wood stoves
Discussion in 'Modern EPA Stoves and Fireplaces' started by NYCountry, Dec 9, 2015.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    If you were to buy any stove you wanted which one would it be and why?
  2. papadave
    One of the BKs. Probably the Ashford 30.
    Long slow burns, and the ability to crank it if needed. Less wood use in the process.
  3. fox9988
    fox9988
    NW Arkansas 72717
    I'm content. If I had to change, I'd try a Princess. I need a low/slow burn rate, 2 cuft per 24 hours is not unusual for me. 3 cuft/24 hours is about my max burn rate.
  4. Todd 2
    Todd 2
    I have wanted one of these from the first time I've seen them. They are awesome looking in person. Cook, bake goodies and warm your buns all in one. I was just thinking about one again with all the cooking and baking this Thanksgiving. I'll bet food even tastes better out of or off of one. :flipeggs::stirpot::chef:
    Great dream home stove….. But probably not the best for every day use….
    Maina, schlot, Sunfish and 7 others like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    fox9988 I too have been tempted by the dark side. I would like to try a Woodstock Hybrid or Ideal Steel. Mainly to compare to my BK Princess. I like the BK though....
  6. NYCountry
    NYCountry
    Mohegan Lake NY
    30 hours of burn time is amazing. Bk makes amazing stoves. I'm thinking about getting one and eliminating my oil tanks and furnace and only use wood for heat..I'm not sure if my wife will be ok with it. Hopefully. I would probably go with the Princess
  7. papadave
    If that had a thermostat, and a big enough firebox.......can I change my answer?
  8. NYCountry
    NYCountry
    Mohegan Lake NY
    Wow that looks awesome. Everything in one...
    Sean, papadave and Todd 2 like this.
  9. Doug
    Doug
    ohio
    I've wanted a Blaze King for a while. Still on my want list. Longer burn time and very efficient burning. But the Woodstock Stoves have caught my eye too.
    I look at burn time and efficiency.
    So when I do go to buy a new stove (won't be happening any time soon) I'll have a tough decision. Lol
  10. NYCountry
    NYCountry
    Mohegan Lake NY
    That BK King looks like a beast and it throws out some heavy duty heat. Those woodstock stoves are turning alot of heads especially with the IS and hybrids they are making..that's a tough decision
  11. papadave
    Princess, Ashford 30, and Sirocco 30 all have the same firebox, if I remember correctly.
    Turn the furnace therm. down every once in a while....maybe she won't notice.
  12. NYCountry
    NYCountry
    Mohegan Lake NY
    Ok that's good to know. The thermostat is set at 64 , it hasn't gone on because the stove gets the therm reading of 73 so it doesn't go on. I figure with another stove I wouldn't need oil at all.
  13. Backwoods Savage
    NYCountry, we've had only wood heat for over 35 years now. Has never been a problem either. We love it.
    As for the stove, we have it already! We absolutely love our Fireview.
    Maina, T-Stew, chance04 and 4 others like this.
  14. Highbeam
    Highbeam
    The princess is a different but similar size firebox than the 30 series stoves. The efficiency and emissions are a little higher with the princess.
    Even though I have the ideal stove to heat my home I would always want a furnace or other thermostatic heat source that could keep the house warm in the event of stove failure, sickness, vacation, etc.
    Other than the 8" chimney requirement, the BK king is the ideal stove. #1 stove in the world for efficiency and provides a 40 hour burn. Yes sir.
    NYCountry and bobdog2o02 like this.
  15. papadave
    I thought that was the case. Thanks for clarifying, since I was too lazy to go check.
    NYCountry likes this.
  16. Canadian border VT
    So Dennis do you not leave home for a weekend in winter? I have oil back up in case I got to go away for weekend. and hot water. Even with IS basement thermostat set to 50 to save pipes in case... otherwise would love to be wood only:D
    Maina, Backwoods Savage and Eric VW like this.
  17. clemsonfor
    First choice is BK K. Second choice was NC30 and I just bought that stove this spring. But I need to install it. Have to build a hearth and everything for it as it will be a new install.
    Canadian border VT and papadave like this.
  18. Butcher
    Butcher
    Call me stupid but....
    Sunfish, T-Stew, milleo and 1 other person like this.
  19. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    whats wrong with that, if its a real teepee then its made of animal hide, the flap in the top is open a natural chimney.....
  20. Backwoods Savage
    Not usually but have a couple times. If it doesn't get too cold we can get by but don't like to let the house get much below 50. One time we left for several days so hired a neighbor boy to come fill the stove. That was a mistake but turned out okay....barely. Got home to a frozen water pump but it must have just frozen as it took me about a minute or less to get things going again. House was pretty cold but we got the stove going nicely in time to keep from freezing ourselves. This was with our old stove; not the Fireview. Also before we added insulation and put in new doors and windows.
    Overall, it really has not caused us problems other than that one time. Not too bad for the time we've done this. But when I was still a boy I grew up with the same conditions; only wood heat. I survived it too.
    Maina, Sean, HarvestMan and 2 others like this.
