Harman Accentra draft voltage adjustment
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Harman Heat, Jan 4, 2014.
  1. Harman Heat
    Harman Heat
    South Central Pennsylvania
    Should I have the dealer make a service call to perform a draft test on my pellet stove. I'm new to pellet stoves (last year). I changed the adjustments myself and didnt see a change with the burn pattern, the stove came set on high, turned all the way to the right.
  2. Lousyweather
    Lousyweather
    well, honest answer is maybe. In fact, the only adjustment the dealer can make is to the voltage to the combustion blower (via the potentiometer on the circuit board). This adjustment can only be accurately made with a draft meter (and a DDM would tell the tech what the voltage actually is to the fan).....without that, any adjustments you make, you are doing blind. Factory setting (which has now been changed), is generally fine. When we do an install, we take a draft reading, adjust as necessary, and record the draft reading of the new stove in the owners' manual. That way, if there is a stove issue at a later date, all the tech has to do is hook up the draft meter and compare readings....if they have change significantly, its usually a cleaning issue (about 80% of the time). Otherwise, could be a intake blockage or even a combustion fan issue.
  3. jtakeman
    You could do it yourself. Tools are going to be $$$, But still could be cheaper than a service call. You can check the volts with a simple clamp on meter. And the draft with a magnihelic gauge. I prefer to do my own DIY. But if your not as frugal or handy? Calling in a tech would be the way to go.
    eBay is where I got my gauge and Radio shack had a decent meter reasonable.
  4. Harman Heat
    Harman Heat
    The famous "Loaded Question". Well I have used it 1 1/2 years now so too late before first fire, I recorded the setting before moving it and it was turned whole way to the right and seems to be operating well. Its heating my 2000 sq ft home. Thanks for infor..
    Lousyweather likes this.
  5. Lousyweather
    Lousyweather
    good to hear, HH! Too many folks fumble with settings, dip switches, then give up and call the techs.....we have to fix the changes first.....but, I am all for folks doing their own work!
  6. DexterDay
    Welcome to the Forums Harman Heat. Glad you got it straightened out.
    Many smart members that are well versed in the Harman line. If you have any questions, do not hesitate to ask. And as always, we always like to hear from new members and see pics of your install. We love pics with fire ;)
  7. Harman Heat
    Harman Heat
    Yea thats my 2 favorite things right now... MY Stove and my dog.
    DexterDay likes this.
  8. imacman
    imacman
    Denver, NC
    First of all, welcome to the forum. Secondly, the above quote is a HINT. lol :whistle:
  9. Harman Heat
    Harman Heat
    Yea how do I fix that...
  10. DexterDay
    Take pics? Or post pics?
  11. Harman Heat
    Harman Heat
    post pics, let me try while the electric is on.. Freeeeezing rain
