My Stove Arrived!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Jan 30, 2016.
  1. Bob Blunt
    Bob Blunt
    upstate new york
    Kimberly congratulations on your new stove. Please , Please, Please make sure you have a working smoke detector in your home !! Your comfort of your new stove is second to your safety.
  2. Babaganoosh
    Babaganoosh
    Jersey Shore
    And CO detector.
    I really like the 10 year ones they have out now. No batteries to forget about, buy, or change.
  3. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I don't have a CO detector. I don't know if the Fire Department has CO detectors like they do smoke. I have put off getting one because of the cost. However, I did see that Lowe's has one for around $20.00. The stove has an outside air connector but I have not cut the hole in the wall for it and I don't know how you go about it; what connection pipe to use, what goes in the wall, etc.
    Well Seasoned and Eric VW like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I am going to finish unwrapping the stove today so I can inspect it properly and will take more photos to share. I have read on here on the FHC about new stoves off-gassing as the paint cures from use of the stove. Is this a concern? Should I do some small burns outside first or is a box fan in the window enough to pull out any such fumes created?
    Eric VW likes this.
  5. mattjm1017
    mattjm1017
    When I first got my stove I just opened the windows in the stove room and started out with the burning. It smelled a bit but with the windows open and a fan blowing out it wasnt terrible and the smell was pretty much gone by bed time. It did take a couple of fires to finally get that smell burned off completely but it never drove us out of the house. I do recall several people on here that have done the burn in fires outside but again thats all a matter of preference. I hope you can get it installed soon and that the smell isnt to terrible for you.
    Eric VW and Scotty Overkill like this.
  6. Sean
    Sean
    We had ours installed in the house without doing any burns outside. The smell will drive you nuts and all the windows will have to be open so best not to start this process just before bed. If you have the means to do one outside feel free. It will save your house from some of the inevitable stink. Start with a small fire like a kindling fire and let it go out. You know its time to fire it up again when you can comfortably rest your hand on the stove top. The next fire should have some bigger pieces (not to big) on the kindling so you reach a higher temperature than the first go around and let it go out again. Use your hand as a gauge. The third fire can be a decent sized one. This will allow the paint to cure on the stove and will also drive the moisture out of your bricks. You may find that you keep smelling the "hot smell" for some time as your stove reaches a new high temperature. I smelled it on and off through the first season. Looking forward to seeing the install pics!
  7. Scotty Overkill
    The stove looks beautiful, can't wait to see it installed!
    Make sure you follow all the manufacturers guidelines to a TEE. The oak is a pretty easy install, I used all metal pipe for mine, including a metal flex pipe.
    WeldrDave, Sean and Eric VW like this.
  8. WeldrDave
    Congratulations Kimberly! We want fire pics!!!:ithappened::cool:…. Nice Stove!
    Eric VW likes this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    I unwrapped the stove this afternoon. Here is a photo of the stove and one of the firebox.
    milleo, HarvestMan, Brad38 and 9 others like this.
  10. Eric VW
    Brings a tear to my eye- who doesn't love a new stove pic?:tears:
    :thumbs:
  11. Kimberly
    Kimberly
    The Kangaroo State
    The question remains; "How am I going to get it inside?"
    Eric VW likes this.
  12. wildwest
    Removing firebrick and door and bringing them in separately will help. I have shimmied a heavy stove on two fence poles like a rail if that gives you any ideas, then use the ramp you are building?
    milleo, WeldrDave, Mag Craft and 2 others like this.
  13. Mag Craft
    Very nice stove. I really like the large glass window in the door. I love to watch the flames as I benefit from the heat.
    milleo, WeldrDave, papadave and 2 others like this.
  14. Eric VW
    Hmmmm...seems like I've heard that somewhere:whistle:
    My Stove Arrived! | Firewood Hoarders Club
    Leaving the stove attached to the pallet would lend itself to using some log or pipe "rollers."
    I'll say this, hearth install, chimney install, stove install, by one woman/person is poised to be considered epic!:thumbs:
    Maybe a GTG at Kim's place to celebrate her success?!:yes:
    It would be better of course if we were there to help w/ the above....
    Stay safe, lady Kim.
  15. wildwest
    :yes::p:dex:
    milleo, papadave and Eric VW like this.
  16. Eric VW
    Nice edit....
    :thumbs:
  17. wildwest
    I think you meant, great minds think alike:thumbs:
    Eric VW and Mag Craft like this.
  18. Kimberly
    Kimberly
    The Kangaroo State
    I am very resourceful.
    Eric VW likes this.
  19. firecracker_77
    firecracker_77
    IL
    You'll do great. Looks like you have wood stacked, so you have the most important part covered. Dry fuel!!!
  20. WeldrDave
    Or an Old stove also….
    Eric VW and yooperdave like this.
