Rockwool, Where to Get It
Discussion in 'The Wood Pile' started by Ralphie Boy, Nov 30, 2015.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Anyone know where u can get roxul or rockwool in the greater Northern Kentucky/Cincinnati area? Don't want to order a pallet if it for almost $500!
  2. wfournier
    wfournier
    Western MA
    Around here Lowes carries it.
    wildwest, cnice_37 and Ralphie Boy like this.
  3. papadave
  4. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Lowes and hd and I'm guessing Menard too if you have them there....
    wildwest, Ralphie Boy and papadave like this.
  5. Norky
    Norky
    I think I got mine at HD. I could be wrong, but I seem to remember paying about $40 for it. A little goes a long way. I filled the void in my chimney with it and still have 2 big bags of it left.
  6. Oldman47
    Oldman47
    Illinois
    I got all of mine at my local Lowes. Sometimes it will be a special order for your local store but they do not require huge amounts for a special order. Just go talk to the guys at the contractor desk.
    wildwest and Ralphie Boy like this.
  7. wfournier
    wfournier
    Western MA
    just as an FYI the "safe n sound" is what I have seen at home depot. Technically that is only a sound deadening and fire product not an insulation product. From what I had read it may be a different density and does not have a published R value.
    papadave and wildwest like this.
  8. papadave
    Hmmm, this is from the first sentence on their own website.......
    "ROXUL SAFE‘n’SOUND® is a stone wool insulation product for use in interior wall partitions of residential wood and steel stud construction where superior fire resistance and acoustical performance are required."
    gboutdoors and bobdog2o02 like this.
  9. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    The "Safe" part is the part we need here. Use Roxul, period.
    papadave likes this.
  10. wfournier
    wfournier
    Western MA
    Either is probably fine but just to clarify what I was referring too:
    CAN ROXUL SAFE'N'SOUND® BE USED FOR THERMAL APPLICATIONS?
    SAFE'n'SOUND® is intended for acoustical and added fire resistance in interior wall applications. Interior walls have no R-value requirements so R-value information is not tracked or published for SAFE'n'SOUND®. We recommend COMFORTBATT® be used in applications requiring thermal value.
    And:
    WHAT IS THE DIFFERENCE BETWEEN COMFORTBATT® AND ROXUL SAFE‘N’SOUND®?
    The difference between ROXUL COMFORTBATT® and ROXUL SAFE‘n’SOUND® is density (weight) and batt size. ROXUL SAFE‘n’SOUND® is denser than COMFORTBATT® and is manufactured to an approximate 3 inch thickness.
  11. papadave
    Yep, saw those too.
    Is the stuff you saw at Lowes the Comfort Batt?
    I'll go check it out.
  12. wfournier
    wfournier
    Western MA
    Lowes had the comfort batt home depot safe n sound.
  13. papadave
    Thinking Comfort Batts may go in the stove room, but then I'd need vapor barrier.
    Looking into that......lots of videos.
    Eric VW likes this.
  14. Oldman47
    Oldman47
    Illinois
    Roxul makes a lot more than that Safe N Sound product. I used their insulating batts (comfort batt), not the Safe N Sound batts. I did use a 6 mil plastic sheet vapor barrier when I used the insulating batts to insulate walls. I thought we were talking about using Roxul around a flue gas stack, chimney.
  15. Eric VW
    Not sure what insulation is doing in the "wood pile" area to begin with? Unless a firewood kiln is the goal? Or keeping wood stacks quiet?
    I dunno. I'm outa guesses....
  16. Oldman47
    Oldman47
    Illinois
    When you do a new install on an existing old school chimney you should block and insulate the new installed chimney pipe. Roxul is the frequently suggested product for that insulation because it is stable at extreme temperatures, unlike things like fiberglass or foam insulation. It shows up quite often as a subject on other more diverse forums that include help on installing a new stove.
    papadave and Eric VW like this.
  17. Eric VW
    That would fit in the stove section then, or DIY area... That's all I'm saying.... No other issue here.
    But I appreciate the peer check.:handshake:
  18. Oldman47
    Oldman47
    Illinois
    Sorry Eric. I didn't realize such an area existed here.
    Eric VW likes this.
  19. Eric VW
    No worries, just trying to help remind, so we can keep stuff lined up is all...:yes:
  20. papadave
    Wait, we gotta color inside the lines now? Jeesh
    Oldman47 likes this.
