Manual splitting trick
Discussion in 'The Wood Pile' started by bobdog2o02, Nov 22, 2015.
  1. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Hey guys, thought id share this trick i learned somewhere else... Put a tire on top of yout splitting block and put your smaller to mid sized rounds in the tire. Then swing away. No more running around the yard bending over to pick up and set back up for another split.... I think the wheel size on this tire is 14" and it works pretty good for me.
  2. Backwoods Savage
    Yup. An old trick.
    Some find it useful but I never did. More trouble than it was worth to me but if it helps, use it.
    Horkn, yooperdave, Chvymn99 and 2 others like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Its great for me. My yard is really hilly so when i have to go chasing its usually downhill.
  4. Oldman47
    Oldman47
    Illinois
    I have been using a tire on the stump that is my splitting block. I left mine loose so that I could just drag it off to remove all the bits of bark and such that would otherwise build up inside.
  5. schlot
    schlot
    NW Iowa
    Bobdog...good idea. Chasing splits is never fun.
    Of course some of us can swing the maul just once and it not only splits it into four perfect pieces but they also fly into a perfectly stacked row without being touched.
    I don't want to mention any names (Schlot) or anything as I'm sure that member would rather remain anonymous (Schlot) :)
    Horkn, MasterMech, WVhunter and 7 others like this.
  6. scooter422
    scooter422
    tmp_7176-P_20150618_143254-1847109784.jpg yep! I like to double stack my tires so no splits fly out.
    Horkn, WVhunter, gboutdoors and 3 others like this.
  7. bogydave
    Good idea
    I used an ATV tire, a little taller
    Cut the sidewall out & turned it inside out
    Star the bottom to use for screws on the plywood, screw the plywood to the stump
    Works good for kindling too:
    has been replace for a few years now : Still split vertical though :D :::
    Horkn, concretegrazer, HDRock and 6 others like this.
  8. old 040
    old 040
    Buckeye State
    well done..........looks like you have a ways to go there..........:axe:
    Horkn, WVhunter and Well Seasoned like this.
  9. DaveGunter
    DaveGunter
    Yeah...that's gonna require video proof:)
    Horkn, WVhunter, Stinny and 3 others like this.
  10. coal reaper
    coal reaper
    Nj
    Tractor tire here. I love best the 20-23" rounds that barely fit.
    Horkn and WVhunter like this.
  11. MightyWhitey
    MightyWhitey
    I've thought about doing this since I've been burning to heat my home....................4th year now. I've used nothing but my Fiskars X-25 for 98% of my wood in that time. Them Fiskars are damm sharp..................would I tear up the tires pretty quick????? Or would the steel belts in the tires do a number on the business edge of my Fiskars???
    Horkn likes this.
  12. Oldman47
    Oldman47
    Illinois
    The tire flexes when you miss and hit the tire so it doesn't deteriorate too fast and doesn't harm the maul either. I have small nicks all over the sidewall on my tire but I don't ever intend to put it on a wheel so I don't really care.
    Horkn, MightyWhitey and coal reaper like this.
  13. Backwoods Savage
    Would not tear up the tires......you are supposed to hit the wood, not the rubber. :axe::axe::axe: :eek:
  14. coal reaper
    coal reaper
    Nj
    yeah, the handle is what makes contact with the sidewall.
    Horkn likes this.
  15. MightyWhitey
    MightyWhitey
    I almost never miss BWS!!!!:whistle::whistle:
    Often times when I hand split; my Fiskars winds up in my splitting stump after going thru what I'm splitting. I was just wondering about it hitting the bead of the tires and all...............................
    Horkn and Backwoods Savage like this.
  16. cnice_37
    cnice_37
    You can cut out the bead.
    I need a bigger cutting block, full size truck tire now slips over the block.
    Horkn likes this.
  17. red oak
    red oak
    Have seen this trick before but have never used it. I prefer to just split the wood where it lies, rather than pick it up to put it inside a tire. I also just split on the ground so I don't have to pick the pieces up more than I have to. But looks like a good trick and if people find it useful then have it!
  18. scooter422
    scooter422
    I use a X27 and never had problems with the tire. Those tires can take a lot of abuse. You won't get into the steel belt. A lot of flex in those tires. I double my tires up so the splits stay in and there is a little more flex if you do hit the top tire.
    Horkn and MightyWhitey like this.
  19. T-Stew
    T-Stew
    Always wanted to try but I've never had an old tire laying around nor a large enough splitting block.
    Horkn likes this.
  20. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Old tire, free at any place that sells tires. They have to pay per tire to dispose of them.
    Horkn likes this.
