Anybody know what this vine is?
Discussion in 'The Wood Pile' started by Shurdel, Jan 25, 2016.
  1. ID1
    ID1
    N.E. Ohio
    PI, I have them here that big ! I could build furniture out of it !
  2. TurboDiesel
    not sure i'd want to sit on that furniture!!!:bug:
  3. ID1
    ID1
    N.E. Ohio
    Give it to someone that you don"t like!:dancer:
  4. TurboDiesel
    :faint:
  5. ID1
    ID1
    N.E. Ohio
  6. Backwoods Savage
    Yes, PI. It has grown there for a long, long time. We see some like that around here on the big white oaks by creeks and rivers.
  7. Backwoods Savage
    It will grow inside the woods but yes, it is much more prominent near the edges and along creeks and rivers.
  8. fox9988
    fox9988
    NW Arkansas 72717
  9. Oldman47
    Oldman47
    Illinois
    To me it definitely looks like what we call PI around here although the previous post shows a map that would mean it is really poison oak. In my wood lot I see whole vast areas of PI growing as a short ground cover plant in cleared areas that is maybe 2 or 3 feet tall but when it grows next to a tree it looks just like that first picture and so far I have seen it as large as 4 inches in diameter. It is even larger diameter than the wild grape vines in the same area.
  10. Flamestead
    Flamestead
    Windsor County, VT
    I'm itching just reading this! We get just the tamer ground-cover variety. My wife clears it from under the cattle fence using the string trimmer and isn't affected. I look at it and get it.
    1964 262 6 and wildwest like this.
  11. TurboDiesel
    Me too
    mostly cause I have had PI for about the last 2 weeks. :headbang:
  12. Dascro
    Dascro
    Southwest PA
    We have some poison ivy here as big as the vine pictured. I removed some from a tree I felled last fall and threw it into a burn pile full of other brush. Any issues with burning it outdoors in a brush pile?
  13. TurboDiesel
    YES
    your neighbors will hate you if they get it easy!!!!!
    you can get it from the smoke
  14. JCMC
    JCMC
    Just outside of Shushan, NY
    Don't breathe any of the smoke.
  15. Oldman47
    Oldman47
    Illinois
    Go get that stuff out of your burn pile. I do not react to PI at all but even I would never burn any. You could seriously harm any neighbors down wind if they get even a whiff of the smoke.
  16. Eric VW
    I came to see the difference between the two by the shape of the leaves... Especially around here. More PO than PI....
    Like so many other seeds/berries that birds eat....they must poop sooner or later, and have a knack at doing their business on the fence row- PI growing right next to my wild asparagus picking areas. Both got their starts exiting a bird.
  17. buckman84
    buckman84
    North carolina
    Got in some last year sawing logs,my buddy turned me on to this stuff called tecnu poison ivy and oak scrub. That stuff really works. Beats anything else I've used. I think cvs or Walgreen's carries it. Just a little tip.
  18. Dascro
    Dascro
    Southwest PA
    Thank you for the wise counsel. I've been around PI all my life but have never been affected by it. And I didn't know the smoke can be harmful. Thanks again.
  19. chris
    Pi reaction in the lungs can be deadly-
    Deacon and Backwoods Savage like this.
  20. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    If you want to do some research, look up woodbine vine, or virginia creeper. Parthenocissus quinquefolia - Wikipedia, the free encyclopedia
    This stuff is odd, it does not effect everyone, and in the past it did not bother me. This last two summers I have got into this and I have to say it is awful. The oils from this plant will adhere almost to your boots and clothing, such that the next time you wear them it can hit you again. Your skin will get small lumps of liquid, that contain the oil. If you scratch open the little sac, it will spread further. One of my feet was blistered and scabbed for close to two months since I would wake up itching..... As others have mentioned, the smoke is poisonous, so burning it is not a good option. Nasty crap, so be careful
    NH mountain man and 1964 262 6 like this.
