new husqvarna 562xp air filter concerns
Discussion in 'Chainsaws and Power Equipment' started by denny461, Dec 19, 2015.
  1. denny461
    denny461
    Scipio, indiana
    I have ran about 5 tanks through my new 562xp. I was getting my saws ready to go cut tomorrow and noticed how much dust is getting past the filter. Anyone else notice this.
    clemsonfor likes this.
  2. denny461
    denny461
    Scipio, indiana
  3. J.Walker
    J.Walker
    Bristol,NY.
    I had the same problem with my 562xpg. Been using some grease around the horn of the carb before seating the air filter.
    Horkn likes this.
  4. denny461
    denny461
    Scipio, indiana
    Just a light coat of all purpose grease?
    Horkn likes this.
  5. J.Walker
    J.Walker
    Bristol,NY.
    I use the bar tip grease that comes with a saw.
    I read somewhere that teflon tape wrapped around the horn worked good too!
    Chvymn99, clemsonfor and Horkn like this.
  6. denny461
    denny461
    Scipio, indiana
    I like the Teflon tape. Shame that this saw doesn't have the filtration my 394xp has the dirt and dust never even gets to the filter.
    clemsonfor, Horkn and J.Walker like this.
  7. MasterMech
    Somebody had some success stretching an o-ring around the horn IIRC.
    Chvymn99, clemsonfor, Horkn and 2 others like this.
  8. snide
    snide
    central il
    I tried the grease, doesn't seem to help much
  9. Horkn
    Sounds like a poor design if it doesn't seal properly.
    How long has this saw design been around?
    pantelis and clemsonfor like this.
  10. clemsonfor
    562 would be the newest family of huskies. The 5 is the newest line. That saw i am not sure? A few years at least.
    Sounds like a crappy design to me as well.
    Horkn likes this.
  11. Birddogtg
    Birddogtg
    Central ohio
    Any air filter that is 2 pieces and snaps together can let fine dust get though,so try greasing that seam also.
    Horkn, concretegrazer and Nixon like this.
  12. pantelis
    pantelis
    Europe
    XP = extra plastic, ooohhh sorry i want to say extra performance , again my bad english you know:D
    abnemsdad, unclefess, Horkn and 2 others like this.
  13. denny461
    denny461
    Scipio, indiana
    I have always kept my air filters clean on all my saws. I pulled the filters off all my saws the 394xp and ms 461 are spotless past the filter. The 562xp and 261c-m have dust behind the filter.
    Horkn, clemsonfor and pantelis like this.
  14. pantelis
    pantelis
    Europe
    i like the older models much more than theese new lego toys with a ton of no need plastic parts that in most of cases the only that they give is a ton of problems ,
    bull......... mtronics and autotunes
    Horkn and clemsonfor like this.
  15. denny461
    denny461
    Scipio, indiana
    I can't imagine the saw lasting a long time if the filter doesn't catch the dust very well. A lot of loggers around my area say they use husqvarna because they last longer because of the filtration system. But I also here that more of them are using the 562 and liking it. I really like the saw minus the air filter.
    Horkn and snide like this.
  16. MasterMech
    Something is wrong on the 261 then as that is an excellent seal.
  17. MasterMech
    Prior to the current generation of saws, Husky really was king of filtration with their air injection systems and "High-top" filters on the pro saws. Air injection made a dramatic difference between a 372XP and an MS440/460 as far as run time between filter cleanings.
    Now that most pro saws have the same centrifugal pre-cleaning system, it comes down to the filter element itself. One-piece, rubber sealed units keep just about everything out while a two piece plastic housing with no real seal will pass the fines through the leaks, especially as it becomes partially clogged and the pressure drop across the filter becomes greater.
    tamarack, Ronaldo, Horkn and 2 others like this.
  18. pantelis
    pantelis
    Europe
    the new stihls filters are far better than the husky ( woman socks ) filters
  19. Sunfish
    Sunfish
    Success Mo
    I've not had that problem with the 562.
    Did have some fine dust getting in the old 346, but 15 years of hard use and no issues.
  20. Firewood Bandit
    Firewood Bandit
    OP, heck that's not bad. Both my 550 and 562's have had the same issue. Tried grease and o ring and that didn't help either.
    Sunfish and clemsonfor like this.
