Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. maulhead
    maulhead
    Colorado
    Lil junk in the trunk,,
    guy said after running 4 tanks threw it he decided it was way more saw then what he needed, and went back to the stihler and bought a ms251....
  2. clemsonfor
    What!!!! Nice find! Who would want to run a 251 over a 461???
    Shawn Curry, unclefess and maulhead like this.
  3. maulhead
    maulhead
    Colorado
    crazy huh?
    I am glad that 461 was too much for him :) :)
    It came with a 25" bar & chain, carring case, a NIB spare 25" chain, manual & tool kit.
  4. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    This is the SP-81 that I found in a box in my garage that I did not recall buying. A generous member on Another Site sent me the roller nose bar. I will need to spin up a chain for it.
  5. MasterMech
    :loco: :crazy:
    I could see picking up a 241/261 but a 251? :picard:
  6. concretegrazer
    concretegrazer
    Southwest MO
    Probably couldn't decide between those two. So he went with the one in the middle.;)
  7. clemsonfor
    Still wouldnt want a 241 or 261 over a 461!!
    maulhead likes this.
  8. MasterMech
    There are many days that I would. Especially the 241. That thing takes apart treetops like the little animal it is and is real easy on the operator.
    Barcroftb, maulhead, Ronaldo and 2 others like this.
  9. clemsonfor
    Yea if were just talking tree tops but I dont cut up just tree tops. Sounds like this guy is a one saw guy. Rather have a 70cc and heft the weight in the tops than to fall asleep cutting 20" rounds with a small saw.
    maulhead, cgraham1 and thistle like this.
  10. concretegrazer
    concretegrazer
    Southwest MO
    Ain't no falling asleep running my 261 through a 20".:banana:
  11. clemsonfor
    Well its not a stock 261 then
  12. thistle
    thistle
    Polk/Guthrie Counties,IA
    Took a few minutes this afternoon & cleaned up some odds & ends.Roughed out a few more Mulberry woodturning blanks,trimmed defects off some lower grade Black Walnut,Black Cherry & Spruce logs.Remainder went to scrap pile,plus a bit of mulch. :D
    Much more exciting using a 20" or shorter bar on a 82cc saw than a longer one.:dex: Job is done quicker also cause of higher RPM's:yes:
    Just realized I hadn't run ANY saw since cutting up that dead Bur Oak at parent's place the first Saturday in November...:emb::saw:
  13. DexterDay
    Even a stock 261 is a good saw for 20"
    maulhead, Chvymn99 and MasterMech like this.
  14. clemsonfor
    Not the 026 I have used. That husky 555 I have is probably pretty close in power and no way I would want to use it on 20+" oak as a main firewood saw. I am too impatient.
    maulhead and thistle like this.
  15. cgraham1
    cgraham1
    Nor Cal
  16. clemsonfor
    Are those bottle kill trees? Wind throw? And what are the tree shelters protecting them from? There so few saplings in shelters?
  17. DexterDay
    Bottle killed? Wind throw? Your phone must be on the Fritz again...
  18. clemsonfor
    Beetle is what it should say. But yes I meant to say "wind throw" thats the proper term.
    I think I have figured out the problem?? I am not sure if tap a talk is more laggy or something but it seems to be worse when I post from tap a talk which j have been since we got it here. And in the last few months these typos seem to be getting worse? Least thats what it seems like to me.
  19. MasterMech
    Usually the problem sits between the drivers seat and the steering wheel. :rofl: :lol: :p
    261 is a very different animal than the 026. If you don't like a 20" on your 555 then you ain't gonna like it on the 261 for sure, stock or not...
  20. cgraham1
    cgraham1
    Nor Cal
    That area was burned last summer, and we've been getting quite a bit of moisture here lately. I guess the ground got saturated, and that tree got knocked over by wind. Too bad, because it was one of the few remaining trees after the fire, and logging/cleanup. It actually fell right across the road.
    I bucked it up and left it for others to pick up, since green Douglas Fir is quite heavy. :D
