Wet Wood
Discussion in 'The Wood Pile' started by bogydave, Dec 31, 2015.
  1. bogydave
    Neighbor built a splitter , no wood heat but loves the out door fire pit fires
    Other neighbor did some tree clearing last couple years & has some birch & cottonwood in 4' lengths
    He's been getting a load in his atv every day or so.
    Went over to see his splitter
    Ram on a beam & a separate hyd pump & valve. Work well for his needs :yes:
    Can see water around the wedge on the semi punky birch oozing out of the wood
    Wet stuff, 2 years old & pretty punky, in 4' lengths bark on.
    Deacon, basod, HDRock and 9 others like this.
  2. MightyWhitey
    MightyWhitey
    And someone suggested "education" a little bit ago.......................
  3. Horkn
    Education = wet wood doesn't burn for chit.
    gboutdoors and Woodsnwoods like this.
  4. bogydave
    Be good fire pit wood next year .
    Next year is tomorrow :D
    Deacon, basod, HDRock and 6 others like this.
  5. Horkn
    That'll do right, next year is now.
    I have a feeling I'll be sleeping in tomorrow. Gooder
    gboutdoors, Woodsnwoods and Chvymn99 like this.
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    i wish there was an easy and quick way to Debark logs before piling them. They dry so very well and avoid this wet wood problem.
  7. Backwoods Savage
    Yes, birch in 4' logs and not split; prescription for punky wood.
    basod and Horkn like this.
  8. Horkn
    There's reason Native Americans used birch bark for canoes. It won't let water in, or out.
    Birch rounds go punky unless split at least in half.
    They'll keep pretty much indefinitely if at least split in half though. I ran across a yule log project in the cottage basement that was a 8 ft cut in half paper birch. The wood was solid, and from cub scouts. When I was a cub scout. So probably over 30 yrs old.
    It's faarwood now. :thumbs:
    Backwoods Savage, J1m and Eric VW like this.
  9. Sean
    Sean
    I bet she burns real hot! I wonder if you would even get a ready if you used a moisture meter on it?
  10. Horkn
    I left my meter at home. It would've read something though. My guess is high single digits. There's a theory here that if the wood is not dust, it will not be much below a certain percentage on the mm.
  11. Sean
    Sean
    I would agree with you on that. Ive had some pine that wouldnt pick up a reading. Even if the meter doesnt show anything the reality is that there is still moisture in the wood. Also in my scenario most moisture meters need a calibration adjustment when it comes to wood like pine so even if Im reading 8% it might actually be closer to 13%.
    Backwoods Savage and Horkn like this.
  12. Horkn
    My ryobi can be switched from pine, oak, and then a generic hardwood setting. I've monkeyed with it enough to know that there's a difference in readings between the settings when using the mm in the same piece without moving the prongs at all.
    Backwoods Savage and Sean like this.
  13. Sean
    Sean
    I didnt know you can get one with different settings. Ill have to look into that when my current one wears out. Thanks!
    Horkn likes this.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Yea, it would say 35%, the high limit.....
  15. Horkn
    It is the ryobi phoneworx moisture meter. Home depot carries them. $30, uh ses Android or ios. They are sweet. You can take pictures of the wood, and it will record date and time, relative humidity, as well as the MC. You can label them and sort the pictures and readings.
    Ryobi, Phone Works Moisture Meter, ES3000 at The Home Depot - Mobile
    Sean and bobdog2o02 like this.
  16. Horkn
    He was referring to the dried 30 year birch half log I found in the basement. ;)
    Sean likes this.
  17. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    I thought he meant the stuff in the thread topic.... sorry. Only one way to find out.... Pics or it didnt happen.
    Sean likes this.
  18. Horkn
    No pics, but it happened.:D
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    and the mc wassssssss
