Pellet Stove Top Feeder Fire YoYo Effect. Do this happen in your stove?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 31, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    See video of fire growing to a nice flame and then going down to red wood pellet coals.
    This is a 1997 Lopi Pioneer Bay fire YoYo effect.
    This may be extreme and seems like there maybe room for some improvement?
    Did you see this in your stove and what did you do to improve it?
    i.e. Change the auger bearing or the control panel?
  2. CleanFire
    CleanFire
    Don, flame looks good - it appears to be starving for fuel in the burnpot, at that combustion air rate.
    * I can duplicate that same condition here, by trimming pellet feed rate at a given combustion blower RPM (air rate).
    (How to fix on the Lopi, don't have a clue.)
  3. CleanFire
    CleanFire
  4. don2222
    don2222
    Salem NH
  5. CleanFire
    CleanFire
    It's a nice looking stove Don - I can see why you would want to rehab / upgrade the Pioneer.
    Even though it may be 'aesthetically unpleasing', that burn pattern is very efficient (running 'lean'), and providing enough material remains in the fire pot so the flame doesn't go out, it shouldn't cause any issues running like that.
    * On the Francesca here, a 'top-fed' stove, there is always -some- variation with flame: depending on auger feed rate, air rate, and pellet length / quality.. This burn pattern is more apparent on lower feed rates on the stove here.
    So some flame cycling is 'normal' here, I think you will find as you tweak air and/or fuel, it will lengthen that cycle time accordingly.
  6. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    The yo yo thing is pretty much it.
    Our Whits do it, especially after a complete cleaning.
    It's more pronounced until the stove gets hot and a good bed of coals builds up.
    Still though the fire ebbs and flows with the cycle of the fuel drop.
    A higher setting (less time between drops) helps, but then the stove will melt :bug:
  7. don2222
    don2222
    Salem NH
    Hello
    I decreased the damper as much as I could
    Should it be better than this on Medium heat when the YoYo effect is low?
  8. don2222
    don2222
    Salem NH
    Hello
    Do you think a dirty auger and nasty dirty auger bearing and an auger motor with skinny mini magnetic plates contributed to this yo-yo fire effect?
    Will a buffed up clean auger, new hi quality GA auger motor and new hi temp nylon auger bearing help keep the fire from smoldering?
    See pics
    Pic 1 - Control panel heat setting shown on medium heat level
    Pic 2 - dirty auger and old tired auger motor
    Pic 3 - Dirty auger top
    Pic 4 - Dirty auger bottom
    Pic 5 - Dirty Bronze bearing
    Pic 6 - Old dirty auger motor with only a few magnetic plates
    Pic 7 - New high temperature nylon auger bearing in end plate
    Pic 8 - New auger motor, bearing and clean buffed out auger installed!
  9. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    If all that squaring and jigging does not help, NOTHING will.
    Looks great Don
  10. DexterDay
    That is a lot of airflow for that little pot and little stove (little feed per turn of auger).
    I'd say it's spot on, but if the air can be slowed? That will help tremendously!
    It has a great burn as it is. But to much air.. which burns your bed down to quick.
  11. don2222
    don2222
    Salem NH
    Hi Dexter
    Cleaning up the auger and beefing up the auger motor and bearing keeps the fire from smoldering.
    Still has some yo-yo effect which is fairly normal according to the general consensus
    See pic below after new auger motor and bearing
  12. Snowy Rivers
    Snowy Rivers
    Newberg, Oregon
    Install a speed controller in the feed to the draft fan and adjust it into the sweet spot.
    Buttttt, if you are going to sell it these thing are generally waaaaayyyy too much thinking for most folks.
  13. don2222
    don2222
    Salem NH
    Great idea Snowy. I would do it if I keep it as mine.
    The good news is my new helper is building a corner hearth for my new workshop since I do not have the time!
