Husqvarna 262xp Rebuild
Discussion in 'Chainsaws and Power Equipment' started by HoneyFuzz, Jan 21, 2016.
  1. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I wasn't gonna do a thread on this...but why not..took a bunch of pics to jog my memory ....so might as well share !
    So this is my cousins 262xp. He was given it as a gift..brand new..long time ago. . He cleared his property..and cut a crap ton of firewood with it over the years. So just this past fall....his gas cans got mixed up...and this old girl got the straight gas treatment :( He said he ran 2 tanks through it before he realized it. So.....I told him no problem...I can help ! So....tore it down...Luckily...no bottom end damage....but it transfered some of the piston onto the cylinder :( So after alot of cleaning.... Alot of emery cloth...scotch bright...and Old040's help....I got the old cylinder in decent shape. Only some small stuff on the exhaust side that I couldn't get as good as I wanted...so fingers crossed ! Fast forward past all the cleaning and disasembly....to today. Assembly time ! New Meteor piston assembly....even sprung for this new handy dandy ring compressor kit ! I highly recommend...it worked awesome !
    Stinny, RJames, pantelis and 3 others like this.
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Using this compressor kit is sooo easy..and handy !
    This pic was after I lubed up the crank bearings...lower rod bearing...upper rod bearing and piston pin ! After the pic..the piston....ring...and cylinder got lubed up nicely !!! IMG_20160121_165230640.jpg IMG_20160121_165139843.jpg
  3. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Did I mention..that this ring compressor kit is a must ? :). So easy...a fella like me can use it ! IMG_20160121_170801415.jpg
    Coming together nnicely.....back in my comfort zone !! P.S...been emailing and sending pics to Old040 this whole time...so he could help keep me on the right track ! Thanks again buddy !! IMG_20160121_182325445.jpg
    CTYank, foragefarmer, Stinny and 7 others like this.
  4. Warped5
    Warped5
    Northwest IN
    I'm liking this!
    Especially the CLEAN work area.
  5. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Looking good ! All went back together nicely. Learned alot ! Definetly so much better to have a buddy online.....and everything supper clean for assembly ! IMG_20160121_185203478.jpg
  6. Warped5
    Warped5
    Northwest IN
    Wow are those parts clean ..
    150 PSI? Did you use a base gasket?
    HoneyFuzz likes this.
  7. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Guess what.....fired up in about 8 pulls !
    Running good so far ! Let it idle about 5 minutes or so..blipped the throttle a tad...seems good ! But that's it for tonight. Hope compression goes up in a few tanks ! I'm a happy camper !
    Replaced ....
    Piston/rings
    Fuel line and filter
    The complete gas tank vent assembly
    Gas cap
    Spark plug
    Still need..
    New sprocket
    Recoil pull rope.
    Also used high temp woodstove paint to freshen up the muffler !
    Maybe some action shots tommorow ?!?!
    Fun project..now on to the 350 !!! IMG_20160121_185230129.jpg IMG_20160121_185237426.jpg
    CTYank, foragefarmer, Stinny and 3 others like this.
  8. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Too clean lol ! Almost hated to use that shiny piston !!! I did use a base gasket...I was told that the 262xp has to have one..unless machine work is done to the cylinder . But I never checked squish...cuz I don't know how ....but hope to soon !
    Barcroftb likes this.
  9. Warped5
    Warped5
    Northwest IN
    Dude, that's weak.
    .... especially since Mark was helping you ...
    You can take material off the bottom of the cyl with sandpaper and a piece of glass. I got my first one down to .020/.020/.020/.021 very easily.
    Barcroftb and HoneyFuzz like this.
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I think he was keeping it simple stupid for my first build lol !! I'd rather try new stuff on my own saws ! I'm hoping for 150 to 160 after break in ..... that will make me happy ! That's a good trick though ...I'm curious to learn more about it.
    Baby Steps lo! !
  11. Warped5
    Warped5
    Northwest IN
    If ya do enough digging on these forums, you will find out how to test squish using solder and grease.
    I dropped the base gasket and sanded the cyl on my first 262 and got 175PSI before it ever ran. Is much stronger now.
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I would definitely love to do another one of these...try out some new tricks !
    I'm glad this one stayed simple....gave me a boost of confidence. Which I needed !
    Canadian border VT and Barcroftb like this.
  13. Warped5
    Warped5
    Northwest IN
    Very good!
    In the bigger picture, good on ya for helping out your cousin!
  14. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Hey thanks ! I appreciate that !
  15. DexterDay
    Nice thread Fuzz!! Good on ya for helping out!! Nice saw too!!
    Barcroftb, Eric VW and HoneyFuzz like this.
  16. Eric VW
    Nice work HoneyFuzz ....
    How's the 266se? Ya didn't sell it, did ya?:rofl: :lol:
  17. old 040
    old 040
    Buckeye State
    I felt the same on the comp reading, by the time fuzz got to that point I was already lay'n low for the evening, pretty sure Fuzz didn't check the squish, so we'll both have to get together and see what's up with the compression....may also be a bad decomp valve
  18. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Still got it ! Shes a strong old girl ;)
    Eric VW likes this.
  19. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Running really well ! Still holding about 150 psi after two tanks...so I may have to look into this ..... IMG_20160122_090835185_HDR.jpg
    And yes...I tightened the chain after the pic lol !
  20. concretegrazer
    concretegrazer
    Southwest MO
    Nicely done hf!
    old 040, Eric VW, BIG DOG and 2 others like this.
