Cold feet
Discussion in 'Everything Else (off topic)' started by Backwoods Savage, Nov 21, 2015.
  1. Backwoods Savage
    So, like many others, I suffer from cold feet. In my case, it is caused from having polio and also from a terrible back that makes the toes somewhat numb but not totally numb. Even inside the house, my wife goes barefoot year around while even many times in the summer I have the foot heater under the desk turned on to keep my feet from freezing. At night, we have, rather than a mattress warmer, a foot warmer. It comes up to almost knee height. It gets turned on a couple hours before I hit the sack and then turned down after a while after going to bed.
    For outdoors, I have a couple pair of boots, 1600 grams of thinsulate plus felts and another 2000 grams of thinsulate. Even in 50 degree weather when I am sitting still, it takes only a very short time for my toes to get cold even though I keep wiggling them to keep blood circulating. Speaking of this, every doctor and nurse have been surprised at how good the circulation is in my feet. But they still get cold. Yes, I've tried the toe heaters and hand warmers and such and even tried the new Thermacell heated insoles. Nothing seems to work.
    I've been checking into some new boots but still unsure what to get. What appears best so far are some of the boots from Baffin which are rated to -148 degrees. But I think those ratings are all marketing hype and no way are they accurate.
    Any suggestions?
    wildwest and Eric VW like this.
  2. Eric VW
    I don't have the cold feet situation yet, I'll be but 43 tomorrow.... But, if you're looking at Baffin- anything named after those islands may be accurate, 'cos that area ain't nothing but a rock with some mines on it, and only open a few months a year- our service manager went up there in July to look at some our transformers onsite, and it didn't get above 30F with 40 mph sustained winds.... Imagine temps in spring or fall up there, let alone dead of winter-
    I'd give them boots a serious looksie :binoculars:
    I hope you find something that works for you:yes:
  3. concretegrazer
    concretegrazer
    Southwest MO
    I'm no help with boot selection but I hate my feet getting cold. I have 2 pair of muckmasters that I rotate throughout the day on a peet boot dryer. The boots are always nice and warm when I make the switch.
  4. bassJAM
    bassJAM
    Cincinnati, OH
    I'm plagued with cold feet too, but nothing as severe as you have Savage! I've found that if I'm outside moving a couple pairs of layered wool socks works better than insulated boots. I guess it's because boot's aren't necessarily insulated on the soles. I also have had luck with those hothands packets, but they need recharged every 4 hours or so.
    As to the Baffin boots, I bought a pair of rubber bottom/leather upper Baffins a few years ago. It's hard to drive or even operate the clutch on my garden tractor in them because they're so heavy and stiff, but they are absolutely the warmest boots I've ever worn. Not walking around, I'll still eventually get cold feet in them. But it takes longer than anything else I've tried.
    Backwoods Savage and Eric VW like this.
  5. wildwest
    I am plagued with cold feet too, but it is from blood vessle spasms, so more towards cirulation. For me, all the layers in the world do not help, I have to literally warm my feet first, THEN use good footwear.
    Dennis, not sure if you have tried this, I saw a thin foil sole insert awhile back, it worked on the same idea as emergency space blankets for heat reflection. I did not try them because of my first paragraph. Thought I might throw it out for you, they were inexpensive.
    Backwoods Savage, bassJAM and Eric VW like this.
  6. Will C
    Will C
    New York
    I am thinking that you need heat-something like disposable insoles or even therma cell rechargeable insoles, or electric socks. You would to be careful. Or to burn yourself with your health concerns. My father was diabetic and struggled with poor circulation, so I understand what you are dealing with.
  7. Greenstick
    Greenstick
    Just to be a wise guy....my feet get warmer in my boots when I wet myself. But seriously I had a problem with hot feet a few falls ago. Sittin out by the fire pit and warming my toes and managed to set the soles of my shoes on fire. :bug:
  8. Pyroholic
    Pyroholic
    mid michigan
    For the record, I had a pair of rubber, insulated baffins a couple years ago. They were junk in every way. I would not buy that brand again.
  9. Backwoods Savage
    Well, this sort of leaves me out in the cold...
    bassJAM, concretegrazer and wildwest like this.
  10. Backwoods Savage
    Will, I've tried the insoles, even the thermacell rechargeable ones and have tried 2 pair of electric socks. Disappointed with all.
    I see Cabela has some new heated stockings but they are extremely expensive. Not sure if I want to try them or not. Worst part is they run the battery down very quickly, especially if using on high setting.
    Guess I'll stick with the chemical hand and toe warmers for now. But I keep hoping...
  11. wildwest
    Dennis, have heard of the home made neck warmer, old stretchy sock with real rice (not minute rice), stick in the microwave? I wonder if Judy could fashion something for your boots, of course more like sorels. Crazy idea I thought I would throw out there......
    Also, I have bought microwave slippers in the past, similar idea, put insoles in microwave, then back into slipper. They worked pretty good but were not very practical for walking on....... (I do not use them anymore)
    Oh, one other thought, I have a pair of crocs boots, of course more fashion than arctic, but wow the thick sole on them really helps me feet!! I also have a pair of arctic Merrell boots, the sole is not thick enough, the ground sucks the warmth right out.
  12. Greenstick
    Greenstick
    I am unsure as I have never used one but... Zippo makes some kind of a catalytic hand warmer. Not sure if these are too big to install in a boot or if there would not be enough air but something to look at.
  13. OhioStihl
    OhioStihl
    Southern Ohio
    Gerbings heated clothing for motorcycles works well. They have been purchased by "Glyde" I think.
    They have the 12V connection for bikes/ snowmobiles/tractors and also a battery pack for when you don't have access to 12V.
    I have used the socks, gloves and jacket. It's pricy but when it comes to warmth it might be worth it. Best of luck
  14. Backwoods Savage
    I was looking at the socks but found several bad reviews on them. Mostly that they don't hold up long and are uncomfortable with large seams, etc. They are pricey but if they work...
  15. thewoodlands
    thewoodlands
    I have Baffin snowmobile boots, even in the coldest weather last year my feet were warm, I'll get the model number after we eat.
  16. MightyWhitey
    MightyWhitey
    Grandpa used to say......................"If your feet are cold, put a hat on."
  17. OhioStihl
    OhioStihl
    Southern Ohio
    My socks and jacket have the big seams. My wife has a newer heated jacket and there is some kind of carbon flexible heating element in it. It is more of a "normal" jacket.
  18. MightyWhitey
    MightyWhitey
    Vs.................an "abnormal" jacket????
    Unless you buy it from the "slightly irregular" rack at WallyWorld or K-Mart!!!!
  19. Backwoods Savage
    And he was right. I rarely go without a hat.
  20. wildwest
    Dennis, I wanted to mention if the thermacell inserts work somewhat for you, I see excellent prices on bulk batteries often, I could alert you. 9V, right?
