Tire grooving
Discussion in 'Chainsaws and Power Equipment' started by Trilifter7, Nov 22, 2015.
  1. Trilifter7
    Trilifter7
    Waynesville, OH
    Got my groove on today grooving my R4's on my 1025R.
    It was actually really easy and the whole thing only took me about 2.5hrs to do all 4 wheels. Should give me better traction for plowing
  2. MasterMech
  3. LinkedXJ
    LinkedXJ
    That turned out pretty damm nice!
    clemsonfor, wildwest and Trilifter7 like this.
  4. NewToStihl
    NewToStihl
    Central Indiana
    Sorry if this is a dumb question, but this concept is new to me. Are you grooving out the 'proud' treads and then putting some sort of plastic insert into the groove? If so, what purpose does the insert serve?
    Thanks!
    clemsonfor and wildwest like this.
  5. LinkedXJ
    LinkedXJ
    No insert.
    This allows the tread to cut through the snow.
    The more surface area you have on snow, the less your tire is going to grab.
    You need skinny tread, a skinny tire, sharp tread, whatever.. Tread that works in snow, is tread
    that is skinny and cuts through the snow.
    Best i can explain it..
  6. NewToStihl
    NewToStihl
    Central Indiana
    Copy that. It's always been my understanding that, unlike mud tires, snow tires have a treat pattern that holds snow since snow sticks to itself much better than any rubber or plastic sticks to it. The reason I asked my question was due to the fourth photo in the post? Or, are those the very neat & clean pieces of removed tire material?
  7. Trilifter7
    Trilifter7
    Waynesville, OH
    The more edges you have on snow and ice the better traction you are going to get. By grooving the tire you are doubling the number of edges on each tire to help grab the snow/ice.
    Chvymn99, MasterMech and wildwest like this.
  8. Trilifter7
    Trilifter7
    Waynesville, OH
    Yea those are the removed material
  9. NewToStihl
    NewToStihl
    Central Indiana
    That's awesome! What type of tool did you use? Sorry if that's another dumb question...
  10. Trilifter7
    Trilifter7
    Waynesville, OH
    I was new to this too just a few weeks ago. It's called the Ideal tire grooving tool. It's basically a soldering iron with a horse shoe like blade on the end that helps melt and cut the tire rubber. I actually got into a community tool pass along on another forum so the tool cost me $65 plus shipping and now the next guy pays me $55 plus shipping to send it to him. New the tool is $85 but I am the 3rd one to use it now, so each guy pays $10 plus shipping for the tool until it's paid off. After that it travels around to the next person at the cost to ship it to them. Pretty cool deal for tools you need to buy to do a specific project that will only be used once.
  11. Trilifter7
    Trilifter7
    Waynesville, OH
  12. dgeesaman
    dgeesaman
    Elizabethtown, PA
    IMG_00000420.jpg I did mine last year. Same tool, same kind of tire. I borrowed the tool from a friend who is a circle track mechanic.
    It's definitely better in the snow. I would slide around on snowpack because the weight of the tires would compress the snow into a tight smooth layer on the asphalt. The big blocks of tread had no bite at all.
    With the grooving added, I get some bite and the grooves reduce the creation of that smooth surface.
    It's nothing at all like the traction of a car snow tire, but it's a step in that direction and it does help. My rear tire wear in normal usage is a non-issue.
  13. Chvymn99
    Awesome job! Looks good too!
    clemsonfor and Trilifter7 like this.
  14. ironpony
    ironpony
    Mid Ohio
    very nice job, you can have them siped also and it is like having little teeth on the tires. big tire shops can do it.
    clemsonfor and Woodsnwoods like this.
  15. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Why not just use chains?
    clemsonfor, JustWood and Woodsnwoods like this.
  16. ironpony
    ironpony
    Mid Ohio
    my reason for no chains, I have approx 4000 sq ft of pavers I clear, driveway and courtyard. I even have a rubber edge on one blade to protect them. I run 2 tractors in the winter, one set up for the asphalt and one for the pavers.
  17. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Ahhhh....pavers. Got it. They are not that popular here so it never crossed my mind. Makes sense now...carry on! :D
    clemsonfor likes this.
  18. dgeesaman
    dgeesaman
    Elizabethtown, PA
    In my case I dis not want to damage the asphalt. The rubber chains were much more expensive so I tried this first.
    I should mention that the slick snow pack phenomenon on asphalt seems worst if you spin your tires at all. The grooves help to stop this cycle before it starts.
  19. MasterMech
    They're hell on asphalt, pain in the azz to mount/dismount, and expensive to boot. In some situations they make a lot of sense, but if you just want a little more snow traction, grooving is cheap and it works.
  20. Trilifter7
    Trilifter7
    Waynesville, OH
    Yep, I grooved mine for all those reasons. My driveway is concrete so I didn't want to scrape it up with chains.
