Loose Screw in center of IS secondary baffle?
Discussion in 'Modern EPA Stoves and Fireplaces' started by NVhunter, Jan 3, 2016.
  1. NVhunter
    NVhunter
    Northern Nevada
    So after breaking in the stove and then having a good three day runner on the stove I let it cool today as I saw the center screw in the secondary baffle was protruding about a 1/4" out from the baffle.
    I put on my gloves and tried to hand tighten it but it just spins and moves up and down and doesn't seem to be threaded into anything, but it's still staying put in the baffle.
    What's going on here?
    How do I tighten this screw?
    Can I access it from the cat area of the stove?
    Thanks
    Mike
  2. CoachSchaller
    CoachSchaller
    Southeast Michigan
    the bolt is there to keep the baffle from warping downward. It is designed/common for the baffle to raise up in the center due to heat. Mine is at least half an inch. However, I have never tried to tighten it, so I do not know if it should be loose...
  3. Maineidealsteel
    Maineidealsteel
    Northern Maine
    I contacted Woodstock when i first got my stove about this. That bolt is supposed to be that way to allow for expansion and contraction.
  4. Canadian border VT
    I thought about contacting Woodstock but it was in thread ideal steel tips... uh I guess IDK how to post threads..
  5. NVhunter
    NVhunter
    Northern Nevada
    Thanks guys! Was worried a little and it kept me up last night thinking and wondering how I was going to access it
    to tighten it.
    It looks and sounds like it's fixed in the position its in and won't come out at all but can't be tightened either.
    Mike
  6. JA600L
    JA600L
    Lancaster, Pa
    You are correct. Nothing to worry about. I may be way off but I think I remember seeing a picture of the nut with a cotter pin. I can't remember why I think that. ..
    NVhunter likes this.
