Handlebar resto with heat shrink tube
Discussion in 'Chainsaws and Power Equipment' started by stackowood, May 5, 2015.
  1. stackowood
    stackowood
    Oregon
    I read some comments about using heat shrink tube for handle bar wrap (hose) and here are the results I had on an old Jonsered 630 handle.
    I picked up two different shrink tubes at the electrical wholesale house and tried a small section of both to see which one worked the best.
    Beat up old handle:
    New tubing:
    I ended up using the "Canusa" 1.1" heavy wall tube. The printing will come right off with a little carb cleaner on a rag. This stuff doesn't like to go around corners so you have to work it on:
    Start heating at the center, and work your way to the ends. You have to stretch it a bit to keep it from getting rippled. Once it is shrunk, trim the ends and it looks like this:
    The stuff gets thicker as it shrinks so it makes a nice handle cover that is hard to tell from the original. Not bad for the first one, and I'm sure there are some tricks to learn.
  2. Warped5
    Warped5
    Northwest IN
    Nice!
    The topic of alternative bar coverings has been hit on before.
    Heat-shrink was one option presented, but I've never seen anyone do it yet. This looks very good!
    Bert, Horkn, clemsonfor and 3 others like this.
  3. stackowood
    stackowood
    Oregon
    Thanks, it turned out OK.
    Forgot to mention- cost - it was $37 (wholesale) for a 48" long piece of tube, which is enough to do 2 bars. The 3M version is only $21 but it has a thick coating of glue on the inside, a thinner wall, and just didn't seem to shrink as well.
    Moparmyway, Bert, Horkn and 2 others like this.
  4. $ooline
    $ooline
    WI
    IMO any aluminum handlebar with hose or shrinkwrap tubing on it is 10 x better than a composite or plastic handle(stihl u listening...? )..they might not be as strong, or as light but it just seems to have a better feel. Well done stacks.
    Bert, Horkn, clemsonfor and 1 other person like this.
  5. prell 73
    prell 73
    ia
    That's a cool option
    Bert, Horkn and Eric VW like this.
  6. NH_Wood
    NH_Wood
    Looks great - nice work! Cheers!
  7. dgeesaman
    dgeesaman
    Elizabethtown, PA
    Did you use the tubing with the adhesive inside?
  8. Eric VW
    I agree that the adhesive lined tube is unsat.
    Using the Canusa, you could use "spray silicone" to make sliding the tube on the handle easier. We use it on electrical cables (up to 4/0) all the time in the factory- heat and silicone spray are ok together.
    Could you wrap a fine cordage or some sort of similar thing to the handle, then apply the Heat Shrink tube over it, to incorporate some "grip"/ tactile aide?
    Bert, rookie1, Horkn and 1 other person like this.
  9. stackowood
    stackowood
    Oregon
    Will try silicone spray next time, and I'm sure that will help it slide on. Once the tubing is heated and shrunk it seems to feel a little more rubbery and is gives a pretty good grip.
  10. bogydave
    Good idea
    Got to be similar to what was originally on there.
    Filed to memory in case mine ever need replaced :)
  11. wildwest
    Nice to meet you :)
  12. DexterDay
    Very nice thread. Good info...
    Bookmarked :)
  13. Eric VW
    Right on, DexterDay!
    Horkn and DexterDay like this.
  14. Stihl Livin
    Stihl Livin
    Minnesota
    Great thread here. I just did some googling of the canusa and found it on amazon for just over 20 with shipping.
  15. angelo c
    angelo c
    People's Republic of North Jersey
  16. pantelis
    pantelis
    Europe
    Hello friend
  17. pantelis
    pantelis
    Europe
    37 dollars for a 48" heat shrink tube ?? No thanks i will buy a new oem handle bar with 25 euros
    for example husqvarna 372 handlebar
    522 42 88 01 = 25 euros
    522 48 88 02 = 32 euros full wrap
    Stihl Livin likes this.
  18. angelo c
    angelo c
    Amazon had it cheaper then the supply house... Not sure if Amazon ships to Macedonia though :(
    Also I would never re-wrap a Husky handle...they just don't last long enough to make it worth the effort, a Stihl....of course....they last for ever....:faint:
    pantelis likes this.
  19. pantelis
    pantelis
    Europe
    I never try to buy from amazon , no reason why , most of times i use the ebay
    Yeah stihl use airnautics aluminum , husqvarna use a cheapo the same like cocacola tinkers:D:rofl: :lol::rofl: :lol::rofl: :lol:
    angelo c likes this.
  20. pantelis
    pantelis
    Europe
    I like the alu handles just because you can welded them if break the plastics maybe are more strong but its a little trouble to fix them
