Any lefties around here? Stove Gloves!!
Discussion in 'Modern EPA Stoves and Fireplaces' started by Machria, Feb 13, 2015.
  1. ranger bob
    ranger bob
    Leeburn Ontario
    Me too! Lefty as can be except ... baseball, hockey, golf ... but kick football with left leg/foot. Go figure! Guess I was prime for a cat stove. LOL
  2. TurboDiesel
    Thought I'd bump this thread with an update.
    Was at tractor supply today and was looking for a product called Plasti dip.
    My Idea was to coat the finger tips of my stove gloves before I wear yet another hole in the right middle finger.
    I didn't see it, but i did find a product called Tear Mender
    I gave each finger tip a light coat and let it dry. (5 minutes)
    It dries clear and flexible.
    Also thought about taking an old glove and cutting little patches out of it and gluing them to the fingers tips of a good glove to reinforce them.
    milleo, papadave, Eric VW and 3 others like this.
  3. TurboDiesel
    Right middle finger had a little hole starting in the leather
    I'll use them for a while and see how the coating holds up.
    If this doesn't work I'll try the Plasti dip on a new pair to see if it keeps them from wearing out so quick
  4. Machria
    Machria
    Long Island, NY
    We should write to the firehose pants company and ask them to make a firehose clove for us!!
  5. Backwoods Savage
    Tim, I do hope you give us a follow up on how this works out.
    TurboDiesel likes this.
  6. TurboDiesel
    Well, it's been one day, and the small hole in the right middle finger is still sealed up...:rofl: :lol:
    Will do, Dennis :handshake:
    Actually I'm cautiously optimistic about this fix. It's very thin and flexible. We'll see how long it lasts. I may give it another thin layer to see if it helps
    Backwoods Savage and milleo like this.
  7. BDF
    BDF
    I have the fix for that: put the wounded finger between a piece of wood and the buck- block on a wood splitter. Then push the ram forward. Stop sometime after you hear someone in the neighborhood screaming (it will be you but you will not notice it is you right away). Remove hand from splitter and wait about 2 weeks for entire nail to fall off. You do not have to wait at all for easing the pain of the slinter under the nail though- you will forget about that entirely w/in about 0.000001 seconds after the ram sets your finger into the buck block spikes.
    I cannot tell how the story ends yet, new nail only about 1/2 down the fingers' quick and it has been a couple of months.
    Back on topic: I have to wear gloves while doing almost everything because brushing anything beyond a feather duster up against the exposed (Easy Boys!) quick is a new experience in feeling. Not always pain but always a real wake- up note. You cannot believe how sensitive that skin surface is.... probably why it wears a nail in the first place.
    Brian
    HDRock likes this.
  8. HDRock
    Oh yes, I do know how sensitive it is, I had two fingers at the same time with no fingernails because they were smashed so badly the doctor said the nails would not grow back right, so he pulled them off
  9. Star Gazer
    Star Gazer
    Right behind you
    I'm a lefty though when I had my left arm broken I had to learn to write and do things with my right hand. By the time the cast came off, you could almost read what I wrote right handed! :D
    As for the gloves, the only time I use any is when I'm cutting, splitting, and stacking firewood. I don't use gloves when handling firewood in the house or feeding the wood stove. The gloves I use for CSS usually end up with holes in all the fingers and both thumbs on both hands. I also split by hand which accounts for the excessive wear.
  10. Machria
    Machria
    Long Island, NY
    OUUUUUUUCH,!!!!
  11. DexterDay
    I still have several "left" hand gloves that someone can have. I believe I have 3 of them?
  12. Machria
    Machria
    Long Island, NY
    Yeah, so do the rest of us! ;) What we need is a bunch of left handers we can swap gloves with!
  13. BDF
    BDF
    And therein lies the problem; only something like 9% of the US population is left, or 'wrong' handed. So no matter how big a bunch of them you find, there will always be a much bigger bunch of right- handers around them. This varies by country though, fairly high rate of left- handedness in Canada, almost non- existent in Japan.
    Some claim left- handed people are more intelligent. Data suggests they have a higher rate of alcoholism. Now that right there is an interesting and ironic combination, at least in my opinion'. :D
    Brian
  14. Machria
    Machria
    Long Island, NY
    I wont even talk to them! :D
    chance04 likes this.
  15. chance04
    chance04
    Denton Md
  16. TurboDiesel
    Ok its been five weeks since I started this test with the Tear Mender coating on the fingers of the stove gloves.
    I wanted to see if I could extend the wear time and the short answer is...
    Yes, It Worked
    About three weeks in I gave the finger tips of the gloves another coating of the Tear Mender and last week I coated the right index finger along the side as it was showing some wear. Seems now maybe it will be the inside that wears out instead off the outside.
    The Tear mender is a very thin milky consistency and goes on very easy. It dries in just a few minutes and is clear and shiny when dry. It is just a little bit tacky just after it dries and as soon as your start to use them it turns sort of a milky grey and the tack goes away. They are still super flexible. So far none of the patches have begun to show any wear or cracking. I think now I am going to coat some of my work gloves and test them. KIMG0027.jpg
    These are very thin leather gloves similar to what I wear for work and cutting
    I have a pair that are fairly new that I will coat and test to see how long they last. I have the same problem with wearing out the middle finger, index finger and then the thumb.
    I also use Mechanix Wear gloves from AutoZone. I think a test is in order there also
    Here is the start of my glove test
    #42
    DexterDay and milleo like this.
  17. TurboDiesel
    Gave the thin leather work gloves a coat of the Tear Mender yesterday
    Went on nice and thin, dried quick and looked good.
    Headed out to work and they were just a tiny bit sticky just like I expected. After a couple minutes the sticky went away and they turned to the milky grey.
    I used them for a few hours yesterday and all day today. Apparently this leather is a little too smooth for the glue to stick. The coating has almost completely wrinkled and peeled off. I'm not giving up though, I'll try it again
