Installed insulation around my wood stove. . Wow!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Allen Lee, Jan 21, 2016.
  1. Allen Lee
    Allen Lee
    California
    Hey everyone, I finally installed insulation around my wood stove and I can not believe how much better the stove heats! I have a Century cw 2900 wood stove insert, this insert is just put into my fireplace with no liner, I have been running it for about a month and it really hasn't been heating all that well, using a lot of wood and really only heating the room it's in to about 67-69 degrees with the fan on when we were home manning it and during the day and night the house temperature would drop to 64 degrees (our heater was set to 64 degrees) we also loaded the stove full about 6 times a day, I took this as normal operation because I have never had a wood stove but my buddy asked if I had insulated between the insert and the original fireplace opening, I had not, not thinking it would make a difference I put it off but a few nights ago I decided to go get some roxul r 15 and boy did that make a difference! A huge difference! Now I see what's so awesome about a wood stove, that first night our house temp rose about 5 degrees in 30 mins! I was shocked, now our house stays a comfortable 72 degrees all day and all night, with no fan on and today we only put a total of 6 splits of oak in it! No need for more wood right now, beings it's only getting down to 46 degrees outside tonight. Anyways just wanted to share my story with you all! Loving the wood heat!!!!! :) since this is all new to me I wanted to get your guys input on what is "normal" right now with the house staying at 72 all day and night our chimney above the mantel is warm to the touch, with an infrared thermometer it measures about 100 degrees, this is definitely helping to warm the house by radiating heat but I am wondering if it is normal for it to be 100 degrees?
    [​IMG][​IMG][​IMG][​IMG]
    ^^picture of the roxul r15 insulation in place between the wood stove and original fireplace opening
    milleo, BCPLLC, savemoney and 8 others like this.
  2. jeff_t
    jeff_t
    SE MI
    I've read similar results in other threads.
    Does 'no liner' mean no 6" liner in the chimney?
    Horkn, wildwest and Allen Lee like this.
  3. JA600L
    JA600L
    Lancaster, Pa
    100 degrees is perfectly normal. My hearths seem to run a little hotter then that yet.
  4. papadave
    Considering our body temp is 98.6, I'm thinkin' 100 isn't even remotely concerning.
    savemoney, Horkn, Eric VW and 3 others like this.
  5. cnice_37
    cnice_37
    As a test, I put some leftover Roxul on my insert top, after I did the block off plate install (also insulated on top.)
    The smell of that Roxul directly on the hot wood stove was too unpleasant. I ditched it after a couple of weeks.
  6. Allen Lee
    Allen Lee
    California
    Correct, just an open chimney
    Horkn and wildwest like this.
  7. jeff_t
    jeff_t
    SE MI
    Yikes.
    Do you know the safety and performance advantages of a proper liner?
    bobdog2o02, Horkn, Eric VW and 3 others like this.
  8. papadave
    AKA...."slammer"
    bobdog2o02, Horkn, Eric VW and 2 others like this.
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    Block off plate?
  10. Allen Lee
    Allen Lee
    California
    Not at this time. Just the wood stove shoved in the fireplace and insulated with roxul. Planning on installing a liner w block off plate before next winter
    fox9988, Horkn, Eric VW and 3 others like this.
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    Well, that makes sense then. Your open chimney was vacuuming heat out of your house, but the insulation has slowed that down.
  12. Allen Lee
    Allen Lee
    California
    Yep! That's what I concluded aswell. It's awesome!
  13. Backwoods Savage
    Realizing when most people shower the water temperature is well over 100 degrees, no worries! You'll be even happier when this is completed but we're happy you have found the big problem and are able to heat the home now. We keep our home to 80 and sometimes warmer!
  14. Allen Lee
    Allen Lee
    California
    Awesome! Where do you live? I am in northern california
    Horkn, Eric VW and Backwoods Savage like this.
  15. Backwoods Savage
    Mid Michigan.
    Horkn, Eric VW and Allen Lee like this.
  16. Allen Lee
    Allen Lee
    California
    Ahh so a little colder there I presume. Lol
  17. Backwoods Savage
    You might say, just a bit. :rofl: :lol:
  18. Locust Post
    I think you would be much happier if you at least put a short piece of stove pipe off the top up into the chimney.
    Allen Lee, Horkn and papadave like this.
  19. Horkn
    Yeah, he's in the Sacramento area. Big difference in temperatures....
  20. schlot
    schlot
    NW Iowa
    Great improvement to the old open fireplace indeed!
