First time cleaning the nc30 flue
Discussion in 'Modern EPA Stoves and Fireplaces' started by capetownkg, Dec 23, 2015.
  1. capetownkg
    capetownkg
    southern, MD
    Well with this crappy warm weather figured I would clean the flue and cross that off my list. So setup the sooteater and some things to capture the dust.
    Wasnt sure what to expect and not sure how good or bad the results are so you all be the judge!
    Thats all I got. Most of the white ash is from stuff in the stove and not the flue. Towards the cap is when I got some of the bigger particles come down. Sooteater system was pretty straight forward and easy to use.
    One last question. I noticed in the top corners inside my stove these two shiny marks. Anything to worry about?
    Horkn likes this.
  2. saskwoodburner
    saskwoodburner
    If I throw a dodgy piece in the back of the stove, my bricks may turn dark for a bit, but the fire takes care of it. Are you burning a bit cool or throwing marginal wood in the back? Is your baffle sitting to the back, or is some start up cold smoke sneaking in behind?
    Horkn likes this.
  3. milleo
    milleo
    I don.t think so but I am just a dummy.The stuff in the stove is not a problem...Maybe someone else will reply....:)
    Horkn likes this.
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Looks fine by me, if that looks bad you don't wanna see my princess's guts....
    Bags, concretegrazer and Horkn like this.
  5. Locust Post
    Not a thing to worry about there, burn on :fire:
    Horkn likes this.
  6. Horkn
    Looks good to me.
    milleo likes this.
  7. capetownkg
    capetownkg
    southern, MD
    Thanks everyone! It does give a nice bit of relief to me that I am doing it right and keeping my family safe. Very limited fires coming in the next week but hopefully the new year will bring some much needed and desired cold weather my way!
    papadave and milleo like this.
  8. papadave
    Yeah, yours is nice and clean compared to mine
  9. Highbeam
    Highbeam
    Your sooteater strings look really short. Are they long enough to wack the whole flue?
    bobdog2o02 likes this.
  10. capetownkg
    capetownkg
    southern, MD
    I did the measuring guide that was included in the instructions. Have a 6 inch flue and cut them a little longer then it called for so I think its good.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    i have found i need mine a little longer than the guide says to do a thorough job, just me.
  12. saskwoodburner
    saskwoodburner
    I don't think I'd lose any sleep over how it looks. You should see my stove glass..... Colder weather might clean it up anyways, as the same settings will draft harder when it's colder outside.
  13. bocefus78
    bocefus78
    Looks good. Check the soot eater string length after each use. It doesn't take long to wear them down. Very easy to replace with .095 or larger weed eater line.
  14. Highbeam
    Highbeam
    Yes, they wear down.
