hair dryers, heat guns, torches oh my! Really? :) Do you guys do this on every cold start? Ever try a top down fire starting technique - burns hot with very little smoke; seems like a perfect solution for anyone having this cold plug issue.
    CTYank, Horkn and bobdog2o02 like this.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    It only happens to me on REALLY cold nights (20deg and under) from a dead cold stove with really high barometric pressure. I almost always burn top down, but even then its not enough when the draft is running the wrong way, i know its going to happen when i open the loading door and cold air is falling out of the stove. Thats when i know to get the propane torch up the flue, the torch is always handy, its hat i use to light the stove always.
    Horkn, B_Williams and CNE deer like this.
  12. CNE deer
    CNE deer
    ohio
    I'm getting a torch to warm things up from now on, usally newspaper works for me
  13. CNE deer
    CNE deer
    ohio
    Do you think a micro torch would work?
  14. Deano31
    Deano31
    I just use a cheap box store torch head with the click start so no match needed and the cheap colmen tanks I only have to do it like bob dog said and only on my basement stove no need ever on my living room stove
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Horkn and Deano31 like this.
  16. Deano31
    Deano31
  17. B_Williams
    B_Williams
    Maryland
    I know the feeling. I've tried top down fires and they didn't work for me. Heck, I've tried a heat gun and torch, too. They didn't heat the chimney enough to reverse the draft. With a cold stove and cold temperatures outside (not even super cold), there's a strong gust of cold air when I open the stove door. Newspaper on top of the baffle engulfed in flames (with a torch) works for me. Otherwise the basement just gets filled with smoke. Vaseline on cotton balls, placed on the baffle works when it's a little warm out but it takes forever.
  18. Deano31
    Deano31
    Vaseline on cotton balls never heard of that one hey what ever works for your set up
  19. B_Williams
    B_Williams
    Maryland
    Yeah. They burn for a good while with no smoke. They seemed to work for those 40-50 degree days and a cold stove. They don't do a thing for real cold.
    I think the reverse draft is just a big issue for basement stoves, especially those with external chimneys like mine...
  20. bushpilot
    bushpilot
    Eastern Washington
    Never had it happen. That said, it will now probably happen before the weekend is over.
