Great day in Stihl land
Discussion in 'Chainsaws and Power Equipment' started by Smoketr1973, Jan 31, 2016.
  1. Smoketr1973
    Smoketr1973
    Vinemount, Ontario, Canada
    image.jpeg image.jpeg image.jpeg image.jpeg After much thought and reading tons of reviews I pulled the trigger on a new Stihl MS 362 with M-tronic. I wasen't really in the market for a new saw, but my cutting partner squashed his 044 a couple weeks ago and needed a new saw, so I sold him my MS 360 Pro, which has been a great saw for me and will be missed. He is 80 and the lighter weight and decomp valve works well for him. I will post up some pics in the future of the poor 044, which he gave to me as a project. Anyway, my first impressions of the saw are very good. I put one tank of gas through today and it ran like a champ. 4 pulls to get it started cold, settled down quickly and idled smooth. Revs came up quick and after a dozen cuts at 1/2 to 3/4 throttle it really started to settle in. The manual says up to 15 tanks for full break in, so I will reluctantly stay out of wide open throttle for a few more tanks. I put the saw down to pile rounds, so maybe 5 minutes of not running, then 1 easy pull to start.
    A few changes from the 361 like captive bar nuts, master control and of course the M-tronic. On a side note it turned out to be a better looking saw than what the Stihl catalog shows. I am used to the split cover on my 441 and 660, but this one looks pretty good. I will keep everyone posted on the performance as I have a bit of cutting ahead of me.
  2. Canadian border VT
  3. pantelis
    pantelis
    Europe
    What is this ( mark with red ) is a rubber or something ??
    MasterMech likes this.
  4. Smoketr1973
    Smoketr1973
    That's what I thought to, but it's hard plastic molded to the body. Seems to reduce the size of the sprocket cover
    pantelis likes this.
  5. MasterMech
    Huh, now that you mention it, that looks like the new clutch cover from the latest "spy photos".
    pantelis and Horkn like this.
  6. MasterMech
    E-Gator eh? Been awhile since I've seen one of those. How's that treatin ya?
    concretegrazer and Horkn like this.
  7. Horkn
    Beautiful saw!
    Break it in right, though. You can do full throttle, just don't do it for more than 15 second at a time. The old way was to do that, then blip the throttle a few times. Now with m tronic, that probably doesn't need to be done.
    That's how the newer efi 2 stroke sleds are. They specifically won't go all out on timing until a certain hour amount has been hit. Sleds will also add oil more at break in period via the electronic oil injection, but these are all premix saws.
  8. concretegrazer
    concretegrazer
    Southwest MO
    Looks like the new version huh.
    LinkedXJ, Horkn and pantelis like this.
  9. MasterMech
    In regards to new saw break-in.....
    Do not be afraid of WOT. Just refrain from WOT with no-load. Stick it in the wood, hold it to the rug. Best break-in routine for a saw.
    Remember, these little engines are all ball/needle-bearing these days. The only sliding contact is the piston/ring(s) on the cylinder wall. And the best thing for them is moderate-heavy load (NOT excessive lugging) and avoiding extremely high speeds. Plus, the newer M-Tronic and AutoTune saws do most of their adjusting only at WOT.
    To summarize:
    Running the saw at WOT under moderate load will:
    -Promote proper seating of the piston rings to the cylinder wall.
    -Allow the electronic fuel delivery systems to adjust the tune appropriately.
    -Put a stupid grin on your face as you enjoy the new saw. :saw::saw::saw:
  10. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Horkn likes this.
  11. CoreyB
    CoreyB
    South east iowa
    Very cool. I would love to see a video of that in action.
  12. cnice_37
    cnice_37
    Nice, new clutch cover makes the awesomeness over the top.
    Horkn likes this.
  13. Elderthewelder
    Elderthewelder
    Washington State
    yep, the cover on my 362CM looks nothing like that
    bear_hunter and Horkn like this.
  14. pantelis
    pantelis
    Europe
    Yeah i remeber something for about new ms 462 , what a bulls....... is this new cover , they cut the magnesium and they put plastic or rubber to make the saw lighter
    what new verion and bull........ the same saw with a diferent sprocket cover , even and the culinder is the same but they chainge the fins to 45 degrees , nothing new here .
    new version for me means new cylinders , carbs, coils and technology, no i take the cover and from orange i paint it black
  15. pantelis
    pantelis
    Europe
    You dont impressed is the same saw
  16. concretegrazer
    concretegrazer
    Southwest MO
    Have you been in one? It's definitely lighter from what I've read.
    Horkn likes this.
  17. pantelis
    pantelis
    Europe
    how much 100grams ? :rofl: :lol::rofl: :lol: this mean new version ? lighter means 30% off of the weight with the same power , or how are you after 8 hours of use .
  18. walt
    walt
    north central ohio
    Nice looking saw!
    Elvisss222 and Horkn like this.
  19. Smoketr1973
    Smoketr1973
    Thanks to everybody for the engine break-in information. Since this is the last new saw I will most likely ever purchase, I want to make sure I do it right. I've attached some pictures of the 044. I would love to find the parts to get it back together for my cutting partner. He's 80 and going strong, but the sun is probably setting on this wood cutting days and this was the only saw that he ever owned. I've done the internet searches and come up empty except for the aftermarket stuff from Hong Kong. Any ideas would be appreciated. image.jpeg image.jpeg image.jpeg image.jpeg image.jpeg
  20. MasterMech
    OEM parts are available, but new Stihl OEM stuff is pretty much dealer-only. Every once in awhile however, you can find what you need on eBay. Your best bet is to look for a parts saw or post a "wanted" ad here and other saw forums. The 044 is not a rare model and is well-liked. I'm sure someone has what you're after.
    Horkn and mike bayerl like this.
