Absolute Steel Hybrid
Discussion in 'Modern EPA Stoves and Fireplaces' started by Flamestead, Jan 23, 2016.
  1. Flamestead
    Flamestead
    Windsor County, VT
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Bags, colin.p, TurboDiesel and 5 others like this.
  3. Flamestead
    Flamestead
    Windsor County, VT
  4. HarvestMan
    HarvestMan
    Southeastern Michigan
    Why does he suck? Is Flamestead the winner of the AS?
    Canadian border VT, Horkn and Eric VW like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    That little sneaky peek... OF ONLY THE LEGS.
  6. Flamestead
    Flamestead
    Windsor County, VT
  7. bobdog2o02
    bobdog2o02
    Drury Lane, PA
  8. Flamestead
    Flamestead
    Windsor County, VT
    Nothing visible to show yet...
    Cleaning, before moving to make way...
  9. concretegrazer
    concretegrazer
    Southwest MO
    :heidi:
    Horkn likes this.
  10. HarvestMan
    HarvestMan
    Flamestead , are you a beta tester? Must be since they are not certified yet. I would like to see pictures of the inside and how you access the cat, etc.
  11. HarvestMan
    HarvestMan
    After a couple minutes of thought, I'm with bobdog2o02 ... You Suck! Not because you have one but because you are teasing us with it. :hair:
  12. Beet Stix
    Beet Stix
    NW Ohio
    If I do recall..... he has pulled this stunt once before ;)
    Canadian border VT and Eric VW like this.
  13. Beet Stix
    Beet Stix
    NW Ohio
  14. Flamestead
    Flamestead
    Windsor County, VT
    Gosh, we get so used to instant gratification!
  15. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Your still sucking, damm box.
    Horkn, Gark and papadave like this.
  16. Flamestead
    Flamestead
    Windsor County, VT
    No, not the winner. This is a beta...
  17. Flamestead
    Flamestead
    Windsor County, VT
    :rolleyes: Good memory!
    Horkn likes this.
  18. Flamestead
    Flamestead
    Windsor County, VT
    A couple of quick pics before a fire. It has been burned before, at Woodstock, but I suspect we will hit some new high temps and get some paint smell. Luckily a very understanding wife. Her verdict is she she thinks she likes it better than the IS (smaller, side-load).
  19. HarvestMan
    HarvestMan
    How deep is the firebox floor from bottom of load door? Picture makes it look quite shallow.
    Smoke flow is a bit confusing from the picture of the cat, can you give some explanation?
    Thanks.
    p.s. I take back the You Suck comment. :D
    Horkn and papadave like this.
  20. mattjm1017
    mattjm1017
