Logs Too Long
Discussion in 'Everything Else (off topic)' started by firecracker_77, Nov 24, 2015.
  1. firecracker_77
    firecracker_77
    IL
    Snowed here and my saw buck is out there under some snow. Been too lazy to go and cut some longer splits down to length to fit into the stove, so I've been letting them hang out the side door until they can be pushed the rest of the way in. I have a split in there now burning a few hours. Still can't be pushed all the way in, so I am burning it like a fireplace. Sending alot of heat up the chimney, but it's mild here, so that's ok today. Wouldn't be doing this if it were cold outside or I was short on wood.
  2. yooperdave
    Put your jacket and gloves on, slip on some boots, grab your saw and cut them shorter. There. It's done!
  3. yooperdave
  4. bocefus78
    bocefus78
    Sounds like something i would do while consuming a 12 pack :)
    Btw, tony is a get her done, no bs kinda guy. I could be his gene....but I'd need subtitles.....even in 5.1
  5. yooperdave
    Yeah, Tony is fun to watch! My old work partner called him Tony Bleeps!
  6. firecracker_77
    firecracker_77
    IL
    yeah...most of my wood is cut to length. just didn't feel like messing with a saw tonight. it's almost 40 tonight, so you can burn what you got and keep warm enough.
    when i split this, i was just trying to get enough wood split early enough to allow it to dry. now, i can further process the split wood and get it to the right size if it's too long. glad it was all split open early on.
  7. HDRock
    Make yourself one of these, cut the whole bunch at once
    OR Cram a few in a milk crate and cut them off
  8. wildwest
    Wyoming high plains
    Depending on the circumstances we would do the same....
  9. Eric VW
    Long splits, the occasional pole/branch that gets missed(sometimes a lot of limby stuff) goes thru my old miter/chop saw... Makes quick work without involving the chainsaw.... Drag it out into the backyard, hook up the extension cord, and let 'er rip:yes:
  10. yooperdave
    No matter what, it seems that every year I will have one or two chunks that are just a tad long also. Can't even fit them diagonally.
    I can live with those chunks. They may fit if I split them down real small and use them to start fires. If they're knotty, gnarly or otherwise a pain to try to split, they go to the bonfire pile or the OWB gobbles them up!
    The setup in hdrock's post above is nice!
    NH mountain man, HDRock and wildwest like this.
  11. firecracker_77
    firecracker_77
    IL
    For me, I just run it with the door open and eventually, it either gets smaller or the middle burns through and you can push it the rest of the way in. Lose some heat up the chimney, but that's ok. Had the room up to 95 last night. Siting at 79 this morning with a reload at 2:45 a.m. when I woke from the beer I drank. :drunk:
    Drank a 6 pack of light beer. Getting too old for this nonsense.
  12. yooperdave
    And what about the smoke smell from leaving the door open?
  13. bogydave
    Nice way to make one pass & get a stove load !
    You burn the crate full of chunks for shoulder season fires ?
    How you store the shorties long term ?
    HDRock likes this.
  14. bogydave
    Man who burn firewood, not lazy
    suffer from "burn out" maybe, but not lazy.
    Which saw you use to cut to size ?
    Only way to cure "burn out" is to light the fire inside one of the saws :)
    Once you get started cutting , the wood cutting bug feels good.
  15. firecracker_77
    firecracker_77
    IL
    Not too bad. The draft pulls well enough to carry the smoke out. No back puffing in the room
    NH mountain man and HDRock like this.
  16. ranger bob
    ranger bob
    Leeburn Ontario
    Yup! Tony's got that right.
  17. ranger bob
    ranger bob
    Leeburn Ontario
    Live and learn as ma used to say. Got this nice big stove that can take 22 inchers either way so like a goof I cut a whole tandem load (24 fc) into 18 -20 inch pieces as I had no clue as to the difference between a sec burn EPA stove like we had and a big hybrid cat stove. They will fit and burn ok but now find I prefer the old 16 inchers by far. The new stuff won't see the inside of the stove until winter of 18/19 so I guess God willing and the creek don't rise I can fix em up by then. I'll get it figured out sooner or later ma! LOL
  18. HDRock
    Yes, I burn all the chunks sometime or another usually shoulder season.
    If I end up with short pieces 8, 10, 12 inches long I just stack them in a regular stack.
    All the chunks get stored in the wooden crates I have
    I get a lot of stuff that needs to be recut from scrounging, limbs and stuff.
    I made that stand when I got a deal on 2 cords of dry split wood, and I had to recut about three quarters of a cord, it was definitely worth the time to put it together and it's all free pallet wood is made from.
    NH mountain man and Horkn like this.
  19. Doug
    Doug
    ohio
    I have an electric chainsaw that I keep on my back porch. If I get a log too big for the stove, I cut it on the porch and then throw it in the stove :)
  20. UncleJoe
    UncleJoe
    SC Pa
    That's me too. I keep an electric chainsaw in the garage for those pesky long splits.
    NH mountain man and Doug like this.
