Removing a stuck pellet stove cleanout cap with tools that work?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 3, 2016.
  1. don2222
    don2222
    Salem NH
    Hello
    Anyone else have this problem sometimes?
    Some caps are much easier to remove than others since they vary in type but quality as well.
    The common Duravent caps must be turned counterclockwise before it can be pulled off and sometimes that is the most difficult part to do!
    I tried using an oil filter wrench which sounded like a good idea but in reality, I had absolutely no luck with it!
    So a friend who is an HVAC man by trade got a really stuck cap off with very large gas pliers! ISeeing it work is believing! I also found these vise grip oil wrench pliers that work.
    Of course I have found that spraying PB Blaster into the seam makes a huge difference and going back an forth until you can move it fully counterclockwise does help too.
    Before putting the cap back on, some "Dry Moly Spray" can make the job easier in the future.
    I prefer a Selkirk Vacuum Cleanout that can be a little quicker and easier in the long run.
    Click pics to Enlarge:
    Russell, CleanFire and wildwest like this.
  2. imacman
    imacman
    Denver, NC
    Don, Dry Moly is not the be all, end all. The best solution is probably a thin coating of Never Seize around the entire flange and locking "lugs" and "channels" on the corresponding parts. I used this method for the last 3 years I had a stove, and I removed the cap just with my hands.
    CleanFire, kappel15 and IHATEPROPANE like this.
  3. funflyer
    funflyer
    Central Arizona
    Thankfully I don't have to use any of the things you mentioned, most are just greasy kids stuff anyway. Pliers on anything flexible and round is never a good idea and will just make things worse for the next removal/install. I'd use a strap wrench with either a cloth or rubber strap to make sure that even pressure is applied around the cap. If at first the cap doesn't rotate, reposition the wrench and try again. I'd also never spray anything on the vent or cap but use a 0000 steel wool to smooth all the joints before assembly then install and remove each one several times to ensure they can be easily removed in the future without tools.
    If you feel the need for a cleanout "T", for heven sake install it outside so all that crap will stay outside when you feel the need to remove the cap for cleaning.
    Me? I made sure to not use a cleanout "T" and terminated the vent chest high so I can walk up with my trusty leaf vacuum and send all that ash crap up and out and throughout the neighborhood.
    Sorry, but after 32 years of working on jets I learned to do things the best and most simple way...now, it's time for more bourbon.
    Russell, CleanFire, kappel15 and 2 others like this.
  4. don2222
    don2222
    Salem NH
    Oh yes I agree, that never sieze is good stuff too. What ever works!
    CleanFire and IHATEPROPANE like this.
  5. kappel15
    kappel15
    I use rubber strap wrenches on all pipe fittings. And the high temp anti-seize grease on the cleanout caps. Never have had an issue. kap
  6. StEarl
    StEarl
    millinocket, maine
    the excel cap has always been an easy hand job for me.
  7. eatonpcat
    Russell, artc, smoke show and 5 others like this.
  8. imacman
    imacman
    Denver, NC
    :picard: :bug:
    Russell, gbreda, CleanFire and 2 others like this.
  9. jtakeman
    I use a strap wrench on tee caps. I also use some copper never seize........
    One of these days I'll try adding a vac adapter to the tee cap on my duravent pipe. Shouldn't be impossible to do.......
    Russell, CleanFire and kappel15 like this.
  10. Lousyweather
    Lousyweather
    :DICC end caps.....a dream.....no unscrewing, just a thumbscrew, a bar, and the tab lifts off.......I love ICC
    gbreda, CleanFire and jtakeman like this.
  11. don2222
    don2222
    Salem NH
    Let us know how you make out on the vac cleanout. All you need is some iron pipe? Could be an easy job?
  12. jtakeman
    I'll post some pic's here if I do.
    What size is the pipe? Assuming its 1" NPT, But never have seen one in person. I suppose 1 1/4" could be used as well.
    CleanFire likes this.
  13. krooser
    krooser
    Waupaca, WI
    I had a GF like that...
    imacman, eatonpcat, jtakeman and 2 others like this.
  14. jtakeman
    Slapped ya in the head and made your eye's bug out? :whistle:
    imacman and gbreda like this.
  15. gbreda
    gbreda
    NH
    artc, imacman and eatonpcat like this.
  16. gbreda
    gbreda
    NH
    :yes:
    imacman likes this.
  17. don2222
    don2222
    Salem NH
    Hello
    I had a good test today. I had to add more pipe to some pellet vent to bring it above the roof line.
    To connect to the existing pipe I had to remove a piece that looked easy but it was RTVed and really tough!
    So I pulled out the 3" Vise Grip Wrench and Voila! Also no damage!
    See pics, click to enlarge:
    Wilbur Feral likes this.
  18. kappel15
    kappel15
  19. imacman
    imacman
    Denver, NC
    No need to RTV pipe together on outdoor pieces. But another place that would benefit from Never-Seize.
  20. don2222
    don2222
    Salem NH
    X2, but I see it all!
