Christmas Thread- Of the giving kind!
Discussion in 'Chainsaws and Power Equipment' started by DexterDay, Dec 14, 2015.
  1. thewoodlands
    thewoodlands
    The log gauge in my post 116 is gone.
    HDRock, Chvymn99 and Barcroftb like this.
  2. maulhead
    maulhead
    Colorado
    OK, got a few more things to give away. All of these are used parts and have signs of use, none of them are minty. None of them are cracked or broken, all are usable for a working saw. I won't be able to get them to you by the 25th, but I can get them on your door step shortly after.
    I would like to see these go to homes where they will get used, not hoarded just to have them. Don't be shy if you have a friend or family member, (that is not a FHC member) that has a saw that any of these fit on and they can put it to use, please send me a message or post here.
    # 1 HD air filter for 261c or 362c saws, I'm sure it fits other saws with the round twist lock filter
    #2 261c or 362c clutch cover with captive bar nuts. I am sure it would fit other small saws also.
    #3 Plastic clutch cover for 029/290/039/390 type saws
    #4 Cylinder cover for a 036
    HDRock, wildwest, cgraham1 and 4 others like this.
  3. cnice_37
    cnice_37
    When you gonna give away some GOOD (Husqvarna) stuff? :p:headbang:
    clemsonfor, Chvymn99 and maulhead like this.
  4. maulhead
    maulhead
    Colorado
    A few more items,
    #5 Cylinder cover, not sure what it fits, only number I find on it is "Stihl 1121" maybe 024 or 026's?
    #6 Air filter cover, not sure if it's for 064 or 066 only number on it is 1122 141 0500
    #7 Metal air filter base, not sure if it's for 064 or 066 only number on it is 1122 124 3405
    HDRock, cgraham1, Chvymn99 and 3 others like this.
  5. maulhead
    maulhead
    Colorado
    I have ONE lone Husky item, if I can find where I put it, I will post it..... :)
  6. clemsonfor
    I needed that base for an 066 about two years ago!!! Head bang!
  7. clemsonfor
    Actually that part is different now I see the pics think its just for an 064?
  8. maulhead
    maulhead
    Colorado
    Items, 1, 2, and 3 have been claimed. 4-7 still up for grabs.
  9. DexterDay
    I have swags saw here (034) that I'll be putting another 036 cylinder on. The 034 doesn't have a decomp hole. So we could use that top cover so his saw has a decomp
    Otherwise I'm gonna put a plug in it.
    Chvymn99, maulhead and clemsonfor like this.
  10. MasterMech
    As far as I know, only the 064s had the metal base. Every 066 I've seen is plastic.
  11. maulhead
    maulhead
    Colorado
    Cool, I would like to find a home for it. If you guys want it just PM me a address of where to send it.
    clemsonfor and DexterDay like this.
  12. jchin
    jchin
    Mr DexterDay, I think I may have a Stihl 036 shroud with decomp provision on it. I will look in the morning and post what I find.
    Jack
  13. jchin
    jchin
    Good morning, Mr DexterDay. Good news. I looked under the Christmas tree and found a nice Stihl 036 cylinder shroud with its Stihl metal badge nice and shiney still attached. I need to make a trip to the post office for a box and label, so I can package this item for you. I still have your home address. Merry Christmas.........
    Jack
    SquareFile, wildwest, HDRock and 9 others like this.
  14. clemsonfor
    I have a factory non DP front cover for an 066/660/650 and maybe others (064???) I will have to go look to see if it has a small dent or not...just dont remember . Once I do I will post a picture. If someone wants it. Its yours. I pulled it off when I installed a DP front.
    pantelis and wildwest like this.
  15. RJames
    RJames
    I have a 25" 3/8 .050 es bar with a loop of rs full comp. Usable as is, could use a new tip. Only used it once, then bought a 28" light so this one hangs on its nail, dreaming of a stump.
    Chain is all over the place, short/long cutters but I'll put a razor edge on and lower depth gauges to .025 before it ships.
    All I'm asking is that you don't get it to hoard, would like to see it get used.
    Yeah, it's ugly but then you won't be afraid to put it to work.
  16. MasterMech
    Nice RJames! I have an ugly 25" here too. I don't use it much which all the 20" and 28" stuff hanging around. But it does make for a handy test run bar when I don't feel like pulling a bat off one of my saws!
  17. Stihl Livin
    Stihl Livin
    Minnesota
    I have 9-13/64 save edge files that are new just sitting here that I'm sure someone could put to use more than me since we now have a grinder. I believe these are for 3/8 chain.
  18. MasterMech
    Yes, they are the recommended size for 3/8" Stihl chain. Both RS and RM.
  19. clemsonfor
    Nice gift for someone!!! Mine looks about like that..maybe a little worse. It was a tree service bar and I think it was run with some dull chains as a ground saw. My tip has a bit missing from it as well but serviceable as is. If I didnt have one I use id snatch that up. Good gift for someone!! In time for the new year!!
    wildwest and Barcroftb like this.
  20. RJames
    RJames
    Bar and chain spoken for.
    Hopefully it gets to eat some wood at its new home.
    Merry Christmas!
