New Muffler for a 1996 MTD 20 Ton Splitter H/V 5 HP
Discussion in 'Chainsaws and Power Equipment' started by thewoodlands, Jan 25, 2016.
  1. thewoodlands
    thewoodlands
    The old one finally developed a hole in it so I want to replace it, they gave me a replacement number of BS 691969, is this the correct one?
    I looked at a video of someone changing out a newer style muffler, are there any videos on changing out the old ones.
    What can I expect when taking off the old one?
    Briggs & Stratton Super Lo-Tone Muffler - 691969
    I'll get a picture tomorrow of the one that's on it.
  2. Barcroftb
    Barcroftb
    The Mitten
  3. Horkn
  4. Horkn
    Well Seasoned and thewoodlands like this.
  5. Horkn
    So basically you either have a screw in type, with pipe threads, or a 2 bolt flange with a gasket.
    Report back and we'll walk you through it. :)
  6. thewoodlands
    thewoodlands
    Thanks Horkn, I'll get a picture tomorrow and post it.
    clemsonfor and Well Seasoned like this.
  7. Horkn
    You may even have both types of mounts.
  8. MasterMech
    Take the old one off first. If you snap a bolt off in the block, buy a pipe thread muffler. If not, go with the super lo-tone.
    clemsonfor, thewoodlands and Horkn like this.
  9. thewoodlands
    thewoodlands
    I went in today and bought the muffler from the Wood Chop Shop, I also picked up some Anti-Seize for the new studs.
    I sprayed the old studs with some PB Blaster which I'll do again tonight and another shot tomorrow morning.
    clemsonfor and Horkn like this.
  10. thewoodlands
    thewoodlands
    Here's a couple pictures of the old muffler and the new one I bought. In pictures 9822 & 23, it looks like you have your choice of what part you want to put on the face of the muffler.
    If I choose the one that shoots the exhaust straight out, is there any other difference in the two, will one make your engine run cooler?
  11. Oldman47
    Oldman47
    Illinois
    Every air flow restriction or change of direction will reduce power a tiny amount because it takes power to move the exhaust though a more convoluted path. If the exhaust is properly "tuned" to the engine at operating speed the effect may be none at all. Exhaust tuning is something we seldom address on things like a chain saw except when you are running a race engine. Ever wonder why those race engines have a large expansion chamber on their exhausts?
    clemsonfor and thewoodlands like this.
  12. Horkn
    On a 2 stroke, those expansion chambers are for a little different reason. A 2 stoke will puff back, because it has no real valves in the head. A 4 stroke has intake and exhaust valves that don't allow back flow. It's the whole 4 cycle vs 2 cycle thing.
    You won't see expansion chambers on a 4 stroke.
    Back to thewoodlands question though, try them both out. There one with the diverter can be used to keep hot exhaust away from the components of whatever the motor is used on. That diverter can also be used to keep water from flowing into the motor or muffler during a rain storm.
  13. MasterMech
    Blow the exhaust whichever way suits your needs. On a 5hp flat-head Briggs, restricting the exhaust a tad isn't the first thing holding that engine back. On a log splitter, you'd be hard pressed to notice any performance variations but you sure will appreciate less noise.
    clemsonfor, Horkn and Barcroftb like this.
  14. thewoodlands
    thewoodlands
    Well 1 for 2 is good when hitting in baseball, the first bolt broke and the second came out real nice, I have the new muffler on it with the new bolt stuck inside the hole where the bolt broke off and the other one holding down the fort.
    It seems fine when running it but the Wood Chop Shop is hunting down a threaded muffler, B & S don't make them any more.
  15. thewoodlands
    thewoodlands
  16. Horkn
    135200 is listed as a fit. It should fit. Just be mindful of carbon in the threads. You could always try removing the broken stud from the head.
    I think it's literally just a pipe thread.
  17. thewoodlands
    thewoodlands
    I even heated it up with a torch, it won't budge.
  18. Horkn
    That sucks. At least there's a secondary way to mount a muffler.
    clemsonfor likes this.
  19. MasterMech
    Drill it. Start with a SHARP bit, maybe 1/8" and work your way up in 2-3 steps. When you get close to the diameter of the bolt shank, step up to the helicoil drill size and drill it for a helicoil.
    If the end of the broken bolt isn't somewhat flat, touch it with tip of a grinder and center punch it before drilling.
  20. clemsonfor
    Try an easy out maybe? But I doubt that will work since its seized
    Horkn likes this.
