Hinges?
Discussion in 'The DIY Room' started by wildwest, Nov 29, 2015.
  1. wildwest
    IMG_20151129_104431672_HDR.jpg IMG_20151129_104449115.jpg Trap door in floor to access cistern. I was hoping for something that did not show or could be tripped on?
    This is the the old door laying on the hole.
    Eric VW, Well Seasoned and papadave like this.
  2. papadave
  3. Eric VW
    Could do regular concealed hinges to the underside. Mite be tough with such limited work space tho. Getting the 35mm Forstner bit to hit correctly would be the biggest challenge...
    papadave and wildwest like this.
  4. papadave
    Hinges?
    We don't need no steenkin hinges.
    Stinny, wildwest and Eric VW like this.
  5. yooperdave
    Papadave isn't teasing, you know.
    Why don't you just make it a trap door that once it's needed, you just remove it completely? DH won't have to monkey with hinges and cutting the floor, easy fix; just as good looking! Chances are, the door already has door stops on the inside to prevent it from "overclosing"?
    basod, Jack Straw, Stinny and 3 others like this.
  6. Eric VW
    Good point. K.I.S.S. right?
  7. wildwest
    YES, and yes, and Thank You!!!!
    Eric VW and papadave like this.
  8. yooperdave
    I've crawled through too many doors like that in order to work in crawl spaces. The ones with the hinges and door hanging over you is just there waiting to al-ka-bong you when it falls!
    papadave, Eric VW and wildwest like this.
  9. wildwest
    He cracks me up alot, so I did not realize, thank for pointing that out!!
    Also, can I get rid of dumb ring to pull the door up?
    papadave likes this.
  10. Eric VW
    Which = OUCH:zip:
    wildwest and papadave like this.
  11. papadave
    wildwest , ours has a low profile piano hinge, and on the side opposite the hinge, instead of a handle, there's a 1/2" hole with a rope through it.
    There's a bolt tied on the crawl side to pull it down when closed, and a small knot on the top side which sits down in the hole....mostly.
  12. yooperdave
    Yes, you can remove the ring but ask yourself this first. Just how hard will the door be to remove once the grab ring is removed and what kind of damage will you inflict on the new floor trying to get the door open again?
    It's not uncommon to see those grab/lift rings exposed. Could always put down an area rug if the sight of it eats at you??
  13. Eric VW
    Or use something similar to this so the trap door "pops up" for an easier way to grab it and remove/open...
    The brown piece to the right....
  14. papadave
    Would help keep all kinds of detritus from collecting in the recess too.
  15. wildwest
    You guys ROCK! The common sense here and the KISS is invaluable.
    Eric VW likes this.
  16. yooperdave
    Aw shucks!
    Eric VW, papadave and wildwest like this.
  17. wildwest
    I talked to loon on the pet thread a few months ago, we need rugs in that area because its the exit entry for the dogs and the yard after the new septic will be extra muddy this year. Perfect!!
    Eric VW, yooperdave and papadave like this.
  18. wildwest
    Maybe something that flips out but flush, I remember the finger pull on the pocket door at my last house...... Obviously smaller but
    Eric VW likes this.
  19. yooperdave
    OK! Now, please let DH have a little relax time!
  20. wildwest
    Good Advice!! I just mentioned he has been working hard for several days straight, and he took off the knee pads and put the tools up:) I wonder if he will dream about laminate flooring tonight:rofl: :lol::rofl: :lol::hair:
    yooperdave and Eric VW like this.
