Your take on the most efficient flame/burning technique in your stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by saskwoodburner, Dec 18, 2015.
  1. saskwoodburner
    saskwoodburner
    Hey guys, just wondering what your thoughts are on how the fire/flame is compared to the efficiency, kind of the most bang for your buck, and how it's related to the stove temperature. I've noticed a few different types of secondary burns with my stove.
    Ghost fire/northern lights- The stove is hot, the air is throttled back, and flames dance and whisp in the firebox without really throwing jets of flame from the tubes. A very slow burn on the edge of stalling.
    Low burn- hot stove, air throttled back, and some dancing flames, and flames jetting from the secondaries, almost appearing like it was some kind of gas burner from the tubes. In this example and above, the wood is charred but there is none or minimal flame coming directly off the wood.
    Normal burn- Some flame coming off the wood, secondaries firing nice jets, some flame and secondaries sneaking up into the channel between the baffles.
    Whoops burn- Flame everywhere in the box, in the air and off the wood, secondaries lit and spinning and roiling, flames shooting up top between the baffles. Not quite an overfire, but not what you want to do every time you load the stove.
    I'm sure there's more, so feel free to add your "I burn dis way fellers" here. Where do you run your stove, and why? Where do you think the most efficiency is (not heat)? I'll explain my preference after a few guys get 'er going, and it kind of doesn't make sense lol.
    Sorry for the wall of text, guess I have no life.o_O
    Eric VW, bushpilot and Well Seasoned like this.
  2. ranger bob
    ranger bob
    Leeburn Ontario
    Good Q. How's things in P.A.? Used to live in Nipigon in the poplar plywood mill. Lot's went from there to P.A. in the 60's. anyway, I am not a normal woodburner, or otherwise either, I am told. LOL. I don't get my knickers in a knot about how much efficiency I can squeeze out of a given amount of wood. I like clean!!! Clean as in minimal particulate effluent into the atmosphere and clean glass so we can enjoy just the sort of things you describe. the better EPA stoves are reasonably efficient, low emissions and keep glass pretty well clean all the time. We used a Napoleon 1400 for many years and it was just such a stove. Two colder than normal winters and an old stiff body led me to a wood stove shop. I was soon the owner of a cat/hybrid big heat stove. I am of the opinion (just mine let me emphasize) that they all have a place but none are perfect or for everybody. We are not destitute so price of the stove was far from the main decision driver. Just wanted a fair deal. I will say for sure it requires more skill and effort to keep the glass somewhat clean. The flame conditions you describe all take place in sequence with a cat/hybrid. Starts off going full blast then is throttled back to less flame and little secondary burn unless it is run hot. Eventually is has little flame and lot's of charcoal and then just a bit of charcoal and the cycle is repeated. Keeping the glass somewhat clean is the kicker. In order to do this the air damper must be open about a quarter of the way. The flames are not too bad for the initial 2 - 3 hours then it's CAT time primarily and forget the flame show. We both love the flame show when its on. We both love the extra heat. We both bemoan dirty glass. Our wood stove is a big part of our winter lives out in the boonies. We are just a couple of warm Canucks like you ... and truly blessed.
  3. saskwoodburner
    saskwoodburner
    Oh, things are not too bad in Prince Albert, same old place it ever was. Kind of changed in the mid eighties, and then some years back, the mill shut down, so it's not quite a booming city, if it ever was. Gateway to the north, they call it....lots of tourism/service industry and gov't jobs.
    About the flames, it's more curiousity, I won't be losing sleep over it that's for sure. I found a sweet spot that makes the temps get higher to a point, but the flue temps drop. So I'm thinking this is where the efficiency is maxing out (I'll get into that in another thread later) I run a little Englander 17-VL, so you could run this thing like those old wood or coal fired locomotives, and you still couldn't burn 4 cord in a winter. Too small a firebox!
  4. ranger bob
    ranger bob
    Leeburn Ontario
    That an awesome stove and set up. We have no flue temp capability yet. We go by the thought that cat takes off at 500-700 degrees C and keep the indicator on the stove below max and cross out fingers. We're new at the cat/hybrid game and have lots to learn as we get more into it. It's been so darn warm we have to try and keep the heat output sensible within reason. (like <90 F in the main room where we often hang out) We commented earlier today to each other that some minus 35C weather will be a good opportunity to let this baby rock and see what it is capable of. Me thinks we'll still be in T shirts. Regency calls the technology 'ecoboost. We have an ecoboost F150 also. If we like the stove I may have to change my Avitar to 'ecoboostbob' LOL. Peace Bro! good to hear from you.
    Eric VW and saskwoodburner like this.
  5. Backwoods Savage
    As far as efficiency, I'll leave those figures in the lab. But for running the stove, most stoves are made so they do not need a lot of input and that is good.
    With our stove, we have one setting we constantly go to and it will give flames until it is down to all coals. But when it is really cold outside, we then adjust the draft a bit and we get low flame but then the flame will just sort of lift off the logs and roll at the top. When this happens is when we get the most heat from the stove and also the highest stove top temperature. When we ran with the ceramic catalyst we many times had to keep watch so the stove would not overheat but it was easy to adjust so it wouldn't overheat. With the steel cat, we've not had much problem at all going over the recommended high temperature for the stove.
    As far as how much heat we get from the wood, I highly doubt one could get more. Of course the biggest key is to have good dry wood; not marginal or barely dry enough, but dry.
    As for dirty glass, I pity those who have to contend with it. We just do not get black on our glass. It just does not happen no matter how we run the stove.
    Maina, HarvestMan, Eric VW and 2 others like this.
  6. Paul bunion
    Paul bunion
    I let the appearance of what I can see or not see coming out my chimney to guide me to the point of where I'm burning clean. That dictates how the fire will be burnt. Living in the 'burbs I try to keep the smoke to a minimum. So it usually means there is a pretty active fire, what was characterized as 'normal burn' in the OP. I also use what can result in a 'whoops burn' to quickly bring it up to temp on reloads.
    Mitch Newton, Eric VW and mike bayerl like this.
  7. ranger bob
    ranger bob
    Leeburn Ontario
    Yup! Well seasoned wood and experimenting with the draft/air setting and finding the happy spot is where we're at also. At first I was not sure if the stove was getting too hot but now we've been at it for a while I think there is little chance of that at least while we're only burning half loads. If and when we hit minus 30-35 we will load it up full and then monitor things carefully until we get a feel for cold weather burning. We bought it for heat and I can say for sure - lack of heat will not be an issue with this stove.
  8. mike bayerl
    mike bayerl
    Liking this thread. Love the OP's descriptions of the various fire shows. I'm a newb this year and have been looking at the chimney for smoke and fiddling with the air all the time. So far, I've been just trying to keep the smoke out of the chimney. My humble observations are that yes, I a get all types of flames that the OP says at different times. In the beginning, I open up the air all the way to get the fire going and get the firebox up to temp. Sometimes, I get the "oops" fire, or as we call it the "gates of hell" fire. As long as it's in a coolish firebox with new wood, I don't mind it much, at least until the box gets up to temp, secondaries are lit and the wood gets a good char. Then, as we throttle back the air, we get progressively less fire off the logs (going from yellow to blue) and more secondary flames going through normal, low and "ghost" until we just have charcoal and no flame. Very fun fiddling.
    B_Williams, Eric VW and Paul bunion like this.
  9. ranger bob
    ranger bob
    Leeburn Ontario
    Correction - until gauge gets into the 500 - 700 degree F. The gauge must register to about 800 - 900 degrees F. Forgive me, we live with F and Celsius and litres and gallons and two sizes of gallons. One plus though we're no longer using pennies or one and two dollar bills. Now if our loonie would just go to par.
  10. Paul bunion
    Paul bunion
    On our first trip to Canada my wife wondered why the money was named after old Warner Brothers cartoons....Looney Tunes.
    Backwoods Savage, colin.p and Eric VW like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    I am not sure what I can add to this interesting conversation, because I cannot see my fire while burning. I just burn to minimize smoke from the Allnighter, and am looking forward to installing the 30-NC.
    But I'm watching this thread for sure! :popcorn:
    Backwoods Savage and Eric VW like this.
  12. ranger bob
    ranger bob
    Leeburn Ontario
    Cause we are! LOL.
  13. ranger bob
    ranger bob
    Leeburn Ontario
    My wife keeps asking me "where you going?" I just say to check the chimney. As soon as the temp gauge goes into the hot and ready zone the smoke is mostly gone and ... away we go. Eventually I will just 'know' its right to engage the cat.
  14. saskwoodburner
    saskwoodburner
    Secondary burning stoves are the bomb! Especially if you're a firebug....watching the flames dance is mesmerizing.
  15. ranger bob
    ranger bob
    Leeburn Ontario
    N
    Nothing better IMHO
    bushpilot and saskwoodburner like this.
  16. ranger bob
    ranger bob
    Leeburn Ontario
    I think you will love the new stove. Secondary burn on the EPA stoves is awesome.
    Sean and bushpilot like this.
  17. saskwoodburner
    saskwoodburner
    I might add, nothing better, unless it's a slow-mo video of the flames in action.
    Sean likes this.
