Flagstone tile with plastic mesh in hearth???
Discussion in 'Modern EPA Stoves and Fireplaces' started by NVhunter, Nov 15, 2015.
  1. NVhunter
    NVhunter
    Northern Nevada
    Im currently building a hearth pad for an Ideal Steel. It needs 0.41 R value for the hearth.
    I put two layers of 1/2" Durock Next Gen so my R value is 0.78 so I'm already good regarding what the IS needs.
    My first question is, I'm putting down flagstone slate tile on the Durock but the tile I purchased has plastic mesh holding 7 pieces together for each segment of the tile. Is it ok to have this plastic mesh imbedded in the mortar in the hearth or do I need to remove each piece and install them individually without the plastic mess?
    Also, when securing the Durock to the 3/"4 plywood I used 1 5/8" screws evey 8-10". With the screws under the mortar and slate that go into the plywood that are under the stove, do I have to worry about heat radiating down though the screws and into the plywood???
    wildwest and Eric VW like this.
  2. HDRock
    No need to take pieces apart , job will go faster , that's what it's for, I have put down lots of tile with plastic mesh .
    On the heat radiating down though the screws and into the plywood , Just my guess here,not a problem
    wildwest, Eric VW and NVhunter like this.
  3. Highbeam
    Highbeam
    I would NOT worry about the screws. That said, Woodstock prides themselves on being available for these types of questions.
  4. IS obsessed
    IS obsessed
    Shenandoah Valley
    If you have the ash pan on your IS, like I do, I think you'll find that very little heat radiates down into the hearth. I wouldn't worry for one second.
    wildwest, HDRock and Eric VW like this.
  5. ansehnlich1
    ansehnlich1
    We laid two layers of durock in a thin mortar bed, no screws, then brick on top. Hasn't moved in 8 years. I know I'm the odd guy out here, but I have no screws, no combustibles in my hearth pad build.
    I'd certainly contact the stove company and get their input to satisfy my mind if I were you.
