Off topic tug of war gt vs rzr
Discussion in 'Chainsaws and Power Equipment' started by tjcole50, Nov 19, 2015.
  1. tjcole50
    tjcole50
    ohio
    Hillbilly match in the making. Deere 455 with 40 loader 54" deck, 6 suitcase weights, a few dumbells loaderd tires 50 lb wwheel weights plus chains VS a polaris razor 900.
    455 weighs in at 2600 lbs minus operator at 225lbs and 6 gallons of fuel. Razor weighs 1100 ish lbs
    Razor owner claims low 4x4 will pull the garden tractor like itss not there...
    455 has diff lock no 4x4
    The debate is heated and close to happening
    Who wins in a tug of war haha go
  2. papadave
    :ithappened:
    :popcorn:
    tjcole50 likes this.
  3. Mag Craft
    The Razor will lose. Traction and weight will win this.
    Birddogtg, Horkn and tjcole50 like this.
  4. tjcole50
    tjcole50
    ohio
    Hes refusing a pavement pull so it will be grass ... chains added to the 455
  5. tamarack
    tamarack
    paulina oregon
    Wow interesting picts would ne nice. So ur talking like a tug of war? I think the 2600 pounder is way overmatched in the hp dept. However the razor is not heavy enough a video would be cool.
    papadave likes this.
  6. tjcole50
    tjcole50
    ohio
    Yea razor for sure has more hp i believe in 75hp range. The yanmar 3 cyl and k92 tho i think hit in the 650ish range as far as lb ft of torque go..
  7. tamarack
    tamarack
    paulina oregon
    With chains and suitcase weights on the tractor that razor is gona get dragged
    tjcole50 and Horkn like this.
  8. Horkn
    All that power won't matter when its being dragged.
  9. tjcole50
    tjcole50
    ohio
    Hopefully have a vid by the weekend
  10. Oldman47
    Oldman47
    Illinois
    Forget HP, it's all about torque to the driving wheels when all else is equal. OTOH this one could be won by a rock that weighs too much for the Razor to move it.
  11. tjcole50
    tjcole50
    ohio
    I just cant imagine a 1200 lb high gear cvt fun cart will be able to match 2x its weight vs a heavy garden tractor. Even with 4x4. Unless im under estimatint these things. I know i will yank a bigger utility atv around pretty easily.
  12. Canadian border VT
    Burl the loader you win for sure:yes:
  13. lukem
    Make sure you wear a hat, because the Polaris will be shooting rooster tails all over you as you drag him across the yard.
    I need to see a video of this. Not want, need.
  14. Canadian border VT
    yeah, if happening in your yard... loser has to fix ruts and grass seed too don't ask how I know:whistle:
  15. 94BULLITT
    94BULLITT
    Frederick County, VA
    There was a video on youtube of 4xx that 4wd vs a gator. They dead even, they both sat in place, neither one budged. I say it will be close but with rzr having 4wd he may have the upper hand.
  16. 94BULLITT
    94BULLITT
    Here is the video I was thinking about. It was a x585. It looks like he could have pulled the gator but the hydro was too weak.
    concretegrazer likes this.
  17. 94BULLITT
    94BULLITT
    Here is a gator vs rzr
  18. MasterMech
    Please note the performance of the Gator in the above examples! :dex:
    I've bested a 455 (ag tires) with a 6x4 diesel gator before. Pulling on item 4. Both dug in hard and the Gator just had more traction.
    Your case? That razor is gonna chit bearings trying to drag that weighed down 455. If it doesn't have a low gear, he doesn't stand a chance. Being on grass is probably working in his favor. The 455 will pull harder weighed down on ag tires vs. chained turfs. Go easy on the hydro pedal and stand on the diff lock.
  19. bassJAM
    bassJAM
    Cincinnati, OH
    Since the Deere has a diff lock, I'm voting that for sure. Hopefully that Rzr doesn't bust his front diff, there's parts in them that are plastic and have been known to break if the front wheels come off the ground and then hit the groudn at a higher wheel speed than ground speed.
  20. 94BULLITT
    94BULLITT
    Air your rear tires down so you have nice flat contact patch. Also are the rear tires loaded? You could have rimguard put in them for more weight.
