first time portin...
Discussion in 'Chainsaws and Power Equipment' started by R.Singletary, Jan 19, 2016.
  1. R.Singletary
    R.Singletary
    ca
    Thank you fur the info input...I seen several vids on this part and it looks pretty straight forward...but I don't have a mic gauge...but hope to get one in the spring when I go back to work with a few other tools I would like too get....thank you...
  2. mdavlee
    mdavlee
    The intake can be squared and lowered if needed to get that nick out. I've never seen a 372 family that can't be ran without the gasket. It will net about 15 lbs in compression. The exhaust port shape looks good. The upper transfers are where the big gains are. The blue coils from a 346 go to 14.1k rpm and work well for most ported 372 and 390s.
  3. R.Singletary
    R.Singletary
    ca
    Thank you fur the input...so if I take out the nick and bevel the edge a bit...and polished the exhaust and intake with out doin anything else to it...it should improve performance a little...
  4. mdavlee
    mdavlee
    You don't want to polish the intake all the way to 220. I go to 80 grit and that's it. The rougher it is the better fuel atomizes to vapor. You'll gain more with a muffler mod and gasket delete than just polishing the ports.
  5. R.Singletary
    R.Singletary
    ca
    Thank you fur your input...I will rough up the intake more...I already did a muffler mod...what is a gasket delete?... Is it not usin the cylinder gasket...thank you...
    Horkn, clemsonfor and mdavlee like this.
  6. mdavlee
    mdavlee
    Using a sealer for the base gasket to tighten squish. Motoseal, Yamabond, three bond, loctite 518 or permatex equivalent.
    Horkn, HoneyFuzz and R.Singletary like this.
  7. R.Singletary
    R.Singletary
    ca
    Thank you fur the input...but if I run with out the base gasket...won't I have to find out the sqish and change the timin...thank you...
  8. millermodsaws
    millermodsaws
    Hi Mike! :)
  9. mdavlee
    mdavlee
    It changes it 1 degree. I've not seen one too tight but it won't hurt to check. Yellow plastigauge can also be used.
  10. mdavlee
    mdavlee
    :dremel:
    Hey Carl:saw:
    Horkn, MasterMech, clemsonfor and 2 others like this.
  11. R.Singletary
    R.Singletary
    ca
    Thank you fur the input...I will try it...thank you...
  12. mdavlee
    mdavlee
    If you have any more questions ask away.
  13. cwn877
    cwn877
    Central Pa
    How do you guys determine the numbers for opening and closing of the ports on a saw that you have never done before? I would suppose changing those numbers would be like changing a cam in a 4 stroke.
    clemsonfor and bobdog2o02 like this.
  14. Scotty Overkill
    One of the easiest mods to do on a modern saw and gives you a pretty noticeable "bang for your buck" is customizing the muffler (dual port) and tuning the saw once the muffler is modded.
    The whole goal of porting in any aspect is to get the saw to breathe better, both in and out....
    Horkn, clemsonfor, HoneyFuzz and 4 others like this.
  15. mdavlee
    mdavlee
    Top of exhaust and transfer openings and the bottom of the intake is where you read them. Then they can be turned into durations or left as 97° from TDC for exhaust and so on.
    Horkn, clemsonfor and R.Singletary like this.
  16. cwn877
    cwn877
    Central Pa
    Is it mostly done when you cut the base and lower the cylinder to bring them back to where they were or is it more for duration and beneficial even if the base is left alone?
    R.Singletary likes this.
  17. mdavlee
    mdavlee
    Some can be changed some without machine work. Most really need it after machine work though.
    Horkn and R.Singletary like this.
  18. cwn877
    cwn877
    Central Pa
    Ok thanks I had been wandering about what all factored in. Now what determines when it's time for finger ports?
  19. R.Singletary
    R.Singletary
    ca
    Thank you fur the input...I do have a few more...as the jug sets right do you think I could put it on my saw and see a positive result after I remove the bur on the wall? What grit sand paper should I use to remove it with? At the bottom of the jug...at the transfer ports...would it be OK to clean that area up and polish them...what about the lip at the transfer ports...should I remove any of that or wait till I get the tools to measure the ports...thank you...
  20. mdavlee
    mdavlee
    I only raise that window about 1/8" after dropping the jug. Look at the base gasket and you'll see where the case opens. You can smooth and blend the edges. Just hog the ducts out.
