Warmest gloves?
Discussion in 'The Wood Pile' started by sherwood, Jan 24, 2016.
  1. sherwood
    sherwood
    What are your recommendations for the warmest gloves?
  2. NYCountry
    NYCountry
    Mohegan Lake NY
    I use my frosty grip gloves, they are pretty good and you get a good grip on tools and so on..
    Horkn likes this.
  3. MightyWhitey
    MightyWhitey
  4. DaveGunter
    DaveGunter
    NH mountain man and 1964 262 6 like this.
  5. Oldman47
    Oldman47
    Illinois
    Snowmobile gloves.
    1964 262 6 and Mitch Newton like this.
  6. Locust Post
    The ones that have been laying close to the woodstove all night
  7. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    These used to be warm until I got too close to the Fiskars. :faint:
  8. savemoney
    I had to give up on gloves, couldn't get them on with my arthritis. Painful as all heck. Then got some knitted mittens. They slide on easily without the pain.
  9. CTYank
    CTYank
    CT Panhandle
    For temps above freezing, Atlas Therma Fit ($3-4/pr). Lower temps- Memphis Ninja Ice ($5/pr). Both have indestructible latex palms, with great grip, and elastic cuff. Way tougher & cheaper than any leather gloves I've seen. Firewooding tears up leather gloves, IME.
  10. Horkn
    They'd also probably stay drier than leather gloves in the snow.
    I'll have to look for those ninja ice gloves.
    1964 262 6 likes this.
  11. CTYank
    CTYank
    CT Panhandle
    They sure do, but you gradually moisten their innards with sweat. They're cheap enough to carry a second pair, to switch off. The Atlas gloves, I buy by the dozen- ought to last me almost forever.
    1964 262 6, Chvymn99 and Horkn like this.
  12. sherwood
    sherwood
    I need these for a relative in Nebraska who is extremely sensitive to cold and has had an awful problem with sensitive skin since birth, so what I am looking for is warm ( as in 30 below rated) gloves for active outdoor use, but not necessarily handling lots of firewood....though firewood gloves would be fine. I seem to remember North of the Border or Gasifier having some that he recommended last year that were very durable and warm. Expensive doesn't matter too much, because I anticipate that with the usage they will get they will last a long time. He does not have a wood stove but does a lot outside. Thanks for the present suggestions. I agree about mittens, but he needs gloves.
    For any of you who may be knitters, a really warm mitten is made by knitting with two balls of yarn, holding one yarn in each hand and knitting alternating stitches with alternating yarns, long gauntlet, and then once you get into the palm thrumming...and if you want really warm and have a pet with warm fur, thrumming with the fur removed when brushing your dog.
  13. NH_Wood
    NH_Wood
    I've switched to Altlas gloves too - blue for warmer temps and thermafit gray for colder temps - definitely last a lot longer than leather for handling wood and the grip and fit are great.
    OP - are you looking for the warmest work gloves for doing wood, etc., in the winter, or just the warmest gloves for being outside in the cold? Cheers!
  14. Chopy
    Chopy
    Upstate NY
    I found that if you put Mechanic's gloves that can be purchased at any Auto parts store (a hundred pair for around $14.00) inside a good pair of gloves it doesn't matter who's gloves or what they are made of your hands will stay warm and able to move freely. Another trick I remember from being a kid and playing in the snow was to put plastic bags in between two pairs of socks on your feet. When you get wet it gets cold real fast, the plastic and mechanics gloves keep your skin dry and your body heat in.
  15. mike bayerl
    mike bayerl
    Good advice so far. Definitely go with mittens not gloves. Take a look at outdoors / snowmobile sites. I like Primaloft or similar insulation. Go with something simple, and lots of insulation.
  16. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    My wife got me some snow blower gloves that are rubber and lined. I can't believe how warm they are and waterproof.
  17. DaveGunter
    DaveGunter
    I'm sure there are some heated products available too.
    My wife makes little palm sized fabric bags and fills them with uncooked rice that I heat in the microwave and carry in my coat pocket when it is very cold, the heat doesn't last a long time but it works pretty well.
    1964 262 6 and Chopy like this.
  18. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  19. Canadian border VT
    Depending on skin sensitivity, my warmest are sheepskin outside sleep wool insidenmittens .. Have skied Jay peak at 45 below hands were warm.. If skin prevents natural snowmobile gloves are rated that low easy..
  20. bassJAM
    bassJAM
    Cincinnati, OH
    For working outside I wear a pair of Atlas Therma Fit gloves with a cheap mil-spec wool liner. The nice thing about using that is sweat and moisture don't affect the warmth a whole lot because of the wool. Like others have said, I've found that leather soaks up moisture and doesn't hold up for that long but those latex dipped gloves are pretty awesome.
    1964 262 6 and CTYank like this.
