  1. CleanFire
    CleanFire
    NICE speeds Smokey, you did a great job upgrading there, fully 10x faster than the DSL here. :yes: (Latency & Jitter look very good/excellent, for streaming video, with QoS, over wireless.)
    The whole attempt-to-repair is as much for the Boss vs. anything else - she (we) really like this washer, and it was a multi-day store marathon to find this one some 10 years ago.. But she knows & agrees, we're not spending more than $125 in parts to attempt to rehab, anything more just isn't cost effective vs. moving onto a new unit. ( That still gives me some wiggle room, in case I need to replace the Thrust bearing on the lower transmission assembly, or the motor drive pulley. Those parts are bookmarked / ready to be ordered, if needed)
    * One thing I do need to do is snake the washer drain line back to the Stack, to make sure there isn't any lint or slime plug restricting water flow in the P-trap or at the stack outlet (given the condition of the hoses & Drain Pump), that's tomorrow's job.
    That's great news ivanhoe - Congrats on the repair! :yes:
    Your son did great, that's a nice looking insert there Snowy! , Good luck w/ the CL sale, that insert deserves a good home. :yes:
    It's gotten much colder here, stove is running 1.6 / 1.8 lbs / hr. (settings 3 and 4) - 1.8 lb/hr is the (Max.) LG Granules/CF Pacific can run in the Francesca here w/o clogging the burn pot quickly, but so far, so good - back to running 16-18 hrs. / shutting down / cleaning / rinse, lather, repeat.
    Off to the Dollar Store to pickup some "inexpensive" cleaning tools & supplies, then off to work.
    Have a great day all !
    savemoney, bogieb, ivanhoe and 3 others like this.
  2. imacman
    imacman
    Denver, NC
    No pressure regulator on you water inlet line??
    As for the gaskets and hard water, I have VERY hard water here (well). I run white vinegar w/o any clothes on small load setting every 2-3 months....so far, so good. Kinda like cleaning the coffee pot w/ vinegar. There is also a cleaner you can buy at the BB or grocery store called "Affresh". Recommended by Whirlpool to be used once every 30 or so washes.
    wildwest, Ambient, CleanFire and 4 others like this.
  3. will711
    will711
    Pocono Mts.
    First day back at work and of coarse it's cold and going to dip to single numbers tonight :shiver::shiver::shiver: . Took down all the Xmas decorations that I put up before I went on vacation all put away for another year . House is nice an toasty and the smoothies are super cold :cheers:
  4. imacman
    imacman
    Denver, NC
    Haven't done mine in a while either:
  5. will711
    will711
    Pocono Mts.
    I just tested mine ,I pay for 10 Mbps down load and it clocked in at 12.5 I'm getting what I pay for :thumbs:
  6. wildwest
    10.37 and .78
    eatonpcat, CleanFire, bogieb and 2 others like this.
  7. IHATEPROPANE
    IHATEPROPANE
    This is my speeds through the wireless router measured on my phone.
    wildwest, CleanFire, bogieb and 2 others like this.
  8. imacman
    imacman
    Denver, NC
    Seems like real good upload for a phone. The speeds I posted above are also wireless from my desktop. I could get even better speed, but would have to run an ethernet cable through a wall, etc. Too much of a PITA.
  9. will711
    will711
    Pocono Mts.
    Very Fast
    wildwest, CleanFire, ivanhoe and 2 others like this.
  10. IHATEPROPANE
    IHATEPROPANE
    Have you checked out the units that send wireless through your home electrical wiring? I bought one, a low end unit, and it works great. I get around 30 in a room where the wireless signal drops to about the high terms or so and was choppy at times
    Here is the LTE from ATT speeds on my phone:
    wildwest, CleanFire and ivanhoe like this.
  11. imacman
    imacman
    Denver, NC
    Wow, never thought to that on my phone.....this is what I got using Optimum site.....almost exactly the same as my other post:
  12. imacman
    imacman
    Denver, NC
    No, didn't know about that......maybe you can send me a link to that? ;)
  13. imacman
    imacman
    Denver, NC
    On another topic, the temps here have dropped off the table. Was 34* this afternoon......14* right now. :shiver:
    wildwest, gbreda, CleanFire and 4 others like this.
  14. jtakeman
    Ohhh crap, I liked that and I shouldn't have! :headbang:
    :doh:
    wildwest, gbreda, CleanFire and 2 others like this.
  15. IHATEPROPANE
    IHATEPROPANE
  16. imacman
    imacman
    Denver, NC
    You can click "unlike" if you want.....it's OK. :(
    wildwest, ivanhoe, CleanFire and 2 others like this.
  17. bogieb
    Don't have to use HE soap - I haven't and I've been thru 3 front loaders (the last one I left with the Ex and got a new one for myself). Just have to use very little regular detergent. A lot cheaper that way. Didn't know about the water pressure thing though and thankfully have never had that problem.
  18. jtakeman
    Might have too, Many many times! JK!!
    :p
  19. imacman
    imacman
    Denver, NC
    wildwest, ivanhoe and CleanFire like this.
  20. IHATEPROPANE
    IHATEPROPANE
    Not sure about the details exactly but my router and the room that I have the "receiver" are on different circuit breakers.
