Settled on a new (to me) truck.
Discussion in 'Chainsaws and Power Equipment' started by FarmHand78, Dec 1, 2015.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
  2. FarmHand78
    FarmHand78
    South East Iowa
    Well... I was just gonna sell it as is... but then a sub contractor of mine (that owes me money) stopped in today, just so happens he has a good low mile Cummins from an 02 dodge. Might play let's make a deal and swap engines... then I'm thinking of putting a dump bed on it! We'll where it goes.
    concretegrazer and clemsonfor like this.
  3. cgraham1
    cgraham1
    Nor Cal
    Hmm. That's a different engine. I wonder how the electronics (and everything else) would work? Your '03 is a common rail.
    FarmHand78 and mdavlee like this.
  4. cgraham1
    cgraham1
    Nor Cal
    My '06 has been a pretty good truck for me. Only 91,000 miles on it so far. No way I'd spend $40-50 k on a new truck, when this one will do anything a new one will do, and it's paid off. The new ones are nicer, though. image.jpg
    And here's the last Ford I owned, and shoulda kept! Is anybody else seeing a theme here?
  5. mdavlee
    mdavlee
    The crank is the same but that's about it.
    FarmHand78 likes this.
  6. FarmHand78
    FarmHand78
    South East Iowa
    Yeah that figures, dad called and told me about it yesterday after work, hadn't had time to look into it.... thanks for the info guys!
    Certified106 likes this.
  7. FarmHand78
    FarmHand78
    South East Iowa
    White is right!
  8. ironpony
    ironpony
    Mid Ohio
    dually are only 2 inches wider on the axle length, 1 inch each side. if you get a good deal you can get a sw take off bed and standard wheels. if you did not know you would never notice.
    an 02 engine will not work in an 03, without a lot of money added.
    FarmHand78 and bobdog2o02 like this.
  9. clemsonfor
    We have white SUVs also two of them an 01 Toy Highlander and an 04 Sequoia. Both white. We both dont like white but just happens to be the vehicles everything else was right on. When you buy used you have to prioritize and often dont get everything your after.
  10. Certified106
    Certified106
    In The Hills
    Congrats on the new truck! How in the heck did you blow a Cummins up at 255,000? Was it chipped or have a bunch of mods?
    FarmHand78 and clemsonfor like this.
  11. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    And what blew? Was it one of the bad blocks? I have a good diesel shop here that saves tons of trucks from t h E junkyard.
  12. mdavlee
    mdavlee
    03 never had the 53 block. Injectors going bad can bend rods,or burn a hole in a piston. A not so expensive fix compared to a window in the block.
  13. Certified106
    Certified106
    In The Hills
    I was kind of wondering if it wasn't a bad injector melting down a piston. If that's what it was sometimes it isn't to expensive to fix.
  14. FarmHand78
    FarmHand78
    South East Iowa
    I think it's a hole in a piston... gonna have a guy look into it for us, if the rust wasn't so bad on it I wouldn't have been so kean for a different truck. It also has a few electrical gremlins... you have to set the steering wheel just right for the ac/heat blower fan to work. The bulb out light and chime will go off constantly after a rain... that will drive a guy batty on a long drive!
    Certified106 and bobdog2o02 like this.
  15. clemsonfor
    Rip that chime out!!! So when you steer the blower e constantly goes on and off? Or to turn nit on it has to be in said position?
  16. Certified106
    Certified106
    In The Hills
    Classic injector problem. I changed mine out at 1300,000 miles just so I would sleep better. So far other than rust over my fenders on the bed mine is in ok shape right now.
  17. clemsonfor
    I think at 1.3 million miles you were due for them!!! ;-)
    concretegrazer likes this.
  18. Certified106
    Certified106
    In The Hills
    I run a tune on my truck and higher fuel pressure which is harder on them and the guy I trust who works on nothing but Cummins said he recommended doing them at 150,000 miles. I figured they were cheaper than a piston and i got them at his cost.
    bobdog2o02 and clemsonfor like this.
