Newbie Questions
Discussion in 'The Wood Pile' started by Grizzly Adam, Oct 29, 2015.
  1. Grizzly Adam
    Grizzly Adam Guest
    JB weld?
    Eric VW likes this.
  2. HDRock
    Can't answer that one , No experience with that , No sense in guessing:)
  3. Eric VW
    I meant, since you thought with all the members on here, we should be able to come up with a few more questions....
    Our house came replete with a block and flue tile chimney, from basement thru center of house up 22 feet to the crown.
    Terra cotta thimble/flue interface often loosens up with heat up, cool down- thermal cycling- and furnace cement cracks and gets repaired.
    I think it's a viable thing to cover if someone buys a house and wants to heat with wood, and is faced with a similar situation....
    That's all....:yes:
  4. Grizzly Adam
    Grizzly Adam Guest
    Tell me more about this pipe pitching when going through the wall.
    wildwest, NH mountain man and Eric VW like this.
  5. Grizzly Adam
    Grizzly Adam Guest
    In no particular order. Also, please add more myths.
    FAQs
    My stove manual says not to build a roaring fire in a cold wood stove. How do I safely bring my stove up to temp?
    How hot should I burn my stove?
    When is the best time to cut firewood?
    How is firewood measured?
    What is seasoned firewood?
    What size wood stove do I need?
    What kind of 2 cycle oil do I need?
    How do I dispose of ashes?
    How high should I mount my stove pipe thermometer?
    What is seasoned wood and how do I know when my firewood is ready to burn?
    Do I need a flue damper?
    Myths
    Pine will cause a chimney fire
    Creosote Sweeping Log
    NH mountain man likes this.
  6. Greenstick
    Greenstick
    Things to do when you develop a fire that is going nuclear. ie cut air supply, close damper, toss on a scoop of old ash from the bucket ect.
  7. Canadian border VT
    Thru wall chimney... from vertical straight up piece on top of stove you put a 90 Backwoods said needed rise so I looked it up.. quarter inch per foot.. here's a pic 20151124_101020.jpg
  8. Grizzly Adam
    Grizzly Adam Guest
    I finally fished up this project. To be honest, I had forgotten about it. Anyway, here is the link. Frequently Asked Questions
  9. Backwoods Savage
    Thanks Adam. To be honest, I too had forgotten this thread.
  10. JCMC
    JCMC
    Just outside of Shushan, NY
  11. Grahamt
    Grahamt
    Leeds
    Only been hoarding a few month , iv not read anything about rot . Is it a problem ?
  12. basod
    basod
    Mount Cheaha AL
    firewood will last indefinitely if kept off the ground and out of the elements.
    Don't cover it completely with a tarp or it won't breath enough to dry
    Welcome aboard which "Leeds" do you reside in?
  13. wildwest
    Hi Grahamt , for whatever reason I posted this for another member, WaddleRemodel . Personally, I have never seen rot in old stacks, but I am in extreme dry climate.
  14. Grahamt
    Grahamt
    Leeds
    Leeds Yorkshire uk .i should be fine then
  15. Grahamt
    Grahamt
    Leeds
    Damp and miserable hear so a valid point for me
  16. wildwest
    Not that I know of unless its in moist soil for a LONG time, and I only heard of that, not seen it in person. Just do as basod said :) Also, have you seen Backwoods Savage wood primer? Ultimate instruction manual.
  17. JCMC
    JCMC
    As thewoodlands says:
    Get
    It
    Before
    It
    Rots
  18. Grahamt
    Grahamt
    Leeds
    I don't do bad most of my garden faces the sun , rest is in a constant breeze . It's all a learning curve for me
  19. Grahamt
    Grahamt
    Leeds
    I'm getting what I can while I can , not often there's free wood round hear . Funny thing is folk want me to fell there trees now I have a saw. Practicing chopping wood then smallest first . Gotta do safety first, can't chop my wood if I break any bones.
  20. wildwest
    You'll be fine! And yes, it takes a couple years to get ahead, but well worth the wait for seasoned wood instead of fighting to keep damp wood lit, and seasoned wood burns hotter.
    Primer on Woodburning by Backwoods Savage
