Drilling a hole in a bar?
Discussion in 'Chainsaws and Power Equipment' started by Beetle-Kill, Jan 4, 2014.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    My Mak. 6401 has a 24" Oregon Power-match bar. I want to put a cut-to-length gauge on the side of the bar, like Bogydave has on his saw. This bar doesn't have a predrilled hole, so any problems drilling one out? More than one hole?
    Thanks, JB
  2. charlie
    charlie
    Schoharie, NY
    Friend welded a rod onto a washer that went under the side chain cover nut.. He said that worked well... Never saw what it looked like..I'm thinking it had a 90 degree bend then welded to the washer so you can get a wrench on the nut... That bar steel has to be pretty hard stuff to drill..
    Beetle-Kill likes this.
  3. MasterMech
    Shouldn't hurt it to drill 1 hole.
    Beetle-Kill and Oliver1655 like this.
  4. bogydave
    Just clear the tip roller
    Keep oiling the bit :)
  5. Chvymn99
    I was just thinking about this the other day. Cool.... Thanks....
  6. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Personally I do not want any "accessories" hanging from my bar or the side of my saw. They are dangerous enough without adding another piece that can hang on something. If precise measurements are that important then get a Mingo Marker or make a measuring stick and mark your cuts before cutting.
    bassJAM, Oliver1655, $ooline and 7 others like this.
  7. rottiman
    Had to drill this 20" bar when I made this chop saw set-up. Secret is to drill - S L O W L Y- Oregon bars have tough steel in them. Firewood Ramblings 002.jpg
    Oliver1655, $ooline, wildwest and 7 others like this.
  8. mdavlee
    mdavlee
    I've drilled a few holes in them lately and had some cheap bits from walmart go right through in a couple seconds. I need to try to find a few more sets of them. Just make sure to use oil on the bits or some form of coolant. I used premix and it stuck to the bit great.
  9. Nixon
    Nixon
    West Sunbury,Pa .
    Just an alternative idea ,but why not just mark the bar at whatever length rounds you want ? A few years ago ,I made a marking tool out of one of those inverted marking paint wands . Just added some all thread in the length I wanted to the side of it . Worked really well when I remembered to use it .
  10. clemsonfor
    How do you buck a log with a bar screwed to your bar??? Most wood I cut uses most of my 20" bar. I'd get one of those things that told and has a can and outs a dab of spray paint every preset measurement that u secure. They have them in baileys and or northern tool.
  11. bogydave
  12. clemsonfor
    I'll watch it in a few but an 18" tree pretty much eats up a 20"er.
  13. MasterMech
    Could always mark the log, drop the measuring stick and then make your cuts.
  14. bogydave
    I did that one year
    Had a lot of short sticks. LOL. :)
  15. Guido Salvage
    Guido Salvage
    Short of a Mingo Marker this is the way to go. Just get a 1" x 2" furring strip and mark off the lengths. Had an old guy cutting timber once that used the crossbar off a high jump pit to mark his log lengths. Anything that limits the full use of the bar is a no go for me.
    Oliver1655, nate, Nixon and 1 other person like this.
  16. charlie
    charlie
    Schoharie, NY
    I cut by eye, always within an inch of what I want.. The Esse takes a 19 inch piece and the PH takes a 22 , so 16-17-18 works for me...
    Dynomite, nate and thistle like this.
  17. clemsonfor
    I was thinking the rod was mid bar and could not figure it out. Makes sense now. Still I could not really do it on less than a 24" bar I cut a good bit of 18" stuff
  18. bogydave
    Gotta be anal like me & want 17" splits +\- 1/2".
    17 " work perfect for the stove
    With out a good way to mark the I'd get a mix of
    15 to 20" rounds.
    Only on the bar when needed. Quick on & off.
    Sometimes on the small saw & I walk down the log & mark it.
    Then cut the log to lengths I can skid out to the truck.
    No shorties
  19. DexterDay
    I use a piece of an old Yard stick. Cut to 18".
    Makes all my rounds the same length. Use the stick and a paint stick or can of old paint you are not using.
    clemsonfor likes this.
  20. Boog
    Boog
    Where my spirit is free
    This works for me, and I can keep two hands on the saw, don't need to hold anything else for marking . I see that "GB" already pre-drilled me a nice hole too if I wanted to use it!! :rofl: :lol:
    DexterDay likes this.
